Question about Broderbund PrintMaster Gold 16 for PC
When i print envalopes they are not centered - Broderbund PrintMaster Gold 16 for PC
My ibook just has an envalope with a question mark in it can it be fixed bt me with your help please
I am assuming that this question mark appears whenever you try to turn on your computer.
What this means is that your computer doesn't have an operating system installed.
Simply insert Disc 1 that came with your computer, or any Apple Operating System such as Tiger, Leopard, or Snow Leopard into your disc drive. Then turn off your computer.
Turn your computer back on while holding the Option (alt) key and a CD icon should appear. Click that and your computer will now boot from the OS DVD.
Follow the onscreen instructions to re-install an operating system onto your computer.
May 30, 2011 | Apple Computers & Internet
Hpw do i print out a envalope
Without knowing what printer you have, this is a general answer. Most printers allow you to print an envelope through the manual feed. The software you are using (Word, etc) will be used to select the envleope paper size. Key in your information and then print. The program will usually prompt you to insert the envelope and then continue.
Apr 01, 2011 | Office Equipment & Supplies
I have the new galaxy smartphone that kinda looks like the iphone i have a few questionis is there anyway to set it so when i get emails it makes a noise so i know when i do recive it? and also i have a...
Yes there is a way to set email alerts. then env in the corner is telling you that you have an new email. Go to settings hit the sounds and display menu. Hit the menu and it will ask you to choose the sounds you want to use for alerts for emails and txt mms and the phone. you can personlaize the phone to your liking.
Nov 03, 2010 | Samsung Cell Phones
Message folder does not open
try useing the message widget by touching the screen when the scroll bar appears find the orange envalope and click it this should open messages
Sep 21, 2010 | Samsung SGH-S5230 Cell Phone
I cannot uninstall my Lexmark printer model X 4580 because I have to delete print job. How do I do this on my new Macbook/Pro?
You can uninstall printer driver from library folder.
Go to system preferences and delete driver from Library /Printer .
Delete that folder then your printer driver is will uninstalled then reinstall the driver if you want to use it again.
Let me know if you need further assistance.
Thanks for using FixYa.
Feb 20, 2010 | Computers & Internet
I can't recieve or send MMS on my unlocked flip. Phone doesnt even give me the option of MMS anywhere- not in Options, and "Send as MMS" doesnt show up when I hit Menu on one of my pictures. What can I do?
first back up all of your files.then,restore it to factory default.if still not work,upgrade your BB using desktop manager 4.7 and you can download firmware here.http://na.blackberry.com/eng/support/downloads/download_sites.jsp
Jul 24, 2009 | RIM BlackBerry Pearl Flip 8220 Cellular...
All-in-One Prints Off-Centered Photos
just change the settings of printer when printing photos ....go to control panel -->printer and faxes and change there
Jun 20, 2008 | Office Equipment & Supplies
H.P laserjet 4100 series.
Printout a copy of your printer configuration. Press the right-side of the MENU button once, then the right-side of the ITEM button twice, and press the SELECT button once. This will print out a configuration page. In the lower right part of the information on this page, it will give you stats on the Paper Trays and Options. Standard settings on these should be "Default Paper Size: LETTER, Tray 2 (LETTER). If either of these says anything different, I would do a cold-reset on the printer to reset it to factory defaults. If you have a network card installed, you need to pull it out before doing this. To do a cold reset, turn the printer off, then hold down the GO button and turn the printer on. Wait about 5 seconds, then release the GO button. Also, you need to check your print setup on your PC. I am assuming you have a WindowsXP machine. Click START, SETTINGS, PRINTERS&FAXES. Right-click your printer icon and select PROPERTIES. Click the PRINTING PREFERENCES button at the bottom. Click the PAPER tab. Check the boxes at lower left. "Size is should be Letter", "Source is & Type is should both be Auto Select". Click OK, click OK, and exit the Printers Window. Lastly, I would make sure that you have Letter size selected from the application you are trying to print from. Hope this helps.
Feb 26, 2007 | HP LaserJet 4100n Printer
Broderbund PrintMaster Gold 16 for PC Logo
26 people viewed this question
Top Broderbund Computers & Internet Experts
Martin Murray
Alun Cox
Are you a Broderbund Computer and Internet Expert? Answer questions, earn points and help others
