Question about Dell Dimension B110 PC Desktop
Sound I only get static when I turn up the volume on my speakers. I have a Dell Dimension B110
  • 21 Answers
Take a pair of head phones and plug it into the jack that your speakers are pluged into. If you have sound coming out of the headphones then the problem is with your speakers. If you continue to get static then it is probably your onboard sound.
Posted on Oct 23, 2008
Dell dimension 1100 b110 drives audio e rede
Hello download the driver here at dell:
http://www.dell.com/support/troubleshooting/us/en/19/Product/dimension-1100
Open the audio folder, and download the driver.
Run the exe program, and reboot after the install is done.
Good luck
Mar 04, 2013 | Dell WF887 - Dell Dimension 1100, B110...
The sound from my Dell B110 becomes garbled when I try to use another application. I've checked and its not a speaker problem. Can you help me?
Sounds like a driver issue.
Go to http://support.dell.com/ and try reinstalling what ever the latest official sound card driver they have for your model.
Some issues, and a reason why people some times end up with the wrong driver:
1) Your Dell might come with several different sound card options.
You might have to open it up to see what card you actually have.
2) Some times the Windows updater will try to (or you manually allow it) upgrade your sound driver with one isn't right.
Why it's best to at least try the one Dell says to use.
Jun 30, 2010 | Dell Dimension B110 PC Desktop
Dimension 9100 PC Desktop: no sound dell dimension 9100...
Make sure physical cables are plugged in correctly from speaker to audio ports. Check audio driver if installed, if not you can download the driver from the dell website:support.dell.com.If driver is propely installed check sound/volume settings, make sure nothing is set to mute...Hope this helps...Cheers!!!
May 17, 2010 | Dell Dimension 9100 PC Desktop
I need to hook speakers up to my Dell B110 computer.
2 things are needed to get sound from your speakers:
1-wiring connecting your speakers to a socket to the back of the computer. (The spot they need to plug in to ON YOUR COMPUTER is a small light green circular socket. The other end of the plug you plug in here should run to one of your speakers *usually the right side speaker-the right speaker should then have separate wiring to connect the left speaker.)
2- A source of power.
Some speakers use their own power source and plug in to a power outlet - your wall. Other types have a USB type plug and plug into a USB port in your computer and that is how THOSE get their power.
Those are the basics of sound setup. Some computers are equipped with more complicated setups such as surround sound, subwoofers, digital and more. Reply if you need more help, I will try to assist you further.
Hope this helps.
Feb 02, 2010 | Dell Dimension™ B110 PC Desktop
Dell B110: no sound after reinstall of Win XP
check device manager see if sound drivers are installed go to dell on internet the drivers are out there
Oct 19, 2009 | Dell Dimension B110 PC Desktop
No matter what I do/change I cannot get any windows sounds/alerts for startup/closedown or Outlook Express email. Tried systemrestore,did not help, tried changes in conrol panel still no sound except more...
asuming your sound card and speakers are working.
From the control panel goto sounds and audio devices, double click,select sounds, under sound scheme select windows default, u can then go down the program events and select the sounds u want.
Sep 02, 2009 | Dell Dimension™ B110 PC Desktop
Dell dimension computer has missing volume icon,
click on start,goto controlpanel,you will see a speaker diagram click on it to increase the volum.but if it is blunt you have to contact your IT person to install the driver you need
Feb 23, 2009 | Dell Dimension 3100 PC Desktop
Scratching (static) noise coming from computer speakers
I foudn this in anther forum:
I have an ASUS motherboard P5E3 Premium. The audio that came with it was the Sound Max audio. I also noticed abnormal sounds coming from the speakers. They included sounds during hard drive activity and also with mouse movement. They were not loud but noticable. I searched all over the web but didn't find the answer. I stumbled across the fix myself. I also have vista-64. In the sound control panel > speaker properties > levels... there is a pc beep slide bar. I noticed that if it is disabled then the abnormal sound went away completely. Problem solved. Hope this helps.
Nov 18, 2008 | Dell Dimension 4600 PC Desktop
Dell Dimension B110 PC Desktop Logo
112 people viewed this question
Alun Cox
