SOURCE: my monitor is not working hp pavilion dv2000
Your laptop model is on recall.
http://h10025.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&lang=en&product=1842189&docname=c01300427#c01300427_dv20
Its a loose graphics chip. seems like laptop companies dont ever learn. nVidia is taking the fall now. Before ATI was the problem.
SOURCE: Reformatting an HP Pavilion DV2000
when you put in the windows installation disc and restart your computer you will get a screen where you have the option to delete and reformat any existing disc partitions, choose delete current partition and reformat in NTFS and then you can install windows on newly formatted drive
SOURCE: The hp pavilion dv2000 not booting
You might be still covered under extended warranty, check here
SOURCE: HP Pavilion DV2000 no Display
First pull motherbord from cabinet some times motherboard is grounding with cabienet.
Then pull cmos cell from motherbord for 10 minutes.
Refix RAM memory.
Reconnect ATX power connector to motherboard.
Then check.
If still same issue then open processor fan and processor then clean dust from all place in mothebord.
Then try.
If you still got same then something rong with your ram or motherbord.
Change ram then try.
Pull all card from PCI slot check motherbord only with RAM not even harddisk and other device.
Let me know if you need more assistanse.
Thanks.
SOURCE: hp pavilion dv2000 lights switch on but boot or
Hi
Thank you for your query
Please try the folowing
1) Remove ALL wires and then press and hold the power button in for approx 20 seconds
2) Plug everything back in and then rerty
This may sort the issue out however from what you are descrbing, if there is no boot or display it is highly likely the motherboard and/or the CPU is faulty
I would recommend that you book the PC into a reputable PC repair shop if the above does not work
If this has been useful please leave postive feedback/vote/testimonial - Thank You Again
