DVD player will not load DVD's
  • 734 Answers
Use lens cleaner on the player or wash the dvd disks.
Posted on Feb 09, 2012
Samsung DVD-VR330 unit will not accept a brand new blank DVD-RW disc---machine says 'load' for 20 seconds, before saying 'open', which it does.
The DVD-RW will work at random, some brands will wok better than others. Memprex, Sony, Maxell are 3 I can use sometimes. Once the disk is accepted it must be formatted. Click that and if accepted, first do a record for say 2 minutes to see if ti works.
If it works don't take it out until you're ready to finalize it.
That's mostly so the disk will be readable in other players, should it not want to go back in, you probably lost the record.
Don't write on the back, use a card and keep it in the cover.
Sometimes I can use those disk's in PC for data.
regards
Jan 03, 2013 | Samsung DVD-VR330 VCR and DVD Recorder
Hi I have a portable Logik DVD player 7DualM11 7"
try to use a lens cleaner and look at the close sensor
Oct 28, 2012 | Televison & Video
My Road view in the vehicle was working fine...2 day's ago..it's saying 'bad disc' the disc's are all clean and new..I unplug it.. and still saying the same thing.
see this causes and fix it. God bless you
If your mini DVD player reads "No Disc" after you've loaded the disc, it means the machine isn't reading the DVD. Take the DVD out again and clean it. It's quite possible that the disc is simply dirty and cleaning it will solve the problem immediately.
However if the problem persist test the following:
  1. Bad connections to one or more buttons or sets of buttons.
  2. Microcontroller failed to reset properly.
  3. Missing/bad voltages from power supply.
  4. Defective microcontroller or other logic.
go to the repair shop FOR fix it.
Oct 15, 2012 | Roadview Rd615 DVD Player
PET941D/37 won't load dvd says no disc
Some DVD players are proprietary. See if it will play in other devices. If it is a burned copy the player may not like that brand of DVD.
Apr 23, 2012 | Philips PET941D/37 9 in. Portable DVD...
How to remove "Bad Disc" frtom my Polaroid portable DVD player
The unit has either a dirty optical pickup (it reads the disc) or a bad one--most of the time if bad cheaper to buy a new player.
Apr 18, 2012 | Televison & Video
DVD player not working.
Hello
The changer mechanism should be suspected. It is a skilled work to look into. You have to disassemble it. There are three microswitches inside the mechanism, which give signals of the state of the mechanism to main system control IC. If the loading gear wheels have some problem, these witches won't engage well, and the the whole mechanism will be inoperative.
Mar 04, 2012 | Panasonic Televison & Video
I have an advent DV1418A and my built in dvd player wont work when i put a CLEAN WORKING disc in it says loading then it says "no disc" please help!
The READ head is dirty or damaged...very difficult to get to the back of TV to disassemble DVD player.. clean read (light diode) head with light cleaning fulid or don't take apart & use official cleaning DVD disc. Look on web site for CD\dvd cleaning disc.It looks like a CD but has 'fuzz' or a very thin " rug" on 'read' side of disc.
Aug 08, 2011 | Recoton Advent Advent DV1418A 14 in....
Open & close disc doesn't work. It is open not but I can't close it. Looks like both open and close don't work.
Hello
There are three possibilities for this trouble with this DVD player. The first one is imprper loading function due to loading motor or loading belt trouble. If loading motor is weak [that is its pulling power has gone low] the tray will not close properly into the mechanism, and will not touch the load sensor switch fitted inside the mechanism. If this happens, the main system control IC will detect improper loading and will turn the tray out again to load it properly. Just try to close it without a disc inside the tray, and check whether it closes well. If it does so, or the trouble repeats, change the loading belt first. In most cases, this will retify this type of trouble.
The second one is, bad 'Sled' motor. sled motor is one, which spins the disc inside the mechanism. After proper loading, if the disc do not spin inside it, again the system control IC will sense it, and will eject the tray. The sled motor also is a replacable part.
The third one is, damaged gear wheel in the loading gear section. to detect and repair any of above trouble, you have to open your DVD player, and take the DVD mechanism out of it, and is somewhat semi-skilled work indeed. Check these first. If you want anymore assistance from me, feel free to get be by fixya. If you are somewhat skilled, and have confidence and can follow the diagrams, send your email address to me by FixYa. I'll send the service manual of your DVD player by return mail. All details and disassemblng procedure are in it. OK
Jun 12, 2011 | Samsung DVD-V4600 DVD Player/VCR
Dvd player is not working
Put a disc in the player and note it's position. Close and let it start loading. If it doesn't load, eject the DVD and note it's position. If it hasn't moved iit could be either a broken belt or the drive motor I think> _/)***
Feb 16, 2011 | Samsung DVD-V5500 DVD Player/VCR
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
