Question about Toro Garden
Ride on mower blows white smoke when blades engaged
joboo1
  • 257 Answers
SOURCE: Craftsman 18.5 riding mower when I engage the
Hi Jeff, If you look at the deck, one or more of those pulleys is a tensioner, It pushes against the belt to tighten it, The rest of the pulleys can be identified by the fact that they only have a bolt through the middle, whereas the tensioner is mounted on an adjustable arm with a slot to allow adjustment. It should also be the only one that the belt doesn't go around the pully it just pushes on one side.If the tensioner arm is all the way to the end of the slot, the belt is streched and will need replaced but sounds like it may have come loose. Some of these decks also have a spring on the tensioner arm and those come off from a stick or other debris. Check it out and if you have a problem let me know and I will try to come up with a diagram. If your mower is that new there should be a belt diagram on the deck. i will need a model number of the deck or mower for that. Good luck!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Mar 29, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
wadembly
  • 448 Answers
SOURCE: Craftsman riding mower blades will not engage
maybe the safty switch under seat might be starting to go out if that switch doesn't work the blades wont come on at all for safety
Posted on Jun 28, 2009
mowerman1857
  • 389 Answers
SOURCE: When I put the mower in gear, or engage the
Sounds like the seat safety switch is shorted or worn out. You can test it with a short length (about 6") of wire. Strip about a half inch from each end of the wire, unplug the connector under the seat and plug your "jumper" wire in to each side of the connector (NOT the seat switch) If it now works, replace the seat switch
Posted on Sep 16, 2009
Testimonial: "Thanks. The problem was the seat safety switch was loose and not fully engaged. When I plugged it in correctly, everything worked!!! Thanks again."
  • 9 Answers
SOURCE: i have a bolens 38 inch riding mower. it cranked
did you try depressing the clutch to disengage everything regardless of being in neutral? and it sounds like a pulley bearing went bad.try to spin the pulley with your hand and see if it moves.take the belt off to the mower deck and that should keep them from turning when you go to start it.
Posted on Feb 21, 2010
Testimonial: "thanks. at least i can crank it and get it to a trailer instead of pushing it. i really appreciate it.......cb"
Lawn mower blowing smoke
You are burning oil. This usually is from a leaky gasket. Go to ebay and find kiddie boutiques. They sell the best quality cheapest new tecumseh gaskets
Sep 27, 2014 | Garden
When I engage the blades, I smell and see blue smoke, so disengaged the blade
Its not the drive belt. You have a bearing or etc. out.
I just have problem. The spindle bearing was bad.
Oct 01, 2012 | John Deere 22HP VTwin 48" Riding Mower
Everytime I engage blades and start to cut white smoke blows out front of engine. Is mototr blown? cheaper to fix or replace?
The muffler discharges out the front as you would see it from the seat. The white smoke in the exhaust when loaded indicateds that you may be having trouble with oil and vacuum inside the engine. At best requires partial disassembly. This may get expensive. I recommend careful consideration regarding the decision to try to repair or to choose to replace.
I hope this helps.
Jul 27, 2011 | Yard Machines 155 Torque Briggs Stratton...
White smoke coming out of mower
It sounds as though you are losing power (electrical power); see if charging the battery fully allows it to run longer or if charging the battery helps.
Jul 15, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Smoking Craftsman Riding Mower
1st thing, check your dipstick up inside the cap part of it and make sure the O'ring is there and in good condition.
2nd, make certain when you put it back on that you get it on straight and firmly seated. They will only seat one way properly the other way creates a leak into the crankcase and causes oil consumption and smoking. You should be able to tell if it has been improperly installed by an excessive amount of oily dirt accumulated around the threaded area of the cap
Sep 15, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Engine only runs at low idle and smokes
So now, without the blades engaged, it smokes and then dies?
In your first description it sounded like the engine was under a strain. Overfilling with oil could produce a strain, but since it ran ok until you said you engaged the blades, I would have to ask if the blades themselves, were causing the strain. Sometimes if you cut wet grass, the clippings stick to your underside of the deck and can really build up. Also some rope, wire or twine would around the spindles could creat one. Check this out...
Now, with the "smoke" issue (I'm assuming a blue smoke from burning oil) I'm inclined to think your rings aren't compressing any longer and you're burning oil. You might be in for a rebuild... I hope not.
Aug 31, 2009 | Husqvarna 19.5hp 46" Yard Tractor
White smoke and blade won't engage
Sounds like a low compression problem. The piston rings have most likely failed and oil is seeping past them and burning, thus the white smoke. An engine needs three things to run...Spark, Compression, and Fuel. Just take the mower back as it is still probably under warranty. Mike. Rate 100% please.
Jul 01, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
190 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
