Question about Qca Spas Jewel Series Ruby Plus 3 Hot Tub
Not heating higher than 60 - Qca Spas Jewel Series Ruby Plus 3 Hot Tub
    Scholar:
  • 111 Answers
Typically this is a bad heater element.
The water is only reaching 60 because of the friction caused by the heat given off by the pump as the water flows through.
You can have a spa technician test the element but its usually cheaper to replace it.
Posted on Feb 20, 2012
Can my 1999 Cadillac Seville concourse overheat by mixing too much water with antifreeze??
Theoretically yes. Antifreeze has a higher heat capacity than water. Basically, a liter of antifreeze can hold more heat than a liter of water. I dont think it would be enough to cause an overheat though
May 20, 2015 | 1999 Cadillac Seville
Do you have plastic replacement shield for light bulb for GE Exhaust Hood - Model JV347 0XIAA - Serial GS867119C ?
I'm betting 60 watt is much higher than the wattage recommended generating way too much heat in the confined space under the plastic shield. There should be a sticker in the bulb compartment listing the maximum wattage recommended.
Nov 23, 2014 | Heating & Cooling
Ngk spark plug gap chart
usually around .028" - .032"..
n
g
k
r = resistor
b=thread size = 14mm
z
7 = heat range - NGK, the lower the number the hotter the plug. Other mfg. are opposite - higher number=hotter
h = thread length =1/2"
s
-10
These are THE important ones... the rest are mfg. specifics
May 25, 2014 | Mercury Boating
Optiplex replace power supply
Hello Jacey,
Below are the system specs for the power supplies that are installed in each chassis of the GX280 system. You can call the Dell Spare Parts
Department at 1-877-717-3355 or click the link below.
Spare Parts Department
Wattage small form-factor computer: 160 W
small desktop computer: 210 W
small mini-tower computer with processor speeds of 3.2 GHz or lower: 250 W
small mini-tower computer with processor speeds of 3.4 GHz or higher: 305 W Heat dissipation small form-factor computer: 546 BTU/hr
small desktop computer: 717 BTU/hr
small mini-tower computer with processor speeds of 3.2 GHz or lower: 853 BTU/hr
small mini-tower computer with processor speeds of 3.4 GHz or higher: 1041 BTU/hr Voltage fixed-voltage power supply-110 V at 50/60 Hz manual selection and auto-sensing power supplies-90 to 135 V at 50/60 Hz; 180 to 265 V at 50/60 Hz; 100 V at 50/60 Hz for Japanese computers
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Mar 23, 2013 | Dell OptiPlex GX280 PC Desktop
No Heat Passenger Side. I have a 1999 Cadillac Deville. The problem is I can't get heat on the passenger side. Air blows but it is cold. I do have heat on the driver?s side. My car has the spate...
Hello: You have a failed temperature control actuator for the passenger air mix door. Remove the glove box and the close out panel under the dash on the passenger side. You will see two silver rods going from the actuators (mounted on the top and bottom of the heater/a/c programmer) Turn key on (engine off) Turn the a/c heater control on. Go from 60 to 90 or 90 to 60 and watch the rods the one that doesn't move is the failed one. The actuator is held in place by two 7mm screws and one electrical connector. When installing the new actuator have the temp set at 60 when you hook up the linkage. The passenger side set at full cold.
Nov 16, 2010 | 1999 Cadillac DeVille
Air Compressor builds to 60lbs and no higher, does not shut off
the valve plate or the piston damage
wear and tear
take it apart and check
when installing use gasket maker to seal it back
Aug 03, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
I have a 220v 100 amp circuit breaker that feeds a sub-panel. The sub-panel has 3 circuits: a)60 amp Heater (unit 1 in house) b)60 amp A/C (unit 2 in house) c) 40 amp for pool equipment. The 100 amp...
your a/c uses the blower motor from the heater to distribute air check for loose wire connections that will raise amperage and also make sure you have the right size wire to each unit 40 amp should have 8 awg(copper) wire and 60 shouldbe 6 awg i think if the wire is to small=heat= higher amperage
Jul 14, 2009 | Heating & Cooling
The freezer stops working when the room temp drops below 60
Refrigerator operation is controlled by the internal temperature . When there is very little ambient heat available to leak in to cause it to cycle more frequently and there is no door traffic to be a heat source the freezer temperature will increase. Keep the room heated to a higher temperature or remove frozen products is the answer. A small chest type freezer will keep food frozen while you are away and have the heat turned down.
Nov 11, 2008 | Refrigerators
MAXIMUM WATTAGE FOR FAN LIGHTS??????
those bulbs are candelabra type. if they came with the fixture then I wouldn't go to a higher wattage bulb. the sockets are probably bakelite and mounted with the base up so any heat off the lamps would be directed upwards. higher wattage bulbs may shorten the lifespan of the sockets. bakelite is a modified plastic. it won't melt but it will get brittle.
Jan 08, 2007 | Hampton Bay 04379 Madison Avenue Ceiling...
Qca Spas Jewel Series Ruby Plus 3 Hot Tub Logo
Top Qca Spas Garden Experts
Dennis Key
Dennis Key
john h
Are you a Qca Spas Garden Expert? Answer questions, earn points and help others
