Question about Whirlpool Washing Machines
Whirlpool awo/d4505 washing machine showing fault code F11
5 Suggested Answers
  • 61 Answers
SOURCE: whirlpool washer
ok unplug the washer remove the three screws across the bottom front of machine if you have a pedistal willbe between the pedistal and the machine. remove the access panell you will see the drain pump it has a threaded cap faceing the front remove this cap and clean out the lint trap attached clean out and debree in the pump housing you can see. reinstall cap, front cover, plug in and test.
Posted on Jan 20, 2009
  • 1550 Answers
SOURCE: the error F23
This error occurs when heater fails in the unit .
Try this
  1. Unplug power chord to the washing machine .
  2. Check connection to water heater .
  3. Check resistance of heating element .
  4. Check the water temperature sensor and connection to it.
Hope this helps .
Posted on Feb 21, 2009
  • 2501 Answers
SOURCE: the clean water pump is flashing on my whirlpool
There should be a access panel on the front of the machine at floor level.
This will have a filter which you need to clean. This filter is on the input to the pump.
Posted on Feb 03, 2010
TheMobilian
  • 8220 Answers
SOURCE: Machine stopped showing F11 as fault on screen. No
F11 Motor control unit internal failure MCU board failure or broken wire. Check that harness for loose connection to that white box on the left. That is the MCU. Get a tech manual for your machine HERE fe0b7a2.jpg4c1535c.jpg
This might just be a loose connection. The MCU pictured here is the white box on the left and above
The tech sheet is behind the kickplate also and it will give you the data you need for your codes.
Posted on Jun 02, 2010
What does F11 error message stand for on my Whirlpool awo 9565 washing machine?
The F11 fault code indicates a serial communication error between the Machine Control board and the Motor Control board. This can be caused by several different problems.
A failed Machine Control board could be failing to provide the Motor Control board with proper voltage. If this is causing the F11 code, then the Machine Control board would need to be replaced.
The Machine Control board could also be failing to supply proper voltage to the door lock assembly. The Machine Control board would need to be replaced for this failure as well.
Voltage flows from the Machine Control board to the Door Lock Assembly. The Door Lock then energizes and closes the Door Lock MAIN Switch. Voltage flows out of the Door Lock Main Switch to the Motor Control board. So if you have power into the Door Lock Assembly but not out of the Main Door Lock Switch, it will give you an F11. If so, you will need to replace the Door Lock Assembly.
You could have a bad Motor Control board that is causing this failure. A bad wiring connection between the Motor Control board and the Machine Control board could also cause this fault code. A bad wiring connection between the Motor Control board and the drive motor is also a possible failure. A failed drive motor could also cause the F11.
With so many possible causes for this failure, I recommend calling a service technician to diagnose and repair the problem in your washer. If you are able to unplug the washer and check the wiring connections, you may be able to find a loose wire harness connection that is causing the problem. Much of the diagnosis for the potential problems noted above requires live voltage checks. I do not recommend conducting these types of checks yourself. Unless you want to take a chance and replace the Machine Control board and the Door Lock Assembly,
Aug 15, 2014 | Whirlpool Washing Machines
Whirlpool awo 9663 wont start cycle
This can be due to failure of motor components or the control panel as there is no communication for the drive . Check the motor to panel wiring, check the panel for failed component
Jul 05, 2012 | Whirlpool Washing Machines
Hi, I'm a bit new at using the net and posting for
No take the top off and the clip or a giant jubilee will be on the back of the rubber inside the machine not accessable from the door front .
Jan 30, 2012 | Whirlpool Washing Machines
Machine stopped showing F11 as fault on screen. No detail in the book as to cause or solution to this fault. Machine is a whirlpool AWO 10561
Jun 02, 2010 | Washing Machines
The clean water pump is flashing on my whirlpool awo/d4505 washing machine where is the pump and how do i clean it ?
Feb 03, 2010 | Whirlpool Washing Machines
Whirlpool awo/d4505
Change the filter material.
Jan 20, 2009 | Home
Whirlpool washer
Jan 20, 2009 | Whirlpool Washing Machines
Washing Machines Logo
127 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
