Question about Sewing Machines
I AM HAVING TROUBLE WITH THE TENSION ON MY BERNINA 153 AND IDEAS?
    Champion:
  • 243 Answers
Your tension is a balancing act of the upper tension which you can adjust easily and the bobbin tension in the bobbin case. It can be your stitch is not balanced and it is not a tension problem but a burr on the hook or a clearance issue elsewhere. I usually start with a visual inspection using a new size 80 needle. With the presser foot down and the machine properly threaded with good quality normal sewing thread the needle should bend about an 1/8 to 1/4 inch when pulled out the back and to the side. This indicates the upper tension is normal. When adjusting the bobbin thread tension a simple gauge you can make is a wooden clothes pin with three pennies glued to it. You clip the bobbin thread into the pin and hold the bobbin case. Then you adjust the tension such that it just lifts the pin off the table. This crude device is much easier than trying to yo yo the bobbin case and adjust the tension with out dropping the bobbin on the floor.
Posted on Jun 07, 2014
    Novelist:
  • Sewing Machines Expert
  • 166 Answers
Lots of possible issues, but first, check your bobbin case. Take the bobbin out and clean around the inside with a cotton bud. Replace the bobbin and hold the thread and let the bobbin/bobbin case dangle free (take care that the bobbin doesn't slip out of the case. The bobbin case should stay stationery. If you **** the thread upwards , the bobbin should unwaind (this is a very very rough guide). If the bobbin unwinds when just holding the thread stationery, screw in the tension screw on the side of the case a fraction until it doesn't. Conversely if it doesn't unwind when jerked, try unscrewing it slightly. The adjustment is fairly critical and should really be done with a proper gauge and weights. If the bobbin tension is OK, are you sure you're threading the top thread properly ... you should always thread through the pre-tensioner, tension discs and takeup arm with the presser foot lifted - this ensures the thread will lay down between the tension discs properly. Put the presser foot down only when you're threading the needle. If the top tension is too high, try cleaning the tension discs - you can do this fairly simply by turning the tension down to 1, or 2 and with the presser foot up, thread some thick wool through the pre-tensioner and tension discs. Drop the presser foot and drag the wool through slowly - this should clean the fluff and muck out of the discs. Failing the above, you may have a problem elsewhere, such as the check spring or maybe even a problem with the hook/shuttle. In this case, you'd be best to have it checked-out professionally. By the way ... when did you last have your machine serviced ???!!! Also, when did you last remove the hook/shuttle, clean round the hook race firmly with a cotton bud and re-oil it ? You may find the latter will cure your problems ! Good luck and get back to me if I can be of any further help.
Posted on Feb 14, 2012
3 Suggested Answers
  • 8 Answers
SOURCE: bobbin tension
Bobbin Tension Adjustment:
1. Do you have a genuine Bernina bobbin casing and not an Oriental copy? If yes, proceed as follows:
2. To set the bobbin tension, wind a genuine Bernina bobbin with Metrosene thread, type 1161 white thread as your "gaging thread". Load the bobbin case so that the bobbin turns CW. Attach the bobbin case to the hook body from the machine. Wind a couple of revolutions of thread around your index finger with the assembled bobbin case and hook body dangling about 6" to 12" below your finger. Gently and rapidly move your finger back and forth in a "sideways" motion about 1/4" to create a gentle vibration on the bobbin assembly. (Do not shake the bobbin assembly up and down). When the tension is right, the bobbin assembly should fall slowly and as you stop the movement, the assembly should stop.
The adjustment is found on the small screw, holding the flat tension spring against the bobbin case. If the tension is too tight, one must loosen the screw (past) the desired location and always make the adjustment by tightening to the correct position.
There are other checks for tension imbalance and associated problems on the bobbin case that I won't go into here. For further information I can help you later on.
Top Tension Adjustment:
1. The top tension rarely changes and can be depended on throughout the life of that machine providing that tension assembly is maintained occasionally. This can be done by blowing out the tension disks with the presser bar lever in the up position. One can also drag or pull a piece of sized percale or muslin through the disks with the presser bar lever in a down position. Perhaps both methods can be employed.
2. Load the top of the machine with Metrosene 1161 thread in a dissimilar color. I prefer to use a pastel color so as not to create an optical illusion of imbalanced tension.
3. Sew a satin stitch (.25 on the Nova 900) in sized cotton muslin with a thin piece of paper between two plys of fabric. The width should not exceed 4.5mm (standard width on the 900 Nova), however the newer machines have wider stitch widths so one must adjust as specified. The result will be a slight amount of top thread in symmetric lines on both the right and left sides of the satin stitch.
Typically, the top tension will not need adjusting. If the Nova 900 needs adjustment, please ask for additional help.
Posted on Nov 28, 2008
jmgldsmth
  • 2005 Answers
SOURCE: Bernina 66 troulbe with tension
the Berlina uses a reverse hook; from say, singer; over time your hook has slipped and is barely looping the thread: adjust your hook to enter the thread loop about 1/4" before the needle raises to make the stich then readjust the tension on both the bobbin and, the needle
Posted on May 03, 2009
How much does a bernina 153 QE weigh?
Bernina Virtuosa weighs 40Lbs
i found that in less time than it took you to post it.... Thanks Google. you're welcome
Nov 16, 2017 | Bernina Sewing Machines
Can a Bernina Virtuosa 153 still download stitches into its CPS system with Windows 10?
The Virtuoso was pre-Windows 10, so a Windows 10 system will probably have some issues. You might want to contact Bernina. They can tell you if your machine can be upgraded to Win10.
Jun 10, 2017 | Bernina Sewing Machines
Dealer cost for Bernina 153 sewing machines
The BERNINA 153 is an outdated model. As such, any BERNINA 153 you find for sale will almost certainly be used. As a result, markup can vary drastically. This is the case with new machines as well. Every dealer prices their machines independently.
Jul 25, 2015 | Bernina Sewing Machines
Bernina virtuosa 153
When you say cluster you mean the thread is bunching under the fabric. It is usually the top thread that is the problem. Check your top thread tension and make sure the thread is in the take up lever.
Sep 07, 2013 | Sewing Machines
Bobbin thread tangling into knots on my Bernina QE 153
Its possible, refer to your machine manual to adjust the tension. You might need to change your needle to fit the thread you are using.
Feb 01, 2013 | Bernina Virtuosa 150
Trying to connect a USB to the serial port of a Bernina Sewing Machine (Bernina 170). Has been working for a couple of years and has stopped all of a sudden. Does not work on and XP PC, Vista or win 7....
The Dynex adapter does not have any numbers on it. It was the one that is only about a foot in length and has a square center piece that houses the conversion electronics. Standard 9 pin RS-232 male plug on one end and the standard USB plug on the other end. I purchased it within the last month at BestBuy here in Austin TX.
Oct 28, 2010 | Bernina Artista 170
I have a Bernina 153 QE Virtuosa. The bobbin carriage is noisy. When I notice that it is suddenly sounding smoother, I can be sure it has run out of bobbin thread. I have taken it in to my dealer for...
The previous answer is incorrect. The bobbin should turn clockwise in the bobbin case, but then the thread doubles back through the bobbin case tension slot so the end of the thread would be pulling counter clockwise. Are you using genuine Bernina bobbins? Sometimes, generic bobbins do not work as well.
Are you applying a drop of oil to the shuttle/hook area every 8 hours of sewing time? Lack of oil makes my machine noisier. When I notice the sound has changed, I know it's time it needs some TLC.
If you are still having problems with the Bernina technician, try to find another dealer.
Dec 15, 2017 | Sewing Machines
Apr 03, 2009 | Singer 3343 Mechanical Sewing Machine
Bernina 1008 - tension problems
Make sure the presser foot bar is UP before you thread the machine, otherwise the thread doesn't connect propertly with the tension discs. Top thread should reel-off in clockwise direction.
Jan 02, 2009 | Bernina 1008
Sewing Machines Logo
313 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
