Question about Akai LCT2660 26 in. HD-Ready LCD Television
Need help with TV
The LCD became harder and harder to turn on (had to keep flicking switch on base several times until it finnally catches and comes on) and now it just doesn't come on...any suggestions?
  • 3,130 Answers
Must be a problem with the back light circuit. This not a repair for the amature repair person or handyperson seek out a pro as there are no user replaceable parts inside this unit. Good Luck
Posted on Aug 04, 2006
Power and Video Out
I sounds like the internal power supply board was failing and has now completely failed. What is the vintage of the TV? There was a large problem with some components used in electronics for many years.
Apr 27, 2016 | LG Televison & Video
My lcd tv dont have image but has sound. i tried turning it on and off and suddenly became normal but after a while it turned back to the same problem.
There's a good chance you have failing electrolytic capacitors either in the power section or the inverter section or both.
Any caps in these sections that look bulged at the top, or bulged/leaking at the bottom need to be replaced.
If you repeatedly turn it on, eventually it'll probably stay on, but every time you turn it off, the TV will get harder and harder to start up until one day it just won't.
Sometimes you have to do the opposite to start it up and unplug it for 5 mins, then try.
If you aren't tech savvy, this unit needs to go in for repair.
If you are handy with a soldering iron and can identify the power supply and inverter / FM section for the backlights, an inexpensive handful of capacitors will likely fix you right up.
Match the capacitance on the capacitors. Go over voltage if you can, and still have them fit.
IE - it's not a bad idea to replace a 10V cap with a 16V, but don't replace a 680uF cap with a 500uF or a 1000uF (unless you are positive it's only doing ripple filtering).
Mar 03, 2011 | Televison & Video
Daytek television will not turn on.
There is a manual switch on the bottom of the TV. Flick it on and TV screen should come on. The power light will come with this switch off but the screen won't. It had me cursing for a while until I saw the little switch.
May 15, 2010 | Televison & Video
My magnavox plasma tv started to take a long time to turn on until it finnally just wont come on the power button blinks off and on and it seems the tv is trying to come on but it wont
My concern is that this is a power supply issue. Hope it is still under warranty. Find a good qualified service shop. I would call first and get some estimates of repair.
A/V Media Tech Guy
Dec 20, 2009 | Televison & Video
I have a Philips 50" Flat HDTV model 50PF9431D/37. Problem with screen turning on. I get sound. I get 9 quick flashes in red. Then after unplugging and plugging back in several times. It then blinks...
I have the exact same problem! I have it hooked up to a power strip now to unplug it by flicking of the power strip and waiting for the red light to go out then I turn it back on while Channeling up 10 X's and then down and up until it comes on. I listen to the sound of the switch which it comes on. I turn it off if it is faint and then back on and channel up. Crazy process but it's been working. It takes about 10 minutes everytime to get the TV on until I get a tech to come out and look at it. The capacitor keeps a charge which is why the light is flashing with a code for 60 seconds./JJ
Aug 29, 2009 | Philips 37PF7320A 37 in. HD-Ready LCD...
Dim and flicking last black screen
It sounds like your monitor went bad. It happens. Call around. There are a lot of deals now. Good luck.
Aug 04, 2009 | ViewSonic VX1940w LCD Monitor
Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Feb 15, 2009 | Samsung LW20M21C 20 in. LCD Television
My 50SBX70B flicks than lost the power
Symptom: NO HOR SYNC
Symptom: No Horizontal Sync. When PinP is called up, main picture may lock up for a 8 moment, then it goes back out of sync.
Cause: I008 defective (Sync Switch)
Jan 15, 2008 | Hitachi 50SBX70B 50" Rear Projection...
Need help with TV
take it apart and see if all the cables are seated properly, and check the panel voltages could be one of the boards
Aug 04, 2006 | Akai LCT2660 26 in. HD-Ready LCD...
Akai LCT2660 26 in. HD-Ready LCD Television Logo
29 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
