posted by dakos on Aug 04, 2006
hi,
i've bought from ebay one Verge VGA285 as is condition. one ofw the channels is working fine , the other not, when i adjusted the input level the non working channel started but it was like a protected mode because was working for 1 sec then off for 1sec and so long , i've opened the aplifier and i've switched between (left to right channel) the final transistors thinking that one of them if burned but they are fine , when i've tried again to see if it's working i've noticed that the final transistors on the side of the channel that is not working are overheating very fast...any ideea , any schematics for the amplifier?
thank you
Best Solution
posted on Aug 04, 2006
could possible a bad bias resister. easy enough checked with a meter for ohm. also check around the circuit one the side that gets hot see if the transisters farther in are getting hot as well of if they seem out of range on a meter. One thing I have found is if you look carefully at an amplifier stage it is pretty bisymetrical. so use measurements from one side to compare to the other. Sometimes this will give clues.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Verge VGA285 Car Audio Amplifier
Email this problem
Email this problem
This Problem Also Relates To:
Audiovox AMP522A Car Audio Amplifier
Jensen JPA285 Car Audio Amplifier
Kenwood KAC-7251 Car Audio Amplifier
Kenwood KAC-728S Car Audio Amplifier
Kenwood KAC-9103D Car Audio Amplifier
Kenwood KAC-929 Car Audio Amplifier
Kenwood KAC-8403 Car Audio Amplifier
Can you Help with these Car Amplifiers problems?
Repair Service
Find Car Amplifier Repairman Near You:
