Question about Sony KP-53HS10 TV
Sony HP53HS10 power supply board
I am looking for a power supply board for Sony HP53HS10. Do you have an idea where to buy it?
  • 10,594 Answers
Please mention correct tv model as
HP53HS10 is incorrect.
Posted on Oct 23, 2008
Red blinking standby on my sony tv
That problem is cause of faulty power supply board..
look at the capacitors if bulged then try to replace it..
Watch this video to learn more about capacitors:
If you have soldering skills its better to buy a new power supply board online...
Feb 03, 2012 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
Stand by light blinks 6 times and never turns on. sony grand wega kdf-wf655
This issue is related to a power problem in as much as the TV turns off on it's own. I think the TV has developed a power problem.
The problem is consistent with overheating on the power supply board of the TV.
The power supply board of the TV has few capacitors and IC. If any of these IC's gets short or become weak, it can cause the TV to turn off on it's own.
When current passes from electric outlet to the power supply board of TV. The current also goes to the weak/faulty part, then the current stops or slow and the board overheats and TV shuts off on it's own.
This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
This is a common problem faced by many other users too. To solve this issue, check the power supply board and read it with a meter and continuity tester, in order to detect the faulty part and replace the faulty part on the board which is short due to which power supply board.
Sony specifically uses GM1 Board. In other words, Sony power supply board is called "GM1 board"
It's a bit technical job but yes its not at all a costly repair to do or get it done by the technician.
You can buy this part at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor (capacitors) most likely the normal operation will be restored. Or you can buy a refurbished complete GM1 power board from shopjimmy.com to save you some stress.
If this task is too technical for you, you can call a family or friend who has the ability to assist you (two heads are better than one).
Regards.
Sep 28, 2011 | Sony Televison & Video
Sony BRAVIA KDL-46V3000 Television goes black shortly after starting and turns off, red light blinks six times continously
Sep 25, 2011 | Sony BRAVIA KDL-46V3000 Television
I have a 2000 Sony KP-53HS10 color rear video projector, Just yesterday it turned off in the middle of watching it and the timer/standby light merely blinks. When I unplug it and replug it in, the same...
Good day!!!
That problem is usually have 2 causes..Its either power supply board or mainboard..
Please take this steps on how to determine the problem:
  1. Open the back cover.
  2. Check the power supply output...It should have 5vdc for the main board..12vdc or 16vdc for the audio and 24vdc for the back-light inverter..
  3. If those 3 voltage supplies have encountered voltage drop...The problem could be on power supply board..
  4. If the power supply output is normal..The problem could be on the main board...
  5. If the problem is power supply you should check if the capacitors are bulged on the top and try to replaced it..If you can't do that you can purchased new power supply board..
  6. If the problem is on main board there is no D.I.Y repair on that so you need to buy a new main board that fits to your TV..
Hope thissolution will be helpful..
Thanks for using fixya...
Jul 05, 2011 | Sony KP-53HS10 TV
I have dvd player by sony. when i try to turn on there is no power on the unit.i check already the power cord,fuse puffing cap every thing is ok.do you have any idea what other parts should icheck.
Hello
Its poser SMPS bard inside is not working properly. This board supplie low tension voltages to the other circuit boards of the device. It is a Switch Mode Power Supply [SMPS]. Normally repairing is not effective to this board. Replace the board as card basis is good. you can bought it from most of the elelctronic spare part shops at your town. There is a number printed on the printed circuit board and it is its identification. Note that number, and buy the same type. OK.
Jun 21, 2011 | Sony DVP-NS51P DVD Player
My sony bravia 46" it wont continues to turn
power supply board is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Take care in solving the problem....
Jun 21, 2011 | Sony BRAVIA KDL-46W4100 46 in. LCD HDTV
My sony kdl 40 u 2530 e is not staring properly. the red led signal blinking 4 times periodically .any idea about the problem? If i turn off tv for hours then it starts for 2 minutes and again the same...
The tv power supply board have problems and the caused,check the tv power supply board have it fixed or services by u or tv tech.most likely those capacitors parts are dying on the tv power supply board like bulging or puffing up.Take the tv aparts,check the tv power supply board that board where the power a/c cord plug into it.Carefully check for capacitors parts for bulging and puffing up on to it tops.Changes all these dying capacitors,tv should be work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 18, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Hey I need to know the sony part number for a "Sony Wega KDF-E50A10 power supply block" in order to buy it and replace it. It seems sony doesn't easely gives you that number so you have to send...
Power supply board part number for Sony KDF-E50A10 is as follows:
A1113732A .... GT BOARD COMPLETE
and if you are asking for ballast power supply board part number, it is as under:
146893611 ... POWER SUPPLY BLOCK
Hope these info will help you.
Thanks.
Jan 12, 2011 | Sony KDF-E50A10 50 in. LCD HDTV
Kde37xs955 sony with sound but no pic
This tv uses two power supplies. Do you hear a high pitch squeal? If so replace the small G power supply. If not make sure fans turn freely and finally change the large power G board. Look for obvious hot spots and swollen caps before buying board as the small bd. is approximately 129.00 and the large even higher. Part numbers on stamp on each board.
Hope this helps: Sam Farrell
Oct 07, 2009 | Sony KDE-37XS955 37 in. Plasma HDTV
KP53HS10 power supply board
you can check here or leave a post that you are looking for one
http://www.tv.quuq.org/forum/index.php
electech
Oct 23, 2008 | Sony KP-53HS10 TV
Sony KP-53HS10 TV Logo
74 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
