Question about Maytag Kitchen Ranges
Have a maytag range MEP5770AAW that turn off while cooking. gets a F1 code and beeps. also in clean mode. what is this code indicate?
catriver
  • 878 Answers
SOURCE: F1 Error Code on MayTag range
migs, on a Maytag the F1 indicates there is a problem with the touch-pad or control itself. Usually, it's the touch pad. Try killing the power to the range and remove the touch pad ribbon from the control board. Clean it with an eraser. Power back up and see if the error comes back. If it does, remove the ribbon cable again and power up with-out it attached. If the same error still returns, then I would suspect the control board itself. Catriver..post back.
Posted on Jun 05, 2007
Krazytech
  • 725 Answers
SOURCE: Oven Failure Code F1
F1 is a Relay circuit failure . you have a bad relay PCB or wire connection.
to fix your F1 error
92028 RELAY PCB, 105 C
Posted on Aug 25, 2008
  • 338 Answers
SOURCE: I get an "F1" code on my Maytag range.
you need a new temperature probe. its usually located in the upper left hand corner in the rear of the oven.
Posted on Mar 19, 2009
blueextc3221
  • 15935 Answers
SOURCE: oven not working error code F1 and beeping
On ranges where the electronic control and keypad are permanently attached to each other (ie. not separately replaceable) like on your range, a faulty oven sensor or problem in the sensor's wiring circuit can cause that error code on some models. Most oven sensors used these days should read about 1100 ohms when at room temperature.
Here are some juicy pearls of appliantology wisdom from our friends at Maytag for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here’s a simple explanation of what’s going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (1.e., not cooking) mode or
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor gotsta be within spec or it will cause the F1 code. As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode. This is equivalent to 350°F in the oven. The resistance isn’t high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit). The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms. The fault code is generated when this doesn’t happen. Checking the sensor circuit means also checking the harness, harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad. If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously. If the F1 code is given immediately (instead of during or after a heat cycle), remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes, then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner. The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied, the surface material can break down causing shorts. If you’re gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel –don’t spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Most likely culprit: Temp Sensor
CLICK HERE
9e4f6b6.jpg That cylindrical object is the sensor. It's two wires connect to the ERC. You can remove those wires from the ERC and test the resistance with an OhmMeter.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on May 07, 2009
  • 464 Answers
SOURCE: maytag electric range shows F1 error message and
F1 code means a defective touchpad or membrane, usually the touch pad. Here is a simple test that you can do to determine whether the clock or the touchpad are defective when the display reads F1: Disconnect the power to the range
Gain access to the back of the ERC (clock)
Unplug the touchpad ribbon connector from the clock
Make sure everything is clear & will not short out when the power is turned back on to the range. Replace any covers removed to gain access to the ERC.
Turn the power back on to the range
Watch for the F1 and listen for the beepIf you get the F1 and beep, replace the ERC (clock)
If after approx. 60 min. you do not get the F1 fault, replace the touch pad. Note: some ranges incorporate the touchpad and the clock as one part so F1 means a bad clock control.
Posted on Nov 12, 2009
Hii i have kenmore kitchen range and itz givin a F1 error and keep beeping please help me out with this beeping sound is so anyoing
Hello there:
Here is the code and what it means read the code i have provided and what needs to be donte to repair it ok but first here is a thing you can try first unplugthe oven for 1 hr to let the internal memory module reset itself then try it again if you get the same code than here is what is wrong
F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERCplease keep me posted on how this is going so i can assist you more if you need to get parts or some thing else ok
Best regards Mike
Jan 01, 2011 | Kenmore 72002 / 72004 Kitchen Range
Getting beeps and f1 error code after canceling cleaning mode a little early.
Hi dear.According to your explanation,Getting beeps & F1 code meaning: F1
I hope that helps.Thanks.
Sep 03, 2010 | Maytag MER5775Q Electric Kitchen Range
Maytag Oven MEW5530BAW throws error F1 after cleaning the oven using the clean cycle. I had to manually unlock the door and tried to run oven afterwards but it is still throwing the error
  1. Disconnect power to stove
  2. Gain access to the back of the clock (electronic range control or ERC).
  3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  4. Make sure everything is clear and will not short out when power is turned back on.
  5. Turn power back on to stove.
  6. Watch for the F1 and listen for the beep.
  7. If you get the F1 and beep, replace the ERC.
  8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
    NOTE: Some models incorporate the touch pad and the clock as one part.
Importatnt. few of the newer Maytag ranges with a F1 fault code and the problem was the oven temp sensor, check carefully the wires to and from the oven temp sensor!!
Feb 07, 2010 | Kitchen Ranges
I have a maytag oven with f1 and f3 codes what
F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
F3: Open or shorted sensor. The cancel key resets the control and stops the alarm. If fault is still present it will reactivate the alarm when the cook mode is chosen. Correction: Check sensor and wiring for shorted or open circuit.
Nov 09, 2009 | Kitchen Ranges
Maytag Model # MES5770AAB F1 error
Hi was using the oven and as soon as it reached the tempurture i set it to the F1 went on and beeped. I hit cancel and resumed it to see if it would finish cooking and it did. I just dont know what f1-1 means and its almost Thanksgiving. Has anyone found out what F1-1 means??
Setauket mom
Jul 28, 2008 | Maytag MER5770 Electric Kitchen Range
F1-6 Fault Code
This code is in responce to a fault/failure in the lower keypad assembly. It is possible the keypad was bumped.
Maytag Gemini fault codes.
Fault code Suspect area Fault code Suspect area
F0 - 0 None
F1 - 1 Runaway cook upper oven
F1 - 2 Runaway cook lower oven
F1 - 3 Runaway clean upper oven
F1 - 4 Runaway clean lower oven
F1 - 5 Keypad cancel upper
F1 - 6 Keypad cancel lower
F1 - 7 Keypad disconnected
F1 - 8 Keypad shorted
F1 - 9 Slave
Dec 29, 2007 | Maytag MER6769 Gemini Electric Kitchen...
MayTag Stove Model MES5770AAW
Here are the codes for Maytag Ranges:
MAYTAG
Type "C" and "D" Clocks Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Supervisory relay enable shorted (non-cook mode); sounds alarm and inhibits cook mode if alarm fault monitor is always active in non-cook mode, and requires removal of power until serviced. Usually a bad touch pad or clock assembly (also called the ERC). Replace touchpad or ERC F2 Bake/broil/clean temp runaway alarm; sounds alarm and resets control to non-cook mode when bake/broil/clean temp exceeds programmed limits. Usually means a stuck relay. Electric @ 525F (bake), 640F(broil), 900F(clean)
Gas @ 525F (bake), 640F(broil), 900F(clean) F3 Open temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F4 Shorted temp oven temperature sensor; sounds alarm and inhibits cook mode Replace oven temperature sensor F5 Supervisory relay enable open (cook mode); sounds alarm and resets the control to non-cook mode Replace electronic range control (ERC) F5 Missing a/c line cycle detector; displays code (no audible) Unplug appliance for two minutes, should clear problem F7 Function key shorted; too hot at the clock assembly (also called the ERC) or shorted touch pad or clock assembly (also called the ERC) Replace touchpad or ERC F8 Analog/Digital supervisory; sounds alarm to non-cook mode Replace ERC F9 Door latch supervisory (door latched) Unlock door and check switches or clock assembly (also called the ERC) F0 Cancel key supervision Requires the removal of power until serviced. See qualified technician
Dec 04, 2007 | Magic Chef CGS3760 Gas Kitchen Range
MER5730AGW Electric Range
Aug 14, 2007 | Maytag MER5775Q Electric Kitchen Range
Kitchen Ranges Logo
42 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
