Question about Xerox WorkCentre Pro 416 All-In-One Laser Printer
Close duplex unit error
Duplex unit is closed but error persists
  • garyk Feb 08, 2012
    trying to sell unit. a bit embarrassing demo-ing to a purchaser the copy ability when i didn't even get that far. i couldn't get the red flashing light to stop and let me print, i couldn't get this error to go away. even tried leaving the door open and turning machine off, then starting, waiting for error and then closing doors. xerox support said that was the work around.
2 Suggested Answers
wrinaldo
  • 185 Answers
SOURCE: im looking for part# of a paper guide that also
This part you described is sold as part of the Left hand Upper Cover assembly wrinaldo_0.jpg
Also check the black plastic 054K24053 Left Hand Upper Chute assembly, that holds the transfer roller.wrinaldo.jpg
Whit Item, Inc
Posted on Nov 02, 2010
Code 0 d50
Enter in Tech.Rep.mode by pressing Stop - 0 -Stop -1 ,select F code history open the front door and close.If the error code persist pull out the duplex unit and verify the duplex mechanical components.
Nov 03, 2013 | Minolta EP4000/5000 CS/PRO Copier
Tip
Main Error MINOLTA DI 1611, DI 2011 Messages and Their Remedies
PAPER JAM A paper misfeed occurred in the
main unit.
Open the cover at the indicated
location, and then remove the
misfed paper. (“When the Message
(Flashing alternately)
OPEN XXX SIDE COVER
All misfed paper was not removed
from the main unit.
Check the message in the display
for the location of the paper misfeed,
and then remove the misfed paper.
ORIGINAL DOC.JAM A paper misfeed occurred in the
Document Feeder.
from the Automatic Document
Feeder.
Open the Document Feeder Cover
and the Document Feeder, and then
OPEN DOC.FEED COVER
∗REMOVE PAPER IN
BYPASS TRAY∗
Paper is loaded in the Manual
Bypass.
Remove the paper from the Manual
Bypass.
FRONT COVER OPEN The Front Cover of the main unit is
open or not securely closed.
Securely close the Front Cover.
CLOSE FRONT COVER
DUPLEX COVER OPEN The Duplex Unit Cover is open or
Securely close the Duplex Unit
Cover.
CLOSE DUPLEX COVER
DOCUMENT COVER
OPEN
The Document Feeder is lifted up
(while a document is loaded into
it).
Securely close the Document
Feeder.
CLOSE DOCUMENT
COVER
DOC.FEED COVER OPEN The Document Feeder Cover is
open.
Feeder Cover.
CLOSE DOC.FEED
COVER
TONER EMPTY The toner is empty. Copying and
printing cannot be performed.
Replace the toner bottle with a new
one.
SUPPLY TONER
PAPER EMPTY The selected paper tray has run
out of paper.
indicates the paper tray, and
“XXX” indicates the paper size.
Load paper of the specified size into
the specified paper tray.
on Dec 18, 2009 | Office Equipment & Supplies
IT SAYS CLOSE DUPLEXER COVER?
the micro switch in the duplex unit has come loose from slamming duplex unit closed
Feb 09, 2011 | Toshiba e-Studio 350 Copier
13.10.00 error
13.10.00 jam inside lower left door or 13.10.00 jam inside duplexer Description A media jam has occurred in the duplexer area of the printer. Action
  1. Check for stuck media in the paper path around the fuser and duplexer area. (See the paper jam locations in the printer section for further assistance).
  2. Make sure hat the lower left door closes properly.
  3. If this message persists, contact an HP-authorized service or support provider. Click here to go to "Handling persistent messages?? above.
Dec 19, 2010 | HP LaserJet 5200 Printer
When print 13.10.00 error appear
Welcome to fixya,
Hope this helps.
Dec 19, 2010 | HP Hewlett Packard LaserJet 5200 Printer
Ricoh Aficio 2035 wont duplex, displays error message error: Duplex unit is not set. Set it properly
there is a sw on the duplex unit that tells the copier it is closed my guess is that its broke
Nov 04, 2010 | Ricoh Aficio 2035 Copier
1st side cover is open
Hello sir; Are you using duplex unit, check your duplex unit.
Oct 13, 2009 | Konica Minolta Office Equipment & Supplies
Paper Jam Error on Dell 3100cn Laser Printer
Push the side button and open the front cover
Pull out the jammed paper from the duplexer. If jammed paper cannot be found, go to the next step.
Pull up on the belt release levers and rotate the belt unit up
Remove the jammed paper and close the belt unit
Close the front cover
Jan 03, 2009 | Dell 3100cn Laser Printer
Tashiba e-Studio35 Keep getting a close duplex door error message and no door is open
there are three posibilitiesp;
1 The door on the right is not closed properly
2 the door on the Left is not closed
3 the duplexer is not all the way in or there may be a gate inside the duplexer that is in the wrong position ( open duplex and check all flaps and gates are in the correct position)
Dec 12, 2008 | Office Equipment & Supplies
Error Code
I think that is a Duplex error message. The duplex unit is not getting the correct power.
One thing you can try, is to slide the (ADU) duplex unit out and don't push it all the way in. Leave it out about an inch. Then turn the machine on and off. If the machine starts to warm up, but tells you to slide the duplex unit in, then you isolated the problem. Let me know if this works, and we can go from there.
Good luck.
Mac =)
Please always remember to post a feedback and a rating if I have helped you in anyway.
Feb 23, 2008 | Office Equipment & Supplies
Xerox WorkCentre Pro 416 All-In-One Laser Printer Logo
77 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
