Question about Dell Inspiron 1501 Notebook
Sticky keys The letters I type don't stay up with my typing.
  • mjsouth Oct 30, 2008
    When I hit a key on the keyboard it is a second or two before it apprears on the screen. Hope this helps. Thanks a lot.
  • 275 Answers
Care to discribe the issue in a better way?
i am sorry did not understand what exactly is happening
Posted on Oct 30, 2008
  • Ali Khambati
    Ali Khambati Oct 31, 2008
    okie i understand that ... when u type something it takes time to show on screen ...
    go to control panel> keyboards > speed > it has an option for speed rate of letters u can make it by the icon and make sure its on fast
Password reset on dell 518
Reset Your Windows Password Using the Command Prompt
1. Boot your computer using your Windows installation disc.
2. Wait for the setup files to load, and select your language. Click Next.
3. Click the Repair your computer link on the Install Windows screen.
4. Select the operating system to repair, and note the drive letter on which the OS is installed (it is probably C: or D:). Click Next.
5. Click Command Prompt at the bottom of the list of recovery tools.
Now you need to overwrite the Sticky Keys executable with the Command Prompt executable. Sticky Keys is an accessibility feature that allows a user to tap the Shift, Ctrl, Alt, or Windows key once to achieve the same effect as holding the key down. Ordinarily, tapping Shift five times activates Sticky Keys--but with this trick, you are going to make tapping Shift five times activate the Windows Command Prompt instead.
The instructions below use drive letter C: as an example. If your operating system is installed on another drive, replace C: with the appropriate drive letter.
1. In the Command Prompt window, type copy c:\windows\system32\sethc.exe c:\ and press Enter.
2. Type copy /y c:\windows\system32\cmd.exe c:\windows\system32\sethc.exe and press Enter.
3. Exit the Command Prompt and reboot the computer. At the login screen, tap Shift five times. The Command Prompt will pop up.
4. Type net user username password, replacing username with your username and password with a new password.
5. Exit the Command Prompt, and log in using your new password.
To prevent another user from exploiting the same trick to reset your password, you can restore Sticky Keys as follows:
1. Step through the instructions above to boot the PC using your Windows installation disc, open the recovery tools, and launch the Command Prompt.
2. Type copy /y c:\sethc.exe c:\windows\system32\sethc.exe and press Enter.
3. Exit the Command Prompt and reboot the computer. Pressing Shift five times will now activate Sticky Keys instead of the Command Prompt. Store your Windows installation disc in a secure location.
May 03, 2014 | Dell Inspiron 530 Desktop Computer
Turning off my green keys on HP pavilion desktop keyboard?
How to turn off Sticky Keys: disable the Ease of Access feature
Tip: use the Windows Ease of Access Center
How to turn off Sticky Keys: what are Sticky Keys and why turn them off?
Sticky Keys is a Windows Ease of Access feature that makes it possible to use keyboard shortcuts or type capital letters without needing to press more than one key at once. Normally, you'd hold down the Shift key while pressing a letter to type a capital, or hold down the Ctrl key while pressing 'S' to save a document. It's even trickier if you want to use a shortcut such as Ctrl-Alt-Del or Ctrl-Shift-Esc.
With Sticky Keys, you can press Ctrl, Shift or Alt, let go and then press another key - Windows will interpret this as pressing two keys together. You should also hear a beep if you have speakers connected.
That's great if you're disabled and can't press two keys at once, but what if you want to disable Sticky Keys?
How to turn off Sticky Keys in Windows 8
You can't press Shift another five times. Instead, you need to bring up the Start menu (or Start screen in Windows 8) by pressing the Windows key. Now type "ease of access" and click on Ease of Access in the list of results.
If you're using Windows 8, you need to click on the Ease of Access Keyboard settings result, and then it's a simple case of sliding the Sticky Keys toggle to 'off'.
If this does not help you. Let us know the below details to understand the issue bettery.
What is the OS?
What do you mean by hot keys? ex.......
Sep 02, 2012 | HP (395366-001) Keyboard
My laptop is entering more than one character at a time when typing in my password for example its adding additional letters how can i turn this off
seems like something is ring with the keyboard, try an external keyboard, if the issue is still the same this will be a windows issue, once in windows tap on the shift key 5 times this will either deactivate sticky keys or ask you to activate sticky keys.
If it is not a sticky key setting issue then the problem most likely will be Hardware, did any liquid spill on your keyboard previously causing the key to malfunction causing the key to type extra characters?
If none then possible this is a faulty keyboard on the machine.
Sep 10, 2011 | Computers & Internet
When i try to type two of the same letter my keyboard wont write the second letter. a pop up came up and i'm unsure how but i accidently hit yes.
you turned on sticky keys or some windows accessibility features.
Jun 30, 2011 | Computers & Internet
I held the shift key down longer than normal and now am unable to type double letters, backspace, or use arrows.
Restart your computer to turn off the "Sticky Keys" accessibility tool.
Use "sticky keys" if you have limited finger dexterity capability or limited motor skills.
For example, you can press CTRL and then ALT and then DELETE,
rather than having to press all THREE keys at the same time.
Apr 09, 2011 | Compaq Keyboard
When i on my computer it type nonstoply this letter \.when i type some thing it stops
u may have a sticky key.check if the key is in question stuck down
Feb 11, 2011 | ASUS 90-A4C1K1000 Keyboard
I have a dell inspiron 1501 and my FN key is active all the time, so when I type any letter that have a number with it the number is what comes up not the letter, so in order for me to type the actual...
You may have (accidentally) activated the Windows "Accessibility" tools. One of the tools is "Sticky Keys". For example, people with impaired motor-skills can press CTRL, and then press ALT, and then press DELETE, to achieve the 'CTRL-ALT-DELETE' key-sequence.
Turn off "Sticky Keys". Or, restart your computer to start without the "Accessibility" tools.
Oct 22, 2010 | Computers & Internet
My Inspiron 1505 will not type the letters h,t,c and e in e-mail only unless I put on the cap lock then hit the shift key. Any ideas what the problem is?
The potential is you have what's known as "sticky keys" turned on. Check accessibility options and make certain it is turned off. Those letters are used as shortcuts for various actions in different email programs- I suspect sticky keys is the problem.
Oct 02, 2010 | Dell Inspiron E1505 Notebook
My letter 'e' is sticky and I have to press extra hard - do the individual keys come out of a laptop Acer 5720 please
Hello, If your laptop keys are sticky and its causing problem typing, you can replace just the one key which is sticky, visit this site
I got two of my laptop keys fixed by this company and im satisfied by their service, they send all the underneath fixings with the key , so its easy to fix , hope this helps you :)
Jan 05, 2010 | Acer NSK8458AN Keyboard
When typing the letter n 2 letters print nm
Sounds like your keys are sticking together. Pop the affected keys off with a flat tip screw driver and remove any debris. If there is something sticky, remove with Q-Tip soaked in rubbing alcohol. Then replace keys.
Jul 19, 2009 | Sony Computers & Internet
Dell Inspiron 1501 Notebook Logo
70 people viewed this question
Alun Cox
