Question about Kodak EasyShare C340 Digital Camera
Kodak easy share c 340
After i charge camera on dock and shows full charge, i take it off and it immed. losses charge. what is the prob
  • Frankey252 Nov 05, 2008
    I have tried cleaning all of the contacts (inside the camera and out, and even tried buying a replacement battery, but cannot get the camera to power up.  This was a degenerative problem for the last few months, it would only hold a charge for so long and then conk out, but now it won't power up at all.
  • surajit_naug Nov 08, 2008
    flash not working
  • 903 Answers
Try taking out the batteries, and clean the connectors that the batteries touch, and the ends of the batteries (if recharagable). Sometimes a dirty connector can make the batteries seem that they are dead even if they are rechargable. If the camera works with new disposable batteries but not with the rechargable ones, then you may need to purchase some new rechargable ones.
Posted on Oct 23, 2008
Kodak dx7590 camera dock will not light up
Although you did not mention what Dock you are using, I assume it is the Camera Dock 6000. Is the Dock connected with the power supply? Because only connected to the PC with a USB cable will not be enough. Also the LiIon battery in the camera, should be charged at least once. If the battery is completely empty the dock will have trouble to. The dock can be used to charge your camera. Then the lights should indicate the state of the battery. And the Dock can be used to transfer pictures to the PC. But before that will work correct you have to install the software that came with the camera. (Easy Share software)
Jan 12, 2014 | Kodak EasyShare DX7590 Digital Camera
My Kodak easy share is 5 yrs old. can I charge it without the printer dock as I want to take it overseas?
Depending on which camera model you have, you can use regular (lithium!) AA batteries in these cameras, no need to buy the specialty 2-battery rechargeable pack and use the printer dock to charge. You can go with regular NiMH rechargeable batteries as well.
Mar 10, 2011 | Kodak Cameras
Easy share 340 srial 3 kcgkp9500270
You need to erase the internal memory of the camera. With no card in the camera, go into the menu and find "format"...follow the on-screen instructions.
May 31, 2010 | Kodak EasyShare C340 Digital Camera
Kodak Easy Share Printer dock plus. Original
you're not completely right. Kodak printer docks normally only charge the Kodak KAA2HR battery pack. It not charges normal Ni-MH rechargeable batteries of any brands.
Jan 12, 2010 | Kodak EasyShare Thermal Photo Printer
With my camera on the dock and the dock light is on, the battery light does not come on at all.The camera is turned off. It does not show to be charging or to be charged. No light at all. Nearly new...
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
Feb 19, 2009 | Kodak Z8612 Digital Camera
My Kodak EasyShare DX4530 camera dock not charging batteries.
There was an issue with the 4000 series and the NiCd batteries I remember that had to do with the contacts in the camera.  The charging circuit is in the camera so you have to make sure that the battery contacts are clean, both on the battery and in the camera.
Jan 25, 2009 | Kodak EasyShare DX4530 Digital Camera
Kodak M375
There is no Kodak M375 camera.
But for most of these issues the easiest solution is to remove the camera from the dock. Remove the battery from the camera. Re-install the battery (if you know it's still sufficiently charged) and try to turn the camera on or off. This often re-boots the camera.
Oct 12, 2008 | Kodak EasyShare DX6490 Digital Camera
Kodak easy share g610 printer / charging dock with zd710 camera
Consult the Kodak company or Go to a nearby gadget technicians. I hope it could help you....
May 13, 2017 | Kodak EASYSHARE G610 Thermal Printer
Camera will not charge while on dock
i have akodak easy share cant find a chaeger can i get one
Dec 24, 2007 | Kodak EasyShare CX4230 Digital Camera
Docking and charging digital camera
Not sure if this will help, but you might try removing the batteries from camera, then see if it responds on the dock, if so it is most likely bad battery. That battery should be easy enough to find at locally. You might wanna try the Interactive Troubleshooter on Kodak's site. http://www.kodak.com/global/en/service/products/ekn030483.jhtml?pq-path=6861
Jul 28, 2007 | Kodak Dock Plus Bluetooth Thermal Printer
Kodak EasyShare C340 Digital Camera Logo
80 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
