Question about Dishwashers
Ge potscrubber dishwasher will not drain properly
  • 4 more comments
  • Anonymous Oct 23, 2008
    leaking water
  • eseale Jan 20, 2009
    My 8 year old GE Potscrubber will not drain.  It goes through the whole cycle and dries as well but there is water in the bottom and the dishes all have junk/debris on them.
  • GlenRent Jan 24, 2009
    I have the same problem with my GE Potscrubber II. I took off the back screen and played with the drain but it did not seem clogged, nor did it seem to matter when I moved the plug around.
    I might have to pull the whole unit out and pull it apart but would love to avoid that if I could.
    Anyone have some advice?
  • s_fuerth Mar 14, 2009
    I have the same problem as described above.
    Pump is working because I can get it to drain into a pail after disconnecting from sink drain
  • Anonymous Apr 05, 2009
    will not drain
  • Anonymous Apr 18, 2009
    GE potscrubber dishwasher will not drain
Had the same problem with my dishwasher. Took it appart thinking that something was plugging the drain but there wasn't anything. Turns out the cylinoid that has the hook coming out of it to control the flap for the ejection of the water is broken. When looking at your pump, you should see a small flapper valve on the exterior of the pump hooked up to a small cylinoid that when accivated flips a flap in the pump to eject the water out of it instead of letting it circulate in the unit. This is an easy part to replace, but for me, hard to find since my potscrubber is so old. Hopefully your units are newer and you can find this part at your local appliance shop.
Posted on Oct 12, 2009
localwonder
  • 6784 Answers
SOURCE: Potscrubber 900 Dishwasher won't drain
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer
Replace if defective (note: uncommon problem).
Posted on Aug 27, 2009
  • 1891 Answers
SOURCE: My old GE potscrubber 700 dishwasher stopped working
moter has probably locked up TAKE FRONT LOWER PANEL OFF AND YOU CAN ROTATE ROTOR/ if itis not free and rotates easly then the motor has failed / mm
Posted on Dec 07, 2009
  • 35 Answers
SOURCE: dishwasher not draining fully
Remove and replace the motor / pump assy. Call technician. Big Job
Posted on Dec 09, 2007
SOURCE: GE Potscrubber 1000 with temperature sensor GSD1000M20-Water in bottom at end of cycle
Does it sound like it is trying to drain or is it just silent?
Posted on Jul 27, 2008
heatman101
  • 43501 Answers
SOURCE: my GE Potscrubber dishwasher will not drain
Here is a tip I wrote that will help[ you with your problem..
http://www.fixya.com/support/r4078724-dishwasher_problems_water_will_not_drain
Heatman101
Posted on Feb 22, 2010
My question is regarding my dishwahing machine GE Potscrubber 1150 who does'not drain.
There are several reasons why this can happen. The dishwasher only has one pump, so if the dishes are getting washed and the water sprays around properly, you know the pump is working. Draining is controlled by a solenoid. To test that the part of the timer that controls draining, use an electrical tester (AC volts) to verify that power is activating the solenoid when you expect the dishwasher to drain - this is when you hear the "clunk" when it starts to drain. If electricity is going to the solenoid at the proper time, but the solenoid doesn't activate, it could be burned out. To test, disconnect the two wires from the solenoid and use an electrical meter set to Ohms to test that it shows a value higher than "0". If it stays at 0, the solenoid needs replacement. If that isn't the problem, there may be blockage somewhere (drain pipes, hose, valve, bottom of the dishwasher). I have attached a link for parts that can break or clog and prevent draining.
May 19, 2015 | GE Dishwashers
Ge potscrubber 940 dishwasher
My GE potscrubber, model GSH942 (very old) is not working, as one of its part was fumed (burned). Though the dishwasher is old, it was doing perfect job. Kindly advise whether there is any hope to save it. picture of damaged part is attached.
664ecbc5-d293-4bf8-9a26-d4eb60b56c88.jpg 3afc25c1-d149-45c7-8546-1d01d256fcd6.jpg 2ffcde17-d805-44d2-865f-843483703dd0.jpg
Aug 10, 2013 | Dishwashers
Is water suppose to stay in the sump pump of a ge potscrubber dishwasher. The water drains except in the very bottom where I guess the pump is. There is lots of mildew and I have lots of grit on my...
Yes water does stay in the sump all the time. This is normal.
Try running a cycle with a cup of Vinegar or Baking Soda in the dishwasher.
Also check to make sure that your drain line (under the sink) is higher than the sink drain and not allowing some sink drain seepage back into the dishwasher.
Jun 20, 2010 | GE 24 in. GSD2230Z Built-in Dishwasher
Burning smell coming from dishwasher caustic to nose. GE Potscrubber 900. Nothing on element upon inspection. Smell more at beginning of wash cycle or when using the pot scrubber button
Older GE's had problem with drain coils over heating
Remove the bottem front plate and the coil will be on the left side of the moter and activate when the drain cycles, check that
Apr 22, 2010 | GE 24 in. GSD2000Z Built-in Dishwasher
Does not cleans dishes
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 11, 2009 | GE Dishwashers
2. Broken belt
3. Pump
4. Drain solenoid
5. Motor
6. Timer
Aug 27, 2009 | Dishwashers
Jul 08, 2008 | Dishwashers
Dishwasher not draining fully
Dec 02, 2007 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
3,306 people viewed this question
Top Dishwashers Experts
Mike Cairns
Mike Cairns
