Question about Zanussi Washing Machines
Zanussi jetstream 1400 error e46 - Zanussi Washing Machines
  • frank dwyer Feb 08, 2012
    FILTER WAS CLEAR. NO WATER COMING IN EVENTHOUGH NO PROBLEM WITH TAP PIPE ETC.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
Clean filter and reset washer
Posted on Feb 08, 2012
Water is coming through the tray but there is a buzzing sound & there is not much water. Could there be a blockage with the jet stream feed into the drum of our Zanussi Jet stream 1400 ?
more than likely, the buzzing sound is probably the circ pump struggling. this is very common. first check filter is clear. if it is there is a hose from the circ pump to the top of the tub or to the door seal, make sure that isn't blocked. don't worry ab there not being much water in the machine, these machines don't use much.
Sep 01, 2016 | Zanussi Washing Machines
Spin only on Zanussi Jetstream 1400
no agitation check timer and control board. but more likely culprit is the water pressure switch. Which determines water level and when machine goes into agitation mode?
Sep 26, 2014 | Zanussi Washing Machines
ZANUSSI JETSTREAM, CODE E20 appears with every wash near the end of cycle
E20 is a draining error.
Check the filter.You need to take the filter out, empty it of all lint and replace it. It may have water trapped in already, so get a cloth ready to soak up excess liquid! Also, make sure when you put it back in you have tightened it enough to avoid leaking but not too much that you cannot get it back out
If still the problem persists then the problem is with the draining pump.Replace it and this wont come again
Thank You
Sep 09, 2010 | Zanussi Washing Machines
E90 fault
Blue wiring loom that goes to the front control board from the maim control PCB has bad connection on the user interface.Clean PCB terminals and crimp connector to make connections tighter.if this doesn't work could be user interface fault or main PCB fault.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Sep 02, 2009 | Washing Machines
Error 10 message
Hi
E10 means there is no water getting in to machine.
check water supply if ok then fault will be fill valve.
regards
Mar 07, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi error code 30(model zws 1640s)jetstream time line.
Does the machine drain out water in the beginning of the process ? In case it drains out water: -Check first the filters on the inlet water line. - If problem still exist,test for 115/220V on solenoid tags. Good luck !
Aug 06, 2007 | Zanussi FJS1225W Front Load Washer
Washing Machines Logo
153 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
