Question about Mitsubishi WS-65907 65" Rear Projection Television
Red and green pinstripes!!!
There are red and green pinstripes covering the picture they went away after about 30 seconds before but now they are there and wont go away noticed some oil coming from the blue lamp. there was a tray under the lamps that cought the small amount of oil. any ideas???
  • 505 Answers
If the fluid hit the circuit boards, the problem has gotten worse. The loss of fluid wont hurt the CRT, but the boards don't like liquids at all. In lucky cases, you can clean up the fluid and it will work again. CAREFUL the fluid is toxic and cancer causing. Clean it safely, wash hands after touching. If cleaning doesn't help, you will need to repair the board and possible re-seal the CRT.
Posted on Dec 07, 2008
Mitsubishi projection T.V
check the lamp first to see if intact or shattered.
Mar 31, 2012 | Mitsubishi Televison & Video
I have a samsung tx-t2782 with red green and blue pinstripe running horizontal across top of screen. not a ground loop and theres no magnetic interference.
hello spins,
If your problem just pinstripe on top of screen , but picture ok (normal in picture), try it to enter the factory mode. In standby position press info-menu-mute-power. Enter to deflection adjustment- choose - vamp (VA) or v shift (VS). Change value data by pressing + (or right cursor) and - (or left cursor) to shift or increasse amp. If it work, your tv will normal.
But its nor working, you should call samsung technician.
Good luck.
Mar 30, 2011 | Samsung SlimFit TX-T2782 HDTV
Picture freeze and pinstrip on the screen
When a Microsoft Xbox 360 console experiences a "general hardware" failure or "core digital" failure, three flashing red lights appear (known as the "Red Ring of Death") around the power button, in lieu of the four green lights indicating normal operation. Warning signs may include freeze-ups, in which the screen has strange, spontaneous graphical problems in the middle of gameplay, such as checkerboard or pinstripe patterns on the screen, the sound is frozen and changed to a strange, static-like sound, and the console only responds to pressing the power button to turn it off. These events may happen once or several times until the general hardware failure occurs, when the user attempts to turn the console on, and the three red lights are seen and the console will not function.
this sounds like it will error e74 which will need a reflow
but dont overheat with a towel as this will cause more problems
Mar 07, 2011 | Microsoft Xbox 360 Console
Two years ago I had the problem of the picture going away and coming back. With no repair that seemed to fix itself. Today after turning the tv on the picture and sound came on within 30 seconds the...
The problem has been there all the time, probably a dry solder joint or a bad chip, thats got worse over time & has now completly failed, its time for either a trip to the tv repair man, or the best option a nice new smart tv, i just bought a 42" for £199 why mess about.
Jul 30, 2017 | Sony KDS55A2000 55" HDTV
No picture, status light flashes yellow
display comes on works 15 seconds no power just leds green
Sep 18, 2009 | Mitsubishi PD-5010 50 in. Plasma...
Mitsubishi WD52527 Pinstripe vertical red lines
Is the set blurry with pinkish color and white lines?
Dec 21, 2007 | Mitsubishi WD52527 52" Projection HDTV
Mitsubishi WS-65907 65" Rear Projection Television Logo
85 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
