Question about Kenmore Kitchen Ranges
Could you supply on-line a PDF of the schematic for a Spitfire Oven control model # 3 18518545 or it could be SF 5350-L8545-AE
2 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Frigidaire electric range smooth top with no oven function
although you dont have hte model number , that is indeed a correct and valid part number for the control lists for a about $120. since your back there give a quick look at the wiring into the unit, is that ok ??? adn where the burnout is on the control does it appear to have shorted out against the back wall??? perhaps a relay on the board just blew??? i really wouldn't thinkn tha another component was goning to make that go bad, also ck the bake and broil elements for continuity, perhapa wire fell off the element blowing out the control
Posted on Mar 20, 2008
Frigidaire 154568401 Dishwasher Control Board. Can someone tell me what is in position D24 of circuit board (looks like a black resistor possibly), can't find schematic online for Frigidaire 154568401...
"D" normally means diode. I happened to come across your post while searching for the same component, and I can confirm that there is in fact a diode there.
Sep 20, 2013 | Frigidaire 154568401 Dishwasher Control...
My tank is flashing ae on it
Before calling service technician, open following links for Bosch error codes, and contact information, and possible product manual for your model, etc:
http://waterheatertimer.org/Troubleshoot-Bosch-Tankless-water-heater.html
http://waterheatertimer.org/pdf/Bosch_EA_error_code_troubleshooting.pdf
http://waterheatertimer.org/pdf/Bosch-GWH2400ES-error-codes.pdf
http://waterheatertimer.org/pdf/Bosch_A4-E4_error_code_troubleshooting.pdf
Error code AE is not shown, but error EA means "burner flame not recognized by control unit when water is flowing"
There is also error A3 and A3 E3: jumper connection is not correct
Sep 26, 2011 | Bosch Water Heaters
Looking for operating manual for paslode roofing coil nailer 3175RCU and strip nailer 5350/90S
Go to the link below and click on the "downloads" tab. Select the owner's manual which is a PDF file.
http://www.paslode.com/air-nailers/roofers-choice/
I couldn't find a manual for the 5350, but did find a part breakdown and diagram here:
http://www.paslode.com/uploadedFiles/Knowledge_Center/5350%2090S.pdf
Hope this helps,
Dan
Aug 25, 2010 | Air Tools & Compressors
Spitfire controls Clock/Timer on Oven
all a relay is a on off switch. 120v goes into L2in and into a control relay post where it sits sits until 12V energizes the relay coil thus producing an electromagnetic effect which draws the relay contact to a closed position thus placing the 120v from L2in to the 120v L2 out post this voltage then goes on to the oven heating element.
Circuit board voltages which are 16V are derived from L1 which comes in as 120v goes through a step down transformer and gets converted to 16 vac, the voltage then goes through a bridge rectifier which turns the voltage to DC the
DC voltage is routed to the various electronic components, op-amp, microprocessor, etc.
Sep 02, 2009 | Kenmore 24 in. 17462 / 17464 / 17469...
AE Code on Sharp SF2025, What means?
exposure lamp or exposure fuse
Jun 08, 2009 | Sharp SF 2020 Copier
Door on GE JTP18 oven does not close tightly.
Not sure if this link will work, but give this a try
http://claimworks.servicepower.com/mfgltr/I404/RC/Wall%20Oven%20Repair%2011-4.pdf
There is a recall on the oven door for a few models
Safety Recall GE Wall Oven Models Included in the Recall
Brand Model Numbers Must Begin With Serial Numbers Must Begin With GE® and GE Profile™ JCT915, JT912, JT915, JT952, JT955, JT965, JT980*, JTP20, JTP25, JTP28, JTP48, JTP50, JTP86 TD, VD, ZD, AF, DF, FF, GF, HF, LF, MF, RF, SF, TF, VF, ZF GE Monogram® ZET3058, ZET938, ZET958 TD, VD, ZD, AF, DF, FF, GF, HF, LF, MF, RF, SF, TF, VF, ZF Kenmore
(All model numbers start with 911) 4771, 4775, 4781, 4904, 4905, 4923*
* Lower Oven Only 2T, 2V, 2Z, 3A, 3D, 3F, 3G, 3H, 3L, 3M, 3R, 3S, 3T, 3V, 3Z
and that link shows the door and hinge. Recall info at
http://www.geappliances.com/products/recall/wall_oven_08/
May 31, 2009 | GE JTP20 Electric Single Oven
Epson Powerlite 5350- reset lamp timer
5350:reset the lamp timer
1,While simultaneously holding down MENU and Help on the control panel
2,While simultaneously holding down MENU and UP on the control panel
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry
Lampdeng Limited
Feb 18, 2009 | Epson ELPLP09 Projector Lamp for PowerLite...
Mar 20, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Kitchen Ranges Logo
57 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
