Question about Canon EOS 40D Digital Camera
Can not play back image. Box with yellow ? (question mark)
My mother-in-law purchased a new Canon EOS-40D and has only used it a few times. After shooting her daughters wedding her pictures were copied to my wife's laptop. However the orginal pictures were not deleted from the CF card. When she went to view her pictures on her camera she received an error message on some of the pictures (at one point 10 in a row) that stated "Can not play back image". There was also a bow with a yellow "?" (question mark). What would cause this and how would she resolve this issue?
  • Canon Master
  • 5,412 Answers
Possibly corruption of the card - if you are sure the images are backed up, then format the card.
Posted on May 17, 2017
  • 48 Answers
SOURCE: my canon EOS 40D camera
Could be a number of things causing this, is it just one card or any memory card that it will not format.
If only the one card, I would suggest it is the memory card at fault or that it has been formated as FAT32 on a computer, cameras do not like this setting so you could try formating in the FAT format and then re try formating in the camera.
If it is any card that it will not format then you may have bent CF pins in the camera, try taking the card out and looking down the slot with a bright light, you will see all of the gold pins pointing at you, if you see any bent over then that is your problem, you could try rebending them yourself if you are handy, but normally pays to get a tech to replace the pin set, which luckly on the canons is on a seperate board so is relatively cheap to replace.
Posted on Nov 17, 2008
SGNath
  • 170 Answers
SOURCE: eos 40d error 99
Error 99 can mean many things. Have you installed the latest firmware for the camera (version 1.1.1)? If you don't have, download it here (for equipment purchased in USA or Puerto Rico):
http://web.canon.jp/imaging/eosd/eos40d/eos40d-firmware-e.html
If you have the latest firmware, try this:
  1. Switch off the camera and remove the CF card and battery
  2. Keep the camera idle for 30 min
  3. Clean all the contacts of the camera (battery contacts, lens contacts etc) with an eraser. Do this keeping the camera facing down so that no debris fall into the camera.
  4. Attach the lens and insert the battery.
  5. Switch on the camera
  6. Insert the CF card
  7. If the error persists, format the card again
  8. If this does not work, try using another CF card.
Posted on Feb 06, 2009
  • 37 Answers
SOURCE: Canon EOS 350D CF memory card won't go into slot
It sounds like you have some bent pins in the card slot. Take it to a reputable camera repair and they can look and tell you for sure.
Posted on May 12, 2009
  • 34 Answers
SOURCE: My canon EOS 40D with 18 - 55 IS , when continuous
Slow down after taking 6 RAW files ...
A RAW file is Approx. 12.4MB.
The memory usage is approx. 74,4 MB
The internal memory (Buffer) has a size for up to 75 JPEG compressed images.
Which size has the smallest jpg?
JPEG/Small: Approx. 1.2MB (1,936 x 1,288)
The Buffer is approx. 80 MB.
The data are calculated under Canons laboratory conditions.
The maximum Burst (the 17 shoots) means that the camera is writing to the card and the buffer is full. Than the cam will stopping taking pictures.
Which kind of Card do you use?
Check the spec for the card (write speed) and maybe buy a faster card.
Posted on Jun 07, 2009
  • 4090 Answers
SOURCE: Canon 40D and 64Gb CF Card
What i find is that the larger the card the slower the write recovery in taking pictures. If you are an action photographer this is a pain as things happen fast . To have the camera take so long to recover from a write leaves you open to losing some excellent shots. So my rule of thumb is use smaller value cards. If you are just a happy shots photographer then this probably doesn't really matter.
Thanks for using Fixya
Posted on Sep 15, 2009
Why are no photos being displayed on screen after shooting?
PDF]PDF QuickGuide to EOS Live View Features
https://www.learn.usa.canon.com/.../CDLC_EOSLiveView_Q...
Canon Inc.Canon EOS cameras when used in their Live View mode. ... directly onto the sensor, which in turn displays the image ... EOS 40D, 5D Mark II, EOS-1D Mark III, EOS-1Ds Mark III, ... Mark III do not offer movie options. ... to produce a fixed screenbrightness, or Exposure .... settings for the following camera menu options:.
Canon Knowledge Center - Changing the AF Mode to Use ...
https://support.usa.canon.com/kb/index?page=content&id=ART134415
Nov 4, 2015 - ID : 8201360200 _ EN _ 1. Solution ... While the Live View image isdisplayed, you can press the < AF?????????DRIVE &gt; button to select the AF mode on the setting screen displayed. 9. ... If focus is not achieved, the AF point will turn orange. .... Shooting movies with the default settings (EOS 5D Mark III)
Dec 25, 2015 | Canon EOS-1D Mark III Body Only Digital...
Focusing issues with canon 40D when taking sports shots
I believe I have found my problem. I think my image stablizer on my lens is on the brink! I turn it off and got good pictures.
Jun 03, 2009 | Canon EOS 40D Digital Camera
40D not communicating with EOS utility
open device manager, connect camera, it will be seen briefly with yellow triangle and exclamation mark. open it up and uninstall.
Disconnect camera and close windows down. Restart windows, connect camera and switch on, windows will then find it and install driver. Took me hours to figure this one out
Mar 11, 2009 | Canon EOS 40D Digital Camera
Switched to MAC - have EOS40D and SX100 - will not download SX100
Yes, you need to install the SX100 driver software as well. I wouldn't overwrite older versions of the Canon software, though, so do a selective install if you can.
Feb 21, 2009 | Canon PowerShot SX100 IS Digital Camera
Digital Camera Purchase
Here is a page that compares the Canon 40D and 50D side by side
Because the 50D is the newer model it is quite a bit more expensive than the 40D. However, the reviews don't find that the quality has improved very much. Unless the 50D has a feature you simply must have, the 40D is going to be a much better value.
Neither has video capabilities. If you want the best video capabilities as well as top-quality still photos, without spending tens or hundreds of thousands of dollars, take a look at the 5D Mark II. This camera has amazing video capabilities for the price (under $3k). Most camera stores have a long waiting list so if you want this model you will have to put your name on a list and wait at least a few weeks before you get your camera.
Dec 21, 2008 | Nikon D70s Digital Camera
Brand new Canon 40D camera - Get Err 06
You need to return it to the place of purchase as a defective model and get them to exchange it for a new unit, or else send it in for warranty repair.
Dec 06, 2008 | Canon EOS 40D Digital Camera
Canon eos 40d Soft image on playback screen
I think this might be a firmware issue.www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=139&modelid=17779#DownloadDetailAct
Here is a link to Canon's website for your 40D there you will find the latest firmware version for your camera. Version 2.0.0 which includes 1.0.8 . In 1.0.8 item #3 in the list of changes it states repairs a phenomenon where reviewed images appear unnatural.
Jul 29, 2008 | Canon EOS 40D Digital Camera
My Canon 40D can't handle bright yellow and reds. It blurs the detail and overly saturates the subject (flower close-ups) - so that the bright red poppy is overly saturated and lacks detail even though...
By the way are these RAW images? What type of lense are you actually using, check this
EOS-1Ds Mark III EOS-1D Mark III EOS-1D Mark II N
EOS-1Ds Mark II EOS-1D Mark II EOS-1Ds
EOS-1D EOS 5D EOS 40D
EOS 30D EOS DIGITAL REBEL XSi/EOS 450D EOS DIGITAL REBEL XTi/EOS 400D DIGITAL
Compatible Lenses
EF 14mm f/2.8L USM EF 28-70mm f/2.8L USM
EF 14mm f/2.8L II USM EF 28-135mm f/3.5-5.6 IS USM
EF 20mm f/2.8 USM EF 28-200mm f/3.5-5.6
EF 24mm f/1.4L USM EF 28-200mm f/3.5-5.6 USM
EF 28mm f/1.8 USM EF 28-300mm f/3.5-5.6L IS USM
EF 35mm f/1.4L USM EF 70-200mm f/2.8L USM
EF 50mm f/1.2L USM EF 70-200mm f/4L USM
EF 50mm f/1.4 USM EF 70-200mm f/2.8L IS USM
EF 85mm f/1.2L USM EF 70-200mm f/4L IS USM
EF 85mm f/1.2L II USM EF 100-400mm f/4.5-5.6L IS USM
EF 100mm f/2.8 Macro USM EF-S 60mm f/2.8 Macro USM
EF 135mm f/2L USM EF-S 10-22mm f/3.5-4.5 USM
EF 180mm f/3.5L Macro USM EF-S 17-55mm f/2.8 IS USM
EF 200mm f/2.8L USM EF-S 17-85mm f/4-5.6 USM
EF 200mm f/2.8L II USM EF-S 18-55mm f/3.5-5.6
EF 16-35mm f/2.8L USM EF-S 18-55mm f/3.5-5.6 II
EF 16-35mm f/2.8L II USM EF-S 18-55mm f/3.5-5.6 USM
EF 17-35mm f/2.8L USM EF-S 18-55mm f/3.5-5.6 II USM
EF 17-40mm f/4L USM EF-S 18-55mm f/3.5-5.6 IS
EF 24-70mm f/2.8L USM EF-S 55-250mm f/4-5.6 IS
EF 24-105mm f/4L IS USM -
Jun 30, 2008 | Canon Cameras
Canon EOS 40D Digital Camera Logo
189 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
