Question about Electrolux 16.8 cu. ft. Upright Freezer Professional E32AF75FPS
Electrolux upright freezer flashing ce
Its flashing and sounding alarm ce
No alarm sounding but red light is flashing?
Warning light (red)
If the temperature warning light (4) lights up, it
indicates that the temperature within the freezer has
reached a level where the safe food storage is no
longer ensured. When the freezer is first switched on, the warning light will stay on until the temperature has dropped to
a safe level for the storage of frozen food.
Temperature acoustic alarm
This appliance incorporates an alarm which gives off
an audible signal whenever the warning light comes
on. This signal can be temporarily stopped by
depressing the push button for fast-freezing (6).
The fast-freezing push button can be released as
soon as the warning light is off.
Open door acoustic alarm
This appliance also incorporates an alarm which
sounds if the door is left open for more than 60
seconds. The signal will be stopped when the door is
closed again.
Dado
Sep 02, 2014 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
My kenmore frostless 16 upright freezer alarms
kenmore elite, alarm kept going on and b flashed on and off. I finaly figured out on bottom of freezer there is a battery door open it and change 9v. thats it,
Jun 05, 2010 | Kenmore 16.7 cu. ft. / 473 liter Upright...
CE flashing in the temp window of upright freezer I can silence the alarm by pushing the reset button but the red light blinks. Inside the freezer the indicator means operational error
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Feb 08, 2010 | Frigidaire 16.7 cu. ft. Upright Freezer...
Freezer model LFFH2067DW2 - shut the door on an extension cord that left the door cracked open overnight. The alarm was on and has not cleared after four hours. How do I clear the alarm?
Hi, It likely will tell you in your owners manual, but if you push & hold the alarm button it should stop after several moments ( I think it may actually be 30-60 sec.) That should reset the alarm. However, if the thermistor senses the temp. to be too warm the alarm will return. Hope that helps, let me know. Good luck.
Nov 12, 2009 | Electrolux 21.0 Cu. Ft. Upright Freezer -...
The alarm button is flashing
-18c is about 0 F. it shold be cold enough to freeze you know what.
you might want to turn the tempture up a little.
Apr 01, 2009 | Bosch 9.1 cu. ft. / 258 liter Upright...
Warning alarm and light
it will do that till temp is reached
Oct 19, 2008 | Zanussi 3.53 cu. ft. / 100 liter Upright...
Flashing power light on Kenmore upright freezer
If the yellow light is flashing it may mean that the 9 volt battery is dead.
On my Kenmore there's a small battery compartment on the bottom right of the unit - under the door.
Aug 10, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Aug 10, 2007 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Electrolux 16.8 cu. ft. Upright Freezer Professional E32AF75FPS Logo
96 people viewed this question
Top Electrolux Freezers Experts
AJMAL KHAN
Dennis Boxerman
Wayne Tolonen
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
