Question about Maytag MVWC7ESWW Washer
My maytag centennial model number mvwc7esww will fill with water but then stops and does not continue with the rest of the cycles
The washer will fill with water but will not comtinue with any of the cycles just fills with water and turns off
  • 20 Answers
SOURCE: Maytag Atlantis MAV6200AWW Washer Problem?
is your drain hose at the top of the washer .is the water just runing out is it being pump out
Posted on Feb 20, 2009
SOURCE: Maytag Top loading Washer, fills but won't stop
there is a small tubing about 12 inches or so that connect from the water level dail to the tub of the washer. sometimes the clamp on there gets loose and that interfers with the communication. try changing the tubing and or just tighting the clamps. you will need to lift the top of the washer off to get to it.
hope this helps
Posted on Mar 17, 2009
beltronic205
  • 1461 Answers
SOURCE: Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Posted on Oct 02, 2009
  • 256 Answers
SOURCE: I just purchased a Maytag Centennial washer ..it
There may be a water level/pressure switch that will accommodate your washer. However, if you install it, I am certain that during the normal warranty period, if you need service, the manufacturer will probably void your warranty if they notice the alteration!
Contact an appliance service company.
Posted on Feb 19, 2010
SOURCE: MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code "oe",
if the water continues to fill even with power off, and you have to manually shut in off at the wall valve, the 3-way inlet valve is stuck open. you have to replace it. $90
Posted on Mar 12, 2010
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
Not operating correctly Sometimes doesnt fill all the way Sometimes doesnt go through the cycles correctly Somtimes it doesnt spin out correctly clothes still wet What needs to be replaced
Model number would be helpful just so I know what type of Centennial washer we are talking about...
If it's what I think it is, Here is a diagnostic guide to get error codes that may help to figure out the problem:
Maytag Centennial Washer Diagnostic Guide
My guess is the tub sensor...
Apr 23, 2015 | Maytag Centennial 3.2 cu. ft. SuperSize...
My washer want spin run water want its Maytag centennial commercial technology model number mvwc7esww it run water for a seond
the pressure switch has failed or its vacuum isnt good
so its failed to detect water in a timely manner
so i would check any of the pumps traps and filters
the cold water inlet filter etc
it will be something simple
Feb 07, 2015 | Maytag Washing Machines
I have a maytag centennial washer MVWC400XWO it is 3 years old. The washer has stopped after the initial wash cycle leaving the cloths wet in a tub full of water. The washer will not go to the spin/drain...
For saftey the lid lock and lid down switch must be activated before the machine can advance to the next cycle. This has been the sequence for all top loaders..
Check the switch for the lid it is likely defective.
Make sure that the power is removed.
Simple repair by a qualified technician.
Hope this helps?
Jun 14, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Washer immediately goes into wash cycle when filling with water on initial start.At the end of the spin cycle ,washer dumps water back in to drum.Also,it's not getting the detergent out of clothes. Maytag...
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 26, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Oct 02, 2009 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag MVWC7ESWW Washer Logo
119 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
