Question about Frigidaire FRS23KF7AB Side by Side Refrigerator
Ice maker not working frigidaire model GLH537EHSB6
The ice maker in this side by side fridge freezer quit working a few months ago I purchased a new icemaker unit and installed it thinking this was the problem however still no ice my water outlet works but their is no water going into the icemaker any Ideas
  • 833 Answers
SOURCE: Frigidaire Icemaker not making ice.
That on/off arm...you should be able to move it and it will likely make a small click when the switch goes on or off. That arm controls the ice making. There is also a float, is it working freely? It has a switch too. Ultimately, the water is controlled by a solenoid valve. It may be defective. Many of these units are removable to test the switches with a multimeter. Turn off the water and remove to test. Some parts are available...some parts are by the unit only.
Posted on Dec 24, 2007
fridgetech
  • 473 Answers
SOURCE: New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Posted on Oct 07, 2007
SOURCE: Ice Maker Not Making Ice
frigidaire 20.6 top freezer not getting cold
Posted on Jan 06, 2008
  • 66 Answers
SOURCE: Water leaking from freezer door and ice maker not gettin water
Check the fill tube for the ice maker and make sure it is in the correct place. This sounds like the fill tube has been moved and is running water into the freezer instead of the ice maker. Let me know what you find. I am here to help you.
Posted on Nov 12, 2008
  • 9 Answers
SOURCE: Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
Posted on Apr 02, 2009
Frigidaire frs26h5asb5
Hi Gary,
If your evaporator is not completely frosting over (top to bottom) this normally means the unit doesn't have a proper charge or the compressor can't pump all the freon as it needs to. I would check the charge, this should read "0", if less not enough, if higher than the compressor is failing. I hope this helps.
Aug 17, 2014 | Frigidaire Refrigerators
We have a Pure Source Plus model, no manual as it came with the house we purchased a year ago. Things worked fine then. A few months ago the water pressure lowered and temp changed(became warmer) for the...
the ice maker slows as the tempt in freezer gets warmer . icw cream get softer ect . ck for ice build up in back of freezer and the evap fan motor may be running to slow causing poor air flow . ck these first . mm
Aug 10, 2010 | Frigidaire FRS3R5EMB Side by Side...
Icemaker 3 drawer fridge
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
bmbmm,b
May 27, 2010 | Samsung RS2534 Side by Side Refrigerator
Flashing #4 on temperature display
flashing #4 is a communication error between the control board and the damper assy, usually it is the fault ogf the damper assy but if it is under mfg warranty, replace both, if you need to pay for the parts yourself get the damper first.
Oct 24, 2009 | Frigidaire GLHS36EESB Side by Side...
Ice Maker not making ice in new fridge
make sure the metal bar is in the down position
Apr 16, 2009 | Refrigerators
Ice Maker in Freezer in side-by-side not working
CHeck to make sure your freezer is 0 to 5 degrees. If it is warmer than that the water valve wont open to the ice maker. Have you replaced the water filter?
Nov 15, 2008 | Frigidaire Freezers
Nov 12, 2008 | Frigidaire FRS266ZDSB Side by Side...
Ice maker was installed properly, when you put the arm down it doesn't call for water to fill unit. It doesn't make any kind of noises at all. The water is turned on and all plugs are in there are no kinks in the line but when the arm is truned down for it to call for water nothing happens
The is for a frigidaire refrigerator.Ice maker is all new..
Nov 01, 2007 | Frigidaire 20.6 cu. ft. Top Freezer...
Another Ice Maker Problem
i suspect that repair man got it wrong. ice may be blocking return duct to fridge. worth a chance to turn off for 24 hours with doors open then retry
Jun 14, 2007 | LG LSC26905TT Side by Side Refrigerator
Frigidaire FRS23KF7AB Side by Side Refrigerator Logo
88 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
