Question about IBM Computers & Internet
WHERE DOES MY STICK GO IN AN IBM THINKPAD LAPTOP
  • Ric Tutero
    Ric Tutero Feb 09, 2012
    Stick? Are you referring to a USB flash drive or an SD or multimedia card?It will also be helpful if you can post the MODEL of your Thinkpad. Almost every model has a different location for the card slots & USB ports and getting the model can help us locate it.
  • bupandtj
    bupandtj Feb 09, 2012
    I am referring to a USB flash drive where do I find the model number please help
    Thanks
  • IBM Master
  • 32,281 Answers
The model number is located either on the bottom of the right corner of the screen and on the label on the bottom of the laptop and the location and number of USB ports vary with different models.
The USB port is a connector/port that is 12x5 mm in size, some model thinkpad have onlt one USB port and some have 2 USB ports.
The USB ports are usually located at the back or at the sides of the laptop.
The T30 model has 2 USB ports at the back of the laptop located between the LAN and PS2 connectors.
The T40 model has 2 USB ports located at the left side of the laptop.
The A31p model has 2 USB ports located at the back left hand corner of the laptop.
The R32 model has 2 USB ports, one is located at the back left hand corner and the other is located on the left hand side of the laptop.
Posted on Feb 10, 2012
  • 2692 Answers
SOURCE: unlock ibm thinkpad
IF it  is a BIOS password ,Try taking  out the battery and shorting the BIOS terminals then reinstallign the battery or leave it out long enought  for the capasitors and memory chips to loose their charge.  Reinstall the battery and then memory of the pasword wil be no more. BIOS Brainwashing.
Posted on Jan 24, 2009
Geekman
  • 32281 Answers
SOURCE: IBM THINKPAD AUDIO DRIVER
Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model laptop,
Use this link :-
http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download
Posted on Apr 08, 2009
gnkanang
  • 63 Answers
SOURCE: ibm t22 thinkpad laptop error 0175 crc1
Ok hm...
Sounds expensive, I'm afraid!
Here is IBM'smag-glass_10x10.gif explanation of the error codes.
What your machine is telling you is that a chip on your Motherboard is faulty and the only way to repair it is a new system board.
It is probably worth finding out how much IBM would charge you to repair it but I very much doubt you'd get much change from £500.
Posted on Mar 25, 2009
kamal1984
  • 1383 Answers
SOURCE: forget BIOS Password (Laptop - IBM Thinkpad Lenovo R60)
For that you need to reset factory defaults settings for bios.
For reset bios u have to open back side of your laptop then u find motherbord circuit there.
pull cmos cell on motherbord for 15 minute then it reset to defaults.
Also u can reset with jumper settigns read carefully on mother bord there is 1 jumper near cmos cell u read there " bios reset or clear"
It is on 1-2 position right now set it in 2-3 position then power up then all bios settings are reset.
then again set it in 1-2 its original position.
Posted on Jul 29, 2009
parrotheadpc
  • 2600 Answers
SOURCE: I have an IBM Thinkpad R30 laptop. Where can I
Here is the link to your service manual. I do not believe the unit has a "switch", it can be enabled and disabled through the device manager on windows. Control Panel > system > hardware > device Manager, scroll down to network devices and check to see if it is listed and either enable it or disable, whichever you want.
http://download.lenovo.com/ibmdl/pub/pc/pccbbs/mobiles/02r2913.pdf
Posted on Oct 05, 2009
Ibm thinkpad r50 wont start
Remove main battery and power on, next! remove one stick of ram and try again, remove the second piece and return the first one, if still no result! check the power supply that it is putting out the correct voltage, if okay! the DC jack in the laptop is a common issue with bad connections, this is where a professional is needed to assess.
Mar 14, 2012 | IBM ThinkPad R50e Notebook
Where does the stick go in an IBM thinkpad laptop
What do you mean by STICK?
Do you mean the RAM (memory) module/s?
OR USB memory stick?
What is the model of your Thinkpad?
Feb 08, 2012 | IBM Computers & Internet
Ask for Ibm Thinkpad T43 battery Price?
go to : Canada battery on-line shop,sell Laptop battery, Digital Camera Battery (DC ...... Welcome to buy ThinkPad T42, replacement laptop battery for IBM ThinkPad ...
https://www.linkme.com.au/groups/public
Jul 20, 2010 | IBM ThinkPad T42 Notebook
My IBM thinkpad t30 beeps 8 times at me when i go to turn it on and will not start up what is that
Video memory error. The BIOS cannot write to the frame buffer memory on the video card. Since the frame buffer memory is on the video board's memory chips then you will have to replace the entire board.
Mar 01, 2010 | IBM ThinkPad T30 2366 Notebook
It has no network driver to connect to the internet how do I do that
Boot up your Toshiba laptop Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows XP or Vista device drivers for your model computer,
Use this link :-
http://www.ibm.com/products/finder/us/finders?pg=ddfinder&cm_re=other-_-suprcn-_-download There may be one or more driver files for each device, depending upon what device is installed on your IBM, download them all because only one will work with your device but you won't know which one until you install it and it works. Then copy the drivers from the Toshiba to a USB memory stick, then remove the memory stick and boot up the IBM R52 and insert the USB memory stick into the R52's USB port. Click on the USB memory device and double click on each of the device drivers. Each driver file will then expand and copy the driver files onto the C drive under a folder called Drivers. Open this folder to view the various drivers and run the Setup file for each driver.
May 13, 2009 | IBM ThinkPad R52 Notebook
I have ibm T21 laptop, i got 8GB pen drive it is not working
You need to download and install the drivers for your memory stick. You can do this by going to the manufacturers website (who made the stick) and  download the drivers from there.
Jan 07, 2009 | IBM ThinkPad T21 Notebook
Can u help me?
Get your driver here:
http://www-307.ibm.com/pc/support/site.wss/TPAD-MATRIX.html
or more specifically, here:
http://www-307.ibm.com/pc/support/site.wss/MIGR-47TUYM.html
on a computer that has internet access. Put it on a USB memory stick and install it on your laptop.
Jul 02, 2008 | IBM ThinkPad A21m 2628 Notebook
Can't get the cd drawer open
There is a hole in the front of the drive - just stick a paperclip in it to manually eject the cd.
Dec 19, 2007 | IBM ThinkPad 570E Notebook
Computers & Internet Logo
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
