Question about Toshiba Satellite M305D-S4830 Notebook
What dose my f12 key do - Toshiba Satellite M305D-S4830 Notebook
Got an Acer 4050 from ebay and it goes straight to enter boot password
can you click on f12 before it goes to boot password?
The F12 Boot Menu allows you to choose which device that you would like to boot the computer's Operating System from by pressing the F12 key during the computer's Power On Self Test, or POST process. Some notebook and netbook models have the F12 Boot Menu disabled by default.
If this sounds like your problem then try this:
If this sounds like
To enable the F12 Boot Menu:
  1. Restart the computer.
  2. Press the F2 key to enter computer's BIOS Setup during Power-On Self-Test, or POST, process while the Acer logo is being displayed.
  3. Press the Right Arrow key to select Main
  4. Select F12 Boot Menu
  5. Press the Enter key
  6. Select Enabled
  7. Press the Enter key
  8. Press the F10 key and then press the Enter key to save the changes and restart the computer.
Note: Not all Acer notebooks or netbooks have the F12 Boot Menu feature. Computers that do not have the F12 Boot Menu feature will not be able to enable the feature within the BIOS. I hope this works for you if not, then the problem is obviously not the boot menu. Go to Acer support for more help
Aug 30, 2014 | Computers & Internet
Tip
Sylvania Netbook F11 and F12 Key Function
You may need to download and install the latest BIOS update for this function to work, but here it the key combos for both the F11 and F12 function keys.
With the latest BIOS update, Fn+Z should be F11 and Fn+X should be F12.
BIOS Updates may be downloaded at:
http://www.sylvanianetbooks.com/
on May 15, 2011 | Computers & Internet
Upgraded from window 7 to windows 8 a few months ago was working ok now when turn on laptop blue screen and say recovery your pc needs to be repaired a required isn't connected or can't be...
Restart the computer HOLD the keys FN+ f11 or f12 and look for to restore the factory default, and click.
or use the keys f8 for troubleshooting
God bless you
Oct 01, 2013 | Toshiba satellite c660
No beep and no screen my f
this a problem with the POST, you must go to the shop repair computer.
However RUN the software diagnostic coming with the computer restart and HOLD the key CTRL +f11 or f12 and use it
God bless you
Jun 04, 2013 | Fujitsu Siemens FUJ:CA01007-0930 Laptop AC...
Can't connect my HP G70-460 to my samsung tv
Have you selected PC or HDMI as your input source on the TV? Have you hit the FN Function Key on the laptop + the corresponding F1 thru F12 key that displays the image on the TV?
Press and Hold the FN key then hit the correct F1 thru F12 key that displays on the tv. The correct F1 thru F12 key will probably have LCD/CRT on it or it might have the icon of a display.
Apr 01, 2012 | HP Computers & Internet
Inspiron N7010 touchpad is disabled, how to enable?
Inspiron N7010
Key to the right of the F12 key
Press the Touchpad Disable/Enable key,
(the key is located to the right of the <F12> key). Inspiron N7010
Inspiron N7010 Key to the right of the F12 key
Press the Touchpad Disable/Enable key,(the key is located to the right of the <F12> key).
Sep 23, 2011 | Dell Inspiron 1545 Notebook
How do I use the F9, F10, F11 and F12 keys?
Some Gateway (desktop) computers do not have the dedicated F9, F10, F11 and F12 keys, but for a Gateway laptop, those four keys have dual functions for media control (which is the default use) or as Function keys. However, to use F-9 through F12 as Function keys, you must first press the Fn Key and then press the desired F-key. The Fn key is the second key to the right of the spacebar. To launch the Gateway Recovery process during start-up, you must press Alt+Fn+F10.
Aug 19, 2011 | Gateway Computers & Internet
How can I access scroll lock on my hp-g62 laptop.
Hi
Its normally on the top left of the key board
mine is on the F12 key
sometimes we have to press FN+F12 if the F12 dont work on its own
Feb 19, 2011 | Computers & Internet
How to reattach the F12 key on my Sony Vaio laptop. My cat scratched my F12 key off of the laptop. There is a little white plastic square frame loose on top of the key.Pressing the key pad down on top of...
Sounds like the cat did more then just damage the F12 key. If the plastic connectors underneath the F12 are damaged or the white tactile is damaged then they keyboard is done in that aspect. What worries me more is that the right hand side of the keyboard is not usable.
What needs to happen is the keyboard needs to be taken out and reseated back into its slot on the motherboard and see if you can use all of the keys again minus the F12.
If you can then use the keyboard until you can get another one.
If you get the same results (not being able to use the right hand side of the keyboard) then the keyboard is bad and would need to be replaced ASAP or you can use an external usb keyboard for now.
Jul 15, 2009 | Sony VAIO VGP-WKB1 Keyboard
Toshiba Satellite M305D-S4830 Notebook Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
