Question about Saws
Can't unscrew arbor nut on my MS250 Delta Miter Saw. Tried everything to turn it counterclockwise with no success.
Have tried with open end wrench but it seemd frozen. Manual says turn counmterclockwise, which I have tried.
    Sergeant:
  • 462 Answers
Nuts on saws loosen clockwise same direction as blade
Posted on Apr 21, 2014
  • 885 Answers
The arbot bolt on your saw has reverse threads or righty-loosey, lefty tighty. You should be turning it clockwise as you are looking at it or in the same direction the blade turns when cutting. The arbor bolt on these saws are reverse thread so that they are self tightening while the saw is in use.
Posted on Feb 09, 2012
5 Suggested Answers
  • 37 Answers
SOURCE: The delta universal miter saw stand will not adjust to level posi
Hi, The legs on the stand should have leveling pads on it. at the bottom of each stand legs, there is a hole which the pad goes in. you can adjust the pad by unloosening the top nut. put a level on the saw base and adjust the pad up or down to level your stand.
If this doesn’t work for you, please write back. Thanks,
Posted on Nov 28, 2008
agent91
  • 2100 Answers
SOURCE: I have a 1979 unisaw and it is burning stock
I would use a straight edge, to see if the blade is parallel to the table. Bring the blade up, put the straightedge on it and measure to one of the dado cuts in the table, front and back should be the same. If not, You can loosen up the mounting bolts underneath and tap the whole thing around to square it up. Hope this helps.
Posted on Mar 03, 2010
al_kupchella
  • 843 Answers
SOURCE: My saw problem has to do with changeing the blade.
The nut is binding on the arbor because the threads are buggered up or clogged with something. It could be the nut (which is probably brass and soft) or the arbor (which is steel). If it got a little cross threaded, the damage will be on the nut. It might be the arbor if the arbor took a whack. Once you have it apart you should be able to see it - although the damage might be pretty small. You aren't likely to have a tap and die to run through the threads, but you can probably fix it with a little rotary tool (like a dremel) using a small disc. If it is the arbor you can use a triangular file. Or you can buy a new nut. I hope this helps.
Posted on May 17, 2010
jyackle5
  • 8197 Answers
SOURCE: For Delta 36-540 Type 3:
CHANGING THE BLADE
1. WARNING: WHEN CHANGING THE BLADE,
MAKE CERTAIN THE TOOL IS DISCONNECTED
FROM THE POWER SOURCE. USE ONLY 10" DIAMETER
SAW BLADES RATED FOR 4600 RPM OR HIGHER
WITH 5/8" ARBOR HOLES.
2. Raise the saw blade to its maximum height and
remove the table insert (A) Fig. 35.
3. Using the open end wrench (B) Fig. 35, place open
end of wrench on flats on inside blade flange to keep the
saw arbor from rotating and remove arbor nut (C) with
wrench (D). Turn nut (C) counterclockwise to remove.
Remove outside blade flange (E) and saw blade (F).
4. Assemble new blade, making certain teeth of blade
are pointing down at the front of the saw table and
assemble the outside blade flange (E) Fig. 35, and arbor
nut (C). Tighten nut (C) with wrench (D) by turning nut
clockwise while holding arbor steady with other wrench
(B).
5. Replace table insert.
jyackle5_53.jpg Or you can get the manual on the link below. On the right where you see downloads scroll down to the bottom to download the manual also make sure that you are on saw 4.
http://servicenet.deltaportercable.com/Products/Detail?isId=true&productNumber=36-540&selectedType=10717#
Posted on May 21, 2011
Removing Pro-tech table saw blade, is the nut holding it reverse thread? or standard?
Ralph, the arbor thread on a left tilt table saw is "standard" thread direction - that is, when looking at the end of the arbor (which of course you can't do on a table saw) turn the nut in a clockwise direction to tighten, counterclockwise to loosen.
Hope this helps.
Regards,
DIYpro
May 01, 2011 | Garden
I want to replace the blade on my 10"compound miter saw but the bolt for the arbor is frozen up. I have tried everything and of course now the bolt head is stripped. I am assuming the bolt loosens to...
yes sometimes the bolts are left handed thread. What you can try is find a metric socket that starts to go on to the nut and tap it the rest of the way on the nut with a mallet then try to unloosen the bolt.
Apr 01, 2011 | Garden
How do i change the blade on my delta 10" mitre saw
Exploded diagram for your SM100M miter saw is here.
User manual is here.
Page 20 covers blade change operation.
Make sure you unplug your saw! You need to remove a screw from the cover and rotate the cover to the rear. Use a hex wrench in the motor shaft to keep the saw blade from turning, and loosen the arbor nut with a 1/2" wrench. The arbor is reverse threaded, so you'll turn it clockwise to loosen, then counterclockwise to tighten it up after you have swapped the blade.
Rotate the cover back after that's done, and replace the screw.
If this was useful, please vote. Thanks.
Nov 23, 2009 | Delta SM100M 13 Amp 10" Compound Miter Saw
Change blade miter saw
Un-plug the saw. Remove the screws holding the side saw guard in place. Look at the center of the saw blade for the nut holding it in place. Take a socket wrench that fits the nut and loosen it. You'll need to take a scrap piece of wood 2x4, and jamb the teeth of the blade into it while loosening the nut. The nut will come off first and then a washer/spacer.
Reverse the order for installing the new blade. Make sure you use the proper size diameter blade (10 inch) and mounting hole in the replacement blade. Also, use the provided washer/spacers that were on the original blade and secure the nut. Spin by hand to see if everything clears. Mount the protective guard back on. Plug in the saw and test cut .
Good luck. If you are still unsure - ask a handy neighbor to help. It takes about 5 minutes to complete this task.
Oct 05, 2009 | Delta Cycle Rothko Rolling Bicycle Stand
How do I align the saw blade with the saw table I have a 10 inch Delta Contractor's saw that is about 10 years old. The blade is not straignt with the miter slot. andyc@bergeralllied.com
The Blade Arbor is held to the bottom of the table with mounting screws and stop/adjusting screws. Loosen the mounting screw and adjust the stop screws to make Blade true with miter slot.
Sep 14, 2009 | Delta 36 982 10 Inch Left Tilt 1 1/2...
I need a user's manual for a Delta MS250 Miter Saw
I have nothing to do with the product list, thank you. But the information you are trying to find is located at Dewaltservicenet.com and in the middle of the page at the bottom type in your model number and on the following page go to the listing at the left for the schematic and open it, you will see another selection for instruction manuals go to the last one which is in English. If I have answered your question please rate this information accordingly and thank you.
Jul 10, 2009 | Makita 10" Dual Slide Compound Miter Saw...
Changing the blade to our compound miter saw when hex slot is rou
ok a couple things to try...
Firstly to hold the blade arbor still if it doesnt have an arbor/spindle lock button, try wedging a piece of wood between the blade and the saw table (might have to lower the cutting head and hold it down. Next try again with the hex key... Make sure it is the right size one, i.e. the one that came with the saw. If the hole is really rounded out, you are in a bit of a bind, however, the next option is to get a grinder and try and slice a groove across the nut so you can fit a large screwdriver or a flat piece of steel in th slot in the nut you just made for leverage and try and work the nut off that way. Either way, be sure to get a new blade nut if and when you get it off to make sure the problem doesn't occur again. See how you go.
Jun 20, 2009 | Sears Craftsman 7-1/4 in. Circular Saw...
How do I replace my mitre saw blade?
It should still easily fit a 5/8" blade. The arbor shape shouldnt have any effect on the type of arbor hole needed on the saw blade (only round arbor holes are made on saw blades. You will probably find the arbor securing nut has a shape that fits into the flat gaps between the saw blade and the arbor when fixed. So grab a 5/8" round arbor saw blade and give it a go. It should work fine.
It is the arbor nut that secures the blade onto the arbor via friction which holds it on.
Please rate this solution on FixYa!
May 29, 2009 | Ryobi ZRTS1342L Factory-Reconditioned 14...
Need manual for Delta 10'' compound power miter saw MS 250
If you can't print from your computer, or local library, find a local print shop or copy shop that is willing to download and print a .pdf file for you.
Then go to this link and you'll be able to download a pdf file with the manual you're seeking: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/A05737.pdf
If this solves your problem, please take a second to rate this post and let us know! Best wishes!
Mar 18, 2009 | Delta JT160 Shopmaster 10 Amp 6 Inch...
Cant find owners manual for Delta compound miter saw model Ms250
Go to this link and you'll be able to download a pdf file with the manual you're seeking: http://www.dewaltservicenet.com/documents/English/Instruction%20Manual/Delta/A05737.pdf
Mar 16, 2009 | Delta Saws
Saws Logo
206 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
