Lcd Screen For Laptop
The Computer Boots up fine right to where the login screen is But Its black...I can see that its asking for a login but its just dark? Please Help me out! Thanks
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
Try ,new display adapter, or video card
Posted on Feb 08, 2012
  • 34 Answers
Press Fn + F11 to increase Screen light.
crok41
  • 621 Answers
SOURCE: HP Pavillion dv5-1113us laptop lcd screen
I had same problem with HP DV6000. I ordered a new backlight on Ebay from Hong Kong cost $10 found a video on youtube on how to do it by typing in "replacing dv6000 backlight" apart from soldering a couple of wires was pretty straight forward and took less than an hour. Shop had quoted $400 to do this and fine is now working like new again. Good luck from Scott and please dont forget to vote
Posted on Jul 16, 2010
techworm
  • 56 Answers
SOURCE: video problem
shine alight on the screen to see if you see any Icons if you do change the inverter board if not may be the display.
Posted on Nov 12, 2007
alfi819
  • 65 Answers
SOURCE: lcd monitor dark
You probably need to set contrast, etc, using Fn and an other key (F1 - F12).
Posted on Mar 27, 2009
paul7of9
  • 1189 Answers
SOURCE: Computer turns on and boots up , however, the screen is dark
Hi, hope this will help you with your problem.There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop,” click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors' graphics . 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Click, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. Restart "Computer.” *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click, "Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “Did this solution help?”
Posted on Feb 09, 2010
SOURCE: laptop boots up fine but will get a black screen a...
I fixed a similar problem by doing the following. With your computer on and plugged in, remove the battery. Then press the power button to do a cold boot. Once it's off unplug it and wait about a miniute then plug it back in and restart it w/o the battery in it. Once it is re-booted reinstall the battery. Hope this helps.
Posted on Aug 12, 2010
Cq56-115dx boots to black screen
Your thinking along the right lines, first of all check the laptop using an external monitor, if you get the same problems on an external monitor it is likely to be mainboard/GPU fault. If display is fine on an external monitor I would recommend taking the laptop apart and check the LCD cable is connected correctly as the first port of call. If that doesn't cure your issues I would look at replacing the LCD cable, then maybe the screen.
Mar 18, 2014 | Compaq Presario Notebook
I have a black screen on my computer it boots up good and works fine with a monitor but the screen on the computer remains black all the time
Not sure but try looking in settings that ask you which screen to view, you can have screen on laptop, laptop and monitor or monitor only.
Nov 21, 2013 | HP g4-1107nr 14in Laptop 1.6G4GB 500GB...
White screen
First see if the power on self-test (Fn+ Power) or the LCD BIST (D+Power) will run. The Diags are normally on a blue screen with white test, the LCD BIST is simply 4 Solid Color Screen looking for defects in the LCD panel.
If you hear beeps/windows sounds when the system boots and the LCD BIST test does nothing then the LCD has likely failed and you will need a new one. You can try an external monitor and see if you get video on an external screen.
If you don't then try these steps:
http://www.fixya.com/support/r3581893-how_to_troublehoot_a_portable_compouter_
Jul 17, 2011 | Dell Inspiron 1545 Notebook
Help please, just replaced lid on emachines d620, all went well, just turned it on and screen is completely black. The logo shows very feigntly as it powers up, boots up fine but completely black screen.
It sounds like the cord connecting the lcd screen to the laptops motherboard has been disconnected. You will probably have to disassemble the screen portion of the laptop and reconnect the power wires.
Jun 28, 2011 | Computers & Internet
Acer Aspire 5100 Laptop Screen Works Intermittently
Since you have video with an external monitor your lcd panel is going out.This is not hard to repair only costlyhttp://www.insidemylaptop.com/remove-lcd-screen-replace-inverter-board-acer-aspire-5100-laptop/
Apr 06, 2010 | Acer Aspire 5100 Notebook
1/2 of laptop screen works.......
Unfortunately, you need a new display. This is a failure of the electronics built into the display panel itself. You could hook up an external monitor if you're using the computer at a desk, but for portable operation you'll have to replace the display. Replacements are available online from different sources. Check eBay and do a Google search for your specific model and "replacement lcd". Just be sure that any replacement matches the part number of your original.
To skotkolr: Why not just answer the question? Does it really matter to you that the question was under the wrong heading?
Apr 07, 2009 | Insignia IS-LCDTV32 32 in. Television
Dell 1200 Inspiron OS boot problem
Two things you should try to resolve this issue: -
  • Check that the FN button on the keyboard to switch from the Laptop monitor to external monitor has not been enabled - these are usually 3 state switches (Laptop screen ON, External screen ON, Both ON) it is really easy to accidentally hit this without realizing.
  • If this works there is no need to try the second option.
OR
  • Try booting to safe mode - as the laptop boots up and you see the Bios summary screen depress the F8 button and you should receive a screen containing several options.
  • Select the option to Boot to safe mode.
  • If the laptop boots up ok then login to XP, don't be alarmed at the change in screen resolution.
  • Right-click My Computer on the desktop and select Properties - Hardware - Device manager
  • In the tree-view containing the different hardware select Display Adapters you should see your graphics card in there
  • Right-click and select Scan for Hardware Changes if it is ok the close and reboot as normal
  • If there is a problem here it implies the driver is somehow corrupted and may need re-installing from the disk that came with the laptop.
Nov 15, 2008 | Dell Inspiron 1200 Notebook
Evo n610c black black screen please help
If an external monitor works, then the LCD has failed and needs replaced.
Jul 13, 2008 | Compaq Evo N610C Notebook
Monitor goes black
Sorry to have to tell you this, but this is common in LCD monitors. The reason that it is going black when it boots is for one of two reasons. You either have a bad power supply that powers your LCD or your LCD's backlight is blown. These can be repaired or you can purchase a new one. But if it goes black 9 times out of 10 is because the backlight is bad. These can be repaired!
Nov 26, 2007 | Acer AL1711 17" Flat Panel LCD Monitor
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
