Question about Sony FD Trinitron WEGA XBRKV-40XBR800 40" TV
40 INCH SONY XBR PICTURE TUBE WITH SOUND BUT NO PICTURE
  • 6 Answers
SOURCE: SONY 36 XBR SOUND BUT NO PICTURE
posible solution is adjust the screen to low.also check the trimer if it is working.check the resistor in the heater line...weng
Posted on Dec 29, 2007
  • 4 Answers
SOURCE: sony XBR 40" tube 2003 purchased
Soouds like the High Voltage board. It can be repaired. I did mine for liek $16. Ordered to chips soldered them in and viola, TV.
Scott
scott@vzandt.net
Posted on Aug 27, 2008
  • 5603 Answers
SOURCE: Picture color is distorted.
Try turning off power and let set cool completely. Then turn back on. Letting it cool complety re-arms the autmatic degaussing circuit. It may take several cycles to completly clear it up.
Posted on Jul 25, 2009
  • 178 Answers
SOURCE: No picture and buzzing sound on Sony XBR Wega
Is the bulb light flashing ? - Sony's bulb light is very accurate in telling you if the bulb is bad. The buzzing sound could be from the balist trying to strike the lamp. You also may want to open the lamp door and see if the bulb is shattered.
Posted on Sep 02, 2009
asnowman
  • 788 Answers
SOURCE: 36inch sony xbr,mint cond,working perfect until
These sets have a weakness when moved.
You will need to check the area around the flyback transformer. (A large black transformer with a red wire out of the top). Look under the circuit board and near where the cabinet front and back meet. You will most likely find a crack in the circuit board, but never fear, the traces are very large in this area and can be repaired. After you gently remove the coating and expose the copper trace, you can solder a small wire were the crack is and you should be good to go.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Posted on Dec 01, 2009
SONY KDL-40XBR6 12 BLINKS (I HAVE NO IMAGE, BUT SOUND)
I would be more inclined to check the power supply board first. Check the outputs to make sure the voltage is correct getting to the inverter. You should be able to pull up specs online if the expected voltages are not already printed on the board itself.
Apr 01, 2014 | Sony Bravia XBR KDL-40XBR6 40-Inch 1080p...
Sony BRAVIA XBR KDL-46XBR4 HDTV LCD Television
you need to replace defective capacitors in the power supply of the tv
Jan 05, 2013 | Sony Bravia XBR-Series KDL-46XBR4 46-Inch...
Program directv remote
It may or may not program for the sony set, Sony uses many different remote codes.
Sep 01, 2012 | Sony Bravia XBR KDL-40XBR6 40-Inch 1080p...
Sony XBR 40" tube tv.
Failure of the vertical deflection module/circuit. The tv will have to be opened, the vertical deflection circuit found and replaced.
Definitely a job for a pro - the circuit is going to be extremely difficult to extract. The repair will cost you about $200: $20 for a new circuit and $90 per hour for the 2 hour job.
Sep 03, 2011 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Aug 01, 2009 | Sony Grand WEGA KF60XBR800 60" Rear...
Jul 25, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Sony XBR 40" tube 2003 purchased
Scott
scott@vzandt.net
Jun 02, 2008 | Sony KV-36XBR400 36" TV
Sony 57 Inch XBR 2001
I don't have the XBR, but on my sony, using the cable box remote, I had to go into menu/display/etc. and mark the 1080i, 720p, and 480i settings. you usually get a "if you can see this" comment if your tv accepts the settings. for standard tv i set the screen to normal, and when the upper channels go to HD, they auto go to full screen. Sounds like you are using the component cable, and also make sure you are on the video port of remote, and the the TV input. The above worked for mine. Hope it helps.
Dec 04, 2007 | Sony KP-57XBR10 57" Rear Projection...
Oct 30, 2007 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Sony FD Trinitron WEGA XBRKV-40XBR800 40" TV Logo
69 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
