Question about Kicker 05C104 Car Subwoofer
Ground wire i have ground wiring problem from yesterday. i check all the outlets .don't know what to do & how to fix it...............
    Problem Solver:
  • 14 Answers
Make sure that the wire is grounded to your frame, or any other unpainted metal surface. if no unpainted surface is available, get some sandpaper, and 2 gold, copper, or silver washers (in order from best connection to worst) from your local hardware store. find a bolt near the amp, that wont make something fall apart. take the bolt out, and sand the paint off underneath it. make sure to get all the paint and primer off. put the 2 washers on the bolt, and put the ground wire between the washers. then tighten the bolt nice and tight. this will give you the best possible ground connection, without running the ground to the neg of the battery. if this still doesnt work, try running the ground to the neg of the battery. if that doesnt work, then you should have your amp looked at. hope this helps
Posted on May 01, 2009
Yesterday by juicer kicked of the kitchen breaker? Twice.
You may just be overloading the circuit. Easiest correction - unplug something else that's running (or turn off a light) on the same circuit and see if the breaker still shuts off.
But wait - also important - was there any burning smell? If so, this is dangerous. It's a short circuit that occurs when a "hot" wire (black) touches another hot wire or touches a "neutral" wire (white) in one of your outlets. You should not use that outlet and have an electrician look at it. Or it could be a ground fault (similar to the short circuit - when a hot wire touches the ground wire on the side of a metal outlet box which is connected to the ground wire. For either of these, you need an electrician.
Apr 05, 2017 | Juicers
Connect blue wire light ground
I think you have to connect the black to the white if you don't have any other wires.
Jul 27, 2013 | Minka Aire F803-TL Artemis? Fan
I am trying to install the light/outlet combo into my 80 year old bathroom. The outlet box only has 1 black wire and 1 white wire which come down from the top of the other wires are available
If the wiring is BX cable (that is, the two wires are inside a flexible metal jacket that looks like a fat coil spring) (you would see the end of the metal jacket inside the box), and the box is metal, then the box is already grounded and you can install a jumper wire from the box to the ground terminal on the outlet. You might have to add a screw to the box. But if you don't have a grounded box, then the right thing to do is to rewire it all the way back to the main panel. On the other hand, if you simply skip the ground wire, the switch and outlet will work but they will be a little more dangerous than before because now you will have what LOOKS like a grounded outlet, but isn't. By the way, you should be using a ground fault protected outlet in a bathroom.
Good luck, be safe.
Oct 10, 2012 | Cooper Wiring Devices Combination Switch &...
I am trying to fix a dryer wall outlet but the colors are black white and naked copper I don't know which is neutral and ground. White can u please help
I don't know where you live (what Country) But usually the the bare copper is ground in the USA. or if there is a green it is a ground. The black and whites are where you get your power. I can not nor will I tell you with out being there and having a meter. You should call a local electrician and ask him if white is hot or black is hot. Thats all I can say. I dont want to tell you wrong if someone wired it backwards. Call a qualified electrician. You don't want to mess with electricity if you do not know what you are doing. CALL AN ELECTRICIAN AND ASK
Apr 10, 2012 | Dryers
My power outlet stopped working in my 2008 jeep patriot after I plugged in an air compressor
Use a testlight to check for power at the outlet. Clip or hold the black lead of tester to the side of the lighter case, and touch the probe to the very back of the socket(don't touch the sides with probe, or you will blow the fuse.) With key on, testlight should be brightly lit. If no power there, check the ground wire and power wire to the socket.
Dec 31, 2011 | Jeep Patriot Cars & Trucks
Neither lighter outlet works on my 01 allero, just bought it used so don't know if and when they did work! Help..need to charge stuff!!
You have options there. First use a test light and probe the center terminal of the outlet. If it has power, check the ground on the socket. If no power, check the fuse. (if you have no diagram, probe all of them and replace any that don't have power at both ends with the key on, and replace any that are blown. the one you are looking for is usually 20 or 25 amp). Your other option is to create a new circuit. To do that, find an open fuse port that only has power with the key on. attach a wire (close to 14 gauge is best) to a spade connector and plug it into the fuse connection that has power. Run that wire to the connector at the rear of the accessory port (lighter housing center post). If you do that, make sure you install an accessory fuse holder in that wire that is rated at 25 amps. I use that method to install additional ports so you don't have to plug in one of those "octopus outlets" in a working power outlet. Only difference is that I also install a new lighter housing into the dash. That requires a new hole in the dash or console and a ground wire to the outside of the housing.
Oct 01, 2011 | 2001 Oldsmobile Alero
Burns wire off at feed rollers When begging to
You are missing the inlet or the outlet wire guide, these parts will help to insulate the wire from ground. What's the brand and model of your machine???
Sep 09, 2011 | Lincoln Electric Welding Tools
Electrical conntection for Chandelier Tried to send problem twice before, but don't know if you recvd it. My problem is the wiring for install. outlet box has 2/blk/2wht/1red....fixture has...
use the same as when you took it down, white is neutral, red is power from switch, green is ground, look at wiring for new chandelier instructions should tell you what goes where, if al else fails get an electrician to wire for you
Sep 06, 2011 | Home
Instrument panel on 1994 Bravada comes on and off. If you smack the side sometimes it will come on so I know it's not the bulbs. I took off the panel and the connectors are all clean but there's...
BAD GROUND- caused by moisture in cabin- corroding the GROUND terminal /strap/connector. Check the connectors up to the panel? YUP. Tear apart dash. GOOD LUCK!!
Aug 09, 2011 | 1994 Oldsmobile Bravada
I have a 240 volt air compressor. I have had it wired with a three prong dryer cord wich consists of a white, black and green wire. There is only a place on the compressor for these 3 wires. The problem I...
You are going to have to abandon one of the wires and probably change your outlet to match your cord. I would abandon the red wire. You will have to do this in the breaker panel itself. If you are not familiar or comfortable working in this panel then don`t. If you are then only connect the white and black wires to the breaker that feeds your outlet and your green will be your ground which should already be connected to the ground bar. It is possible that the black and red wires are already connected to the breaker and the white to the neutral bar (this is the way it should have been wired for four wires). If this is the case just remove the white wire and tape it off and don`t use it in your new outlet.
Feb 15, 2011 | Fahrenheat Electric Hydronic Baseboard...
Kicker 05C104 Car Subwoofer Logo
59 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
