Question about Miller Welding Tools
No power to weld or use A/c power outlets
I have no power to weld or no power in my A/C outlets. I have taken a stone to the armature and brushes. They were carboned up but did not solve my problem
  • 169 Answers
You don't say what model welder you have, some Miller welders have 3 slip rings and brushes some have just 2. In either case the next step is to use an ohm meter to check the resistance of the rotor and brush assembly. If this is a 2 slip ring model, take one of the wires off of one of the brushes then measure the resistance between the 2 brush terminals - it should be something between 10 and 100 ohms. If you get an open circuit measure the resistance from one slip ring to the other right at the slip rings - if you now get something other than an open you've got bad brushes (about $10 each to replace),
The 3 slip ring models are similar but have 2 rotor windings - take off the wire from the middle brush and measure from it to each of the ends.
If your rotor and brushes checked out OK you should next check the fuse in the exciter circuit, this will be on the block where the other end of the brush wires go.
If the fuse was good you need to do an excitation test. This is a bit dangerous so be careful. Look at the schematic pasted inside the case and figure out which brush is the positive (+) one. The wires are numbered and so is the schematic so this isn't as hard as it might seem.
Disconnect the wires from both brushes (all 4 wires in the 3 slip ring model) and tape them off so you won't get shocked. Get a 9V battery or make up jumpers that will let you connect the welder battery to the brushes. Start the welder and connect your temporary power supply, measure the AC at the outlets (it should be around 60VAC with a 9V battery) and the DC voltage at the weld terminals (should be above 10V), lastly measure the voltage at the wires you disconnected from the brushes (should be around 70V DC). Disconnect the temporary power supply and shut down the welder.
If you didn't get AC at the outlets and DC at the weld terminals above, something is wrong with the stator in your welder. If you didn't measure any DC on the wires that go to the brushes (most likely thing to happen), you've got something wrong in the exciter circuit. Check the rectifier, the capacitor, the exciter winding in the stator, and lastly the current control board. Older welders will also have the fine current control rheostat in this circuit (look for burned windings on it).
That's about all of the general advice I can give you without knowing more about which welder you have.
Carl
Posted on Dec 02, 2008
Generator I'd on and inside lights but can't get power through outlets, 1973 general motors titlest please help
do you meant the engine runs and the gen instrument panel lights come on but you don't get no power outta the outlets , this is because the "dash lights" are run by engine belt drive alternator on older gen sets if it's a 73 im a bettin it's in need of set of brushes on armature and that needs cleaned up as well cus im sure it's black with carbon dust (should be gold in color), there should be a little door you remove on side of gen head that lets you see armature and brushes
May 19, 2014 | Electrical Supplies
Tip
How to Use A Commutator Stone
A commutator stone is used to remove carbon build up from the commutator of a motor or alternator, which is created from worn brushes. The commutator is the internal part of the motor or alternator that spins and makes contact with the motor or alternator brush.
BE ADVISED: The dust created from cleaning the commutator is a carbon dust. Use caution when removing dust so as not to inhale.
If servicing the motor or alternator without removing from the unit, be sure to disconnect power from the machine.
To remove the carbon build up from the commutator, first remove the brush from the motor or alternator. Insert the commutator stone into the brushes place in the motor or alternator. Apply slight pressure against the commutator stone and by hand, slowly turn the motor or alternator shaft. As you are turning the shaft of the motor or alternator, the commutator stone cleans away the carbon that has built up on the commutator.
Use a vacuum hose to suck out the dust debris or tip the motor/alternator over and allow the carbon dust to fall out.
http://www.sportsmith.net/faq.aspx?did=164A8165-E847-41DB-B83C-36C983B6FA18
on Mar 10, 2015 | Stairmaster Exercise & Fitness
9040 belt sander keeps burning out the carbon brushes
If you are burning or wearing out brushes within days, you may have a problem with the commutator on the armature. The copper ring where the brushes make contact had to be absolutely smooth. If it is pitted or one of the contacts is bent upwards, it will eat brushes as fast as you are indicating. If it is dirty or pitted it may be repairable on a lathe with an armature resurfacing stone. If one or more of the contacts are damaged or bent you will have to replace the armature, they are very rarely repairable.
Jan 30, 2012 | Makita 9404 4'' x 24'' Belt Sander
I have an old 315-11441 Craftsman Drill. I took it apart to fix the switch and in the process something must have shifted in or around the gearing. After putting back together when I power the drill I hear...
With these types of electric motors there is an armature, (the main brain of the motor) it has all the copper wiring wrapped around it and slides between two carbon brushes into the armature housing. If you took out the armature, there is sometimes a very thin peice of metal at the top of the armature which slides into the plastic housing above the armarture and creates a spring loaded "seat" for the armature, if this little shim looking thing fell out, you will need to find the old one. Without this tiny peice of metal the armature in the motor will have play in it causing the brushes to wear to one side or the other prematurely, the brushes have to wear evenly. Sometimes the brushes are spring loaded as well for a self-feed type deal. If these springs are missing the same thing will happen. Also one or both brushes could be in backwards. Check and make sure the brushes (black carbon and rectangular shaped) are positioned to support the spin of the armature. Lord, I hope this helps. I worked with small electronic motors over 15 years ago. I worked at the place for a few months, and didn't think I still remembered everything,
Aug 12, 2010 | Craftsman 3/8" Corded Drill
Only 4, volts out 110v output socket,&8,volts out of240v socket on sincro180ew welde/gen, any suggestions!
check the carbon brushes and the avr if brushless and no avr check capacitor and diodes on the armature
Apr 02, 2010 | Electrical Supplies
Need to replace motor brushes on Kenmore canister vacuum 116.25914503 - Getting lots of arcing at brush ends. Need tear-down steps to get at the brushes.
If you can see the arcing you are likely in the motor housing. The brushes are specific to the motor depending on RPM. Most brushes and motors in Sears units are supplied by AMTEK Lamb. The color on the plastic housing and stamped model # on motor will help identify the correct carbon brush, however new brushes will NOT always solve your problem if the motor is arcing.
If the armature is worn like an apple core or if the lines between segments on the copper commutator are gaping and not parallel you will need a new or rebuilt motor.
If brushes are properly removed there is a tiny flag terminal which will slide out of most brush housings where the wire meets the brush itself. New brushes are best installed after dressing the armature surface with a fine carbarundum seating stone or very fine wet dry sandpaper and then the motor is run in at half speed at reduced voltage.
|There is usually a hold down clamp over each brush to seat it and a lock tab underneath to align the new brush.
Sep 30, 2009 | Vacuums
My Ryobi 10 inch miter saw, model TS 1340 has been working fine for years, now in the last 7 days, I see heavy sparking at the carbon brushes and a drop in power from the saw, there is a strong smell of...
It sounds like the armature has developed an open commutator bar. What did the brushes look like that you took out. But before I assume the worst I would unplug the tool and remove both brushes and with a flas light look into the brush tube while slowly rotating the armature looking for a discoloration or raised bar. If not you might bet by with cleaning the commutator with a special stone for this, you might be able to get one at the repair shop where you bought the brushes. If you want to send me the photo of the arcing it might help on my end. Let me know
Mar 09, 2009 | Ryobi Saws
Miller Big 40 will not weld and has no current at the A/C outlet
open inspection door,which also the fine tuner knob is ,there's a 2x4 size circut board that snaps out with little force to remove,this is the voltage regulator board,look for 4700 ohm resisitor burnt into,tv tech can fix or order new board at $227.00 what i paid.
Jan 23, 2009 | Welding Tools
Good armature maybe needs new brushes
You can replace the carbon brushes and most repair shops should have them. Also tho, the armature could be causing the problem, if you put in new brushs and it still arcs badly, then the armature is bad.
Apr 16, 2008 | Kirby G4 Bagged Upright Vacuum
Sparks from motor when turned on
there's a short circuit on the motor armature.. needs replacement but it can be repaired depending on the problem.
Apr 15, 2008 | Vacuums
Welding Tools Logo
1,142 people viewed this question
Top Miller Welding Tools Experts
Robert Lee
Level 1 Expert
Kory Ronning
hubiam
hubiam
Level 1 Expert
Are you a Miller Welding Tool Expert? Answer questions, earn points and help others
