Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
One of two one touch control does'nt work
One of the touch pads is not responsive when buttons are pressed
    Problem Solver:
  • 15 Answers
RESET TO FACTORY DEFAULTS(USE THE MASTER PANEL)THEN REPROGRAM YOU'R OPTIONS!!!!!!!!!!!!
Posted on Nov 06, 2008
Lights are blinking when trying to start frigidaire dishwasher
First, confirm that the display is working. If the display is still working, try pressing some of the touch-pad buttons. If some of the buttons respond correctly but others don't, it is likely that the touch-pad is at fault. (Some manufacturers sell the touch-pad separately from the control panel. Other manufacturers require that you purchase the touch-pad and control panel together. If you cannot replace the touch-pad individually, replace the touch-pad and control panel.) Frigidaire Dishwasher Lights Flashing or Blinking
Oct 28, 2017 | Frigidaire Dishwashers
Dishwasher won't run
It is the touchpad that is faulty.. coz if the control board is faulty the unit may not respond to any button at all.. So just get a new touch pad.. If you want to buy it online.. then let me knnow i will get you the link..
Mar 13, 2008 | Kenmore 16372 / 16374 / 16379 Built-in...
The touch pod on my microwavw 9je635 wont do anything when i press the boutos for timing fuction
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_54_53_pm.gif1_24_2013_5_55_10_pm.jpg
Jan 24, 2013 | GE JE635 Microwave Oven
Left mouse button of Sony VGN-NR38M (nt touch pad) is not working often, and some times need to press hard, please help
mcdevito75 here, Bring laptop to Staples, Best buy for testing, sounds like that key could be hanging up. maybe some sort of oil needed.
Jun 25, 2010 | Sony VAIO VGN-NR385E Laptop
The touchpad (and buttons) stopped working. No response at all. External mouse works fine, so it is not a software issue. Could this be a loose connection? or do these fail after a while? Are the...
Is there a button with a light on it near your touch pad, sometimes these buttons don't have lights? Usually this button is centered on the bottom or top of the touch pad. If there is a button like this, then try pressing it to see if it gives you functionality of the touch pad. If you do have a button like this and it doesn't resolve the problem then there is a possibility that the touch pad has malfunctioned or that the connector has come loose somehow. If you don't have this type of button then look at your keyboard to see if there is a function key for turning off\on the touch pad. Look for the FN key. What color is it? Then look at the keys that have icons in that color. If you find one that you believe is for the keyboard then try pressing that key and the FN key at the same time.
Jun 25, 2010 | Toshiba Satellite M55-S325 Notebook
Touch pad for the oven does not work
eith touch pad or control board un plug the touch pad if it returns the board is bad if it dont the touch pad is
May 27, 2010 | GE Profile JTP56 Electric Double Oven
Display shows E0 F2 after pressing start and cancel at same time. No other buttons work. Stovetop still works.
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 14, 2010 | Whirlpool GY398LXPS Electric Kitchen Range
Nintendo ds lite
First try to recalibrate the screen (start up the DS, and do the following--text from nintendo.com):
  1. Remove all games from the Nintendo DS.
  2. Turn the system on by pressing the POWER button.
  3. Press the A Button when the "Touch the Touch Screen to continue" message appears.
  4. When the main menu appears, use the Control Pad to to place the cursor over the Settings Menu Panel at the bottom of the screen, and press the A Button.
  5. Use the Control Pad to place the cursor over the orange icon that looks like crosshairs (the right-most icon), and press the A Button.
  6. Use the stylus, and tap the red square that appears on the screen. Do this each time the square moves.
    • You must touch the red square precisely at each of the three positions, otherwise the test will continue to re-start.
    • Ifthe touch screen is not responding properly, hold the Nintendo DS at anangle so that you can see where the edges of the Touch Screen meet thehousing of the system. Look around the entire edge of the Touch Screenfor any foreign material (such as crumbs, etc.) that may be wedged inbetween the Touch Screen and the housing of the DS. Foreign material inthis area can cause the Touch Screen to work incorrectly.
If the screen still does not work, you need to buy a new touchscreen. Many vendors sell these, here's an example:
http://store.richspsxparts.com/nidslito.html
You will need a good tri-wing screwdriver to do this repair (don't buy a cheap knockoff--they will strip your screws). Try one like this: http://www.play-asia.com/paOS-13-71-1e-49-en-15-tri_wing-70-1fe.html
Then follow the step by step tutorial at:
http://www.instructables.com/id/Repairing-a-Nintendo-DS-Lite/
Dec 07, 2008 | Nintendo DS Lite Console
Touch pad failed.
Look along the top of the keyboard for an "f key" that shows a "touch pad" icon, IF you see it, press the "function key" (along the bottom of the keyboard) PLUS at the same time the "f key" (that you found along the top) and that should "toggle" the touch pad back on....
Also, IF you plug in a USB mouse that will allow you to move the cursor around--but the USB mouse doesn't fix your touch pad problem.
Hope this helps.
Oct 04, 2008 | Toshiba Satellite A65-S1065 Notebook
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
124 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Craig Butler
Craig Butler
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
