Question about RELIANCE ELECTRIC WATER HEATER
Electric bill issueswill water heater cause electric bill to go up over 300 dollars
50gl, just replace water heater breaker
  • Reliance Master
  • 5,245 Answers
Open following link for steps to isolate reason for higher electric bill.
Problem could be water leak, or cracked element, or new meter was installed.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#skyrocket
Posted on Jun 02, 2012
3 Suggested Answers
  • 9 Answers
SOURCE: 50 gal. Reliance electric hot water w/bottom element problems
Willard when you say it throws the reset button,do you mean the breaker on your fuse box of your home?
If you mean that then yes it could be a bad element.The bottom element takes all the abuse on a electric hot water heater. They can short out,and need to be replaced.
Posted on Dec 01, 2009
SOURCE: Reliance 40 gal hot water heater. Model 54020RS960
Hello Bill The temp stat is a square box clipped in under the elements .Can be replaced in 5 minutes.Need a large flat screwdriver.
Posted on Oct 15, 2010
Why is my hot water heater is using too much power?
It almost sounds as if someone is hooked into your electrical system check for outside cables or extensions cords going into a window or even at the fuse box
Sep 05, 2014 | Water Heaters
Reliance 501 water heater and I cant find a way to turn it DOWN ..the water is scalding
Replace both thermostats and test both elements.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.htmlhttp://waterheatertimer.org/How-to-test-water-heater-element.html
Power is off while doing these repairs.
If water is hot, then you know that electric line and circuit breaker are working correctly.
Apr 21, 2012 | RELIANCE ELECTRIC WATER HEATER
Circuit braker faulty
The following link is step-by-step troubleshoot for water heater electric circuit:
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Link also tells how to test breaker inside main breaker box, and then ends with step-by-step troubleshoot for internal electric water heater parts.
See basic water heater circuit on following link:
http://waterheatertimer.org/240-v-water-heater-circuit.html
If circuit breaker is bad, following link shows how to replace circuit breaker:
http://waterheatertimer.org/How-to-replace-circuit-breaker.html
Jan 11, 2011 | RELIANCE ELECTRIC WATER HEATER
No hot water
Electric water heater can be repaired by homeowner.
Four things can cause NO hot water:
1) ECO red reset button tripped. Remove top cover on water heater, push red reset button on thermostat. Put insulation and cover back over thermostat.
2) Circuit breaker is tripped, circuit breaker bad, or wire loose in breaker box. Turn breaker on-off and listen for crackling or fizzing sound, and burned smell. Test breaker for 220Volts. Test top two screws on upper thermostat to see if water heater has electricity.
3) Bad upper thermostat. Replace upper thermostat.
4) Bad upper element. Test upper element.
Nov 22, 2010 | Reliance WATER HEATER CO #9-40-DKRT 40GAL...
I have a model 71-408 B which just stop heating
If I understand correctly, you have electric water heater.
Heater suddenly stopped heating.
Four things cause sudden loss of water heater.
1) Reset button located under the top cover is tripped > turn off power, remove cover, press reset button > if reset keeps tripping, go to the troubleshooting link shown below.
2) Electric power to heater is interrupted > check circuit breaker > test for voltage > look for loose wire on breaker
3) Upper element burned out > test and replace element
4) Upper thermostat bad > replace upper thermostat
Reset button is best suspect.
Here is a link for complete troubleshoot and homeowner repair of electric water heater:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Nov 19, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Dec 01, 2009 | Reliance & 50gal Electric Water Heater
RELIANCE ELECTRIC WATER HEATER Logo
79 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
