Question about Singer 3116 Simple
Singer 600 touch and sew
How do you get the thread out of the bobbin to sew??? Having trouble have tried 2 different color threads to try and see what I'm doing wrong can you help
Raise the presser foot. and close the slide plate over the bobbin.
Hold the tail of the needle thread loosely.
Turn the hand wheel toward you (counter clockwise) and lowerthe needle into the hole in the plate.
Keep turning the wheel until the needle rises back up to it's highest position.
Gently pull back on the thread until you see a loop of thread come up from the bobbin case.
Open the loop and find the free end of the bobbin thread.
Voila!
Now you can sew.
Posted on Oct 31, 2008
Turn the hand wheel until the needle rises back up to it's highest position.
Gen
You will see a loop of thread wrapped around the upper thread.
Voila!
Now you can sew.
Having trouble picking up the thread from the bobbin
Try a brand new needle. Verify that the machine is threaded properly--both upper and bobbin threads.
If it is still not picking up the bobbin thread, it is likely there is a needle/hook timing issue requiring service.
May 17, 2016 | Singer 4411 Heavy Duty Sewing Machine
TIming Consew 210
I am not sure about this particular machine but in most machines there will be a nob on the front loose low numbers like 0 1 -2 work well on number 3. If the nob is not on the front check and see if it is on the side.
Aug 27, 2008 | Consew Sewing Machines
I have a singer 500/550 .I'm trying too sew a straight stitch ,but I'm having trouble with the tension. What's the best setting? And i can't sew with needle in the middle position. Why
500/550? wow, that an old one. have you check your timing? or the bevel gears?
what type of problems are you having with the sewing. is the thread knotting up on the back side of the fabric? is the thread just breaking? or is it just missing stitches? does the needle hit the bobbin case?
I have a 600 series and I found that if i put the tension around 2 or 3 it sews the best.
too tight the tread breaks, too lose the thread knots up on the back.
I had to change out the bevel gears and have the machine re-time to stop the miss-stitching.
also may want to check your bobbin tension.
May 29, 2015 | Singer Sewing Machines
Top thread tangled in bobbin.
try changing the needle---flat side goes to the back side of the machine
also check the top tension
depending on the fabric your sewing on--the needle & thread have to work
with the fabric--example light fabric needs a different needle & thread than
a heavy fabric
check to see if the thread is coming off the thread take up lever when you
sew.
Apr 04, 2012 | Singer 8280 Mechanical Sewing Machine
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
Bobbin thread will not stitch.
Have you had the machine serviced since you purchased it? This is something that should be done at least once a year.
Take the machine to a certified Singer dealer and explain what is happening. There may or may not be something that needs to be adjusted.
Your warranty is still in effect, but is now limited. Attempting to repair it yourself or having someone who is not a Singer dealer repair it will invalidate the remaining warranty.
Apr 16, 2010 | Singer 3116 Simple
I have a Singer Touch N Sew Model 636. The
I had a Golden Touch 'N Sew many years ago and as the machine aged and parts became worn, step 4 of this bobbin winding diagram started to become a problem and I had to sometimes try several times before the "tabs" would release. If they did not release, the machine "thought" it was still winding the bobbin and would not sew.
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_2001_touch_tronic_threading_diagram.htm
Mar 06, 2010 | Singer Sewing Machines
Singer 301a...sews on top of fabric nicely...bottom is just loose loops of thread...it's like the bobbin is not sewing...I put 2 different colors in to see...top is perfect...on bottom of fabric I see the...
This is a tension adjustment problem. It's good to use two different colors of thread, like you did. From your description, the top thread (needle thread) tension needs to be tighter. As you tighten the tension of the top thread, you'll see that the top thread pulls the bobbin thread up into the fabric so it's no longer laying loose on the bottom of the fabric.
You'll need to have the pressure foot down when you tighten the tension. Tighten it a little, sew a practice seam, check to see what the stitch looks like. Tighten it a little more, sew, check, etc etc--until both top and bottom look the same--you shouldn't see much (if any) of the bobbin thread color on top of the fabric or the top thread color on the underside.
Let me know how this works for you, ok?
Robbie
Jan 25, 2010 | Singer Sewing Machines
Singer touch n sew 750 winding bobbins
You can find Singer bobbin winding instructions at http://www.singerco.com/resources/bobbin_wind.html.
"Birdnesting" occurs when there is no tension on the needle thread to pull the bobbin thread. This is easily corrected by rethreading the machine, following the threading path carefully and making sure the thread is fully engaged in the tension mechanism.
Jun 21, 2009 | Singer 7442 Mechanical Sewing Machine
Raising the bobbin
Use a SA 156 metal bobbin (ebay, 20 of them for $8.99 free shipping) and make sure the bobbin thread is turning the right direction, read you manual or call singer at 1-800-4singer
Aug 23, 2008 | Singer 3116 Simple
Singer 3116 Simple Logo
270 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
