Question about DCS WOSD-230SS Stainless Steel Electric Double Oven
F7 alarm My oven occasionally will ding loudly, and the screen will portray the message 'F7'. Pressing buttons is innefective, and the beeping goes on interminably. My only solution is turning off the breaker for the oven. any clues? tips? solutions?
    Problem Solver:
  • 12 Answers
F7 stands for a faulty touch pad, faulty clock or both. Usually it's the touch pad. Most manufacturers recommend replacing both of the components. First, because they make more money that way, and second, it's the easiest (although more expensive) way to fix this problem. If you'd rather try and save some $$$, you can perform the following test and hopefully identify which of the two components needs to be replaced. The test... Disconnect the power to the oven before performing any repairs. Something triggers the clock to display F7 error code. You can unplug the touch pad from the clock and see if F7 comes back on. If it does, the clock is bad. If it does not, the touch pad is bad. Hope this helps, APP tech http://www.AppliancePartsPros.com
Posted on Aug 08, 2006
My top oven is displaying some kind of error message. First it was F3, now it is F2. a loud ding noise comes with it. Help!!!
I get this, and F7 sometimes, especially after self-cleaning. Was told by a repairman to turn off the power, the breaker in electrical box and leave off. I usually leave off for anywhere from 5 hours to the next morning and then flip the breaker back on. Then it is fine. Happened to me 4 days before Thanksgiving too!
Nov 23, 2010 | DCS (WOTD-227) Double Oven
We had a power outage and when the electricity was restored the oven is displaying an F1 and F7 code and is beeping the alarm, how do i stop this?
Hello, the F1 error code means internal logic failure (monitoring function) it sounds alarm and inhibit cook mode You can fix it by replacing the electronic range control (ERC)
F7 error code means the function key shorted for over 16 seconds, check for something pressing a key or preventing normal release of the key. You can fix it by replacing the electronic range control (ERC) if other component check normal.
Thanks
Jul 14, 2010 | Thermador CM302U Electric Double Oven
I have to turm the oven off at the braker box. it comes on by itself. when I turn it on to cook it will not stay on gos off and beeps. Shows C7 or F7
This is usually a keypad stuck key error, usually caused by a bad keypad or sometimes caused by your control board.
F7 usually means a stuck key on the keypad. I've also seen it caused by a greasey buildup on the keypad connector into the control board. Try pressing each button on the keypad followed by cancel. See if the buttons are registering with the control - should get a beep or some function (execpt up/down buttons need a cook or time function enabled first). If one of the buttons seems inoperative it may be stuck, in which case you probably need a new keypad.
Best Regards, Diana
Jun 15, 2010 | GE JKP20 Electric Single Oven
Double oven. Top is digital. It has started
You have a stuck keypad or a bad electronic oven control. Try pressing all buttons at random several times each to unstick a faulty pad. If that does not work the EOC must be replaced.
Oct 06, 2009 | GE Profile JTP56 Electric Double Oven
I am getting an F7 error message more and more frequently. When the F7 message is on the display, my kepad does not work and I get an annoying beep. When I press "Clear" the F7 and beep will stop until the...
Hi
You don't say what type of GE oven this is so I will advise the following;
On a GE range oven F7 indicates either a function pad button is stuck or the clock on the oven is malfunctioning
On the 99 Range oven F7 indicates a shorted Clear/Off Key due to membrane switch or a shorted control or connector
On the GE XL44 Self Clean Oven F7 is Stuck keypad or control relay malfunction
Hope this helps. Please remember to rate my answer. Thank you.
Jul 07, 2009 | GE Ovens
Alarm on NEFF U1721
It might be the volume control.
Try pressing the minus button a few times. The loudness should cycle between low, medium and high.
Jun 16, 2009 | Neff U1721 Double circotherm Electric Oven
The F7 code appears with a beeping noise. How do I turn off the beep for good.... selecting clear/off only works for a few seconds
Well, F7 error code occures due to
A = Function pad button stuck or
B = Bad clock Unstick button or
Replace Electronic Range Control (ERC)
Replace the ERC there are ten screws 3 on each side and 4 on the control leave the hex screws alone all you need is a phillip screwdriver.
REMEMBER TO SHUT OFF THE POWER FIRST lift and fold out the control panel remove the ribbon cable and remove the four screws that hold the control board . replace control panel in reverse order.
Thanks
May 27, 2009 | GE Built-In 24" Double Electric Wall Oven
Double GE wall oven - F7 code
from repairclinic.com:
F7 A = Function pad button stuck or
It looks like you have a function button pad stuck or a bad clock.
Unstick button or replace electronic range control.
Apr 27, 2009 | GE Ovens
F7 message with beeping
The F7 represents a shorted matrix or start key. To determine whether it's the key panel or control itself, disconnect the ribbon cable of the key panel that goes to the control and power the oven up. If the F7 does not come back, it's the key panel, if it comes back, it's the control..
Jun 09, 2006 | GE JKP15 Electric Single Oven
DCS WOSD-230SS Stainless Steel Electric Double Oven Logo
440 people viewed this question
Top DCS Ovens Experts
Carmen Mikulic
Joyce Nokleby
NOEL
NOEL
Are you a DCS Oven Expert? Answer questions, earn points and help others
