Question about AEG Lavamat W1050 Front Load Washer
Washing machine Drum rattles
I think there is the underwire from a bra caught somewhere in the drum making it rattle and spin violently when its on! How do I remove offending item? Thanks
  • 641 Answers
It is probably between the clothes tub and the outer tub. To remove it from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub and try to remove the clothing through the port. Good luck
Posted on Sep 04, 2007
Why is drum rattling?
Typically there are 2 reasons for this. Either, you have something trapped in the drum (Underwire Bra wires are the favorite for getting through the holes on the drum, getting caught near the bottom of the drum and making a horrible rattling scrape), OR your bearings are failing. If it's bearings then typically the noise will be far far louder on spin than on wash and you may have found bits of plastic and grey or greasy residue in your washing. This detritus will be from the grease in the bearings and small scrapings of the outer plastic drum, created as the inner drum, spinning erratically, catches it some of the time. If it's the latter, then sadly it's typically an uneconomical repair. Bearing replacements usually cost around £140, at which point you end up with an old machine, with one good part in it, which is questionable economics! If it is a "sealed drum" (that is to say, the drum cant be dismantled and the 2 halves of the outer drum are chemically bonded together during manufacture), then you are looking at the cost of replacing the entire drum, which usually works out at between 60%-75% of the cos of the machine when you bought it new.
Sep 23, 2015 | Washing Machines
While spinning, it made a loud noise but finished washing the load while continuing to make the noise especially while spinning fast.
Hi Chantal,
In my many years repairing Miele machines - the most common problem for what you are describing is the underwire from a bra has got in between the inner and outer drum. It's tricky to get out and can be done if you are good with tools and a little technical - but it does involve opening up the machine, removing one of the heating ellements and searching / fishing it out. Another less common reason for this rubbing noise could be the metal heater element bracket that also sits between the inner & outer drum, has bent - but this is normally caused by a bra underwire. Hope this helps.
Sep 14, 2015 | Miele Touchtronic W1213 Front Load Washer
Washer makes a rattling noise when spinning
Hi
If its rattling check the drum for anything caught in it.Washing machine noise is not only annoying, it can also be a sign of serious damage. When armed with a few tips, you can determine what problem may be causing your washing machine to rattle, and what you can do to stop it.
Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Turn the drum by hand and listen for loud noises. If the drum itself is split or the 'spider' is corroded, broken or has come apart from the back of the drum it will create a loud noise on every turn of the drum. (When the bearings have gone bad, the noise is constant the entire time the drum is spinning.)
Look for obvious dents and creases in the drum or look for coins or small objects stuck inside the tub underneath the drum when a horrendous noise is made while clothes are in the tub.
Clear the water pump from obstructions like coins or small objects when a noise occurs while the washing machine is emptying water.
Remove the sump hose and look for bra wires if you hear a light scraping noise when the drum is turned by hand. You can also check to make sure a wire isn't poking out of one of the holes in the drum. In this case, you can pull the wire out easily with pliers.
Take the belt off and run the motor alone if you hear a high pitched squealing noise to check for motor bearing damage or wear. If you still hear the noise without the belt, it's the motor bearing.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 03, 2011 | GE Spacemaker WSLP1100D Top Load Washer
Hot point WF451 Issue. I want change the door rubber between the door and drum. How do I do this? Also the machine is making a noise on fast spin as if there is something in the drum catching. I have...
Hi for changing the door seal check out the video section on www.selfix-uk.co.uk there are a few videos on the wf including bearing change which also covers the door seal as well. As far as the noise in your machine it could be almost any thing...if it's a scrapping noise it may be a bra wire caught between the drum and container, if its a tapping noise it may just be loose wires hitting on the cabinet or you may have a coin between the drum and container if it's a loud rattle, you could also have something in the pump housing...it's hard to diagnose noises without actually hearing them sorry
Jan 23, 2011 | Hotpoint Aquarius WF000 Front Load Washer
Something loose between the drums
how did the underwire get there, you may want to remove lower panel please unplug washer before removing panel use a flash light there is a area were coins and other objects fall in to also have a bucket there well be water in the lower unit use something to fish it out lucky it did not get caught in pump
Nov 25, 2009 | Kenmore HE2 Plus Front Load Washer
BRA UNDERWIRE STUCK IN DRUM
not posative but there should be a panel at the back that should come off to get at the drum
Aug 27, 2009 | Candy CN146 Front Load Washer
Rattle on fast spin
Hi mate the rattle could be caused by a coin are a bra wire regards a coin you would have to take off the main pump hose connected to the drum our else take the heater element out and see if you can find it if it is a bra wire just rotate the drum until you see it and pull it out
Jul 25, 2008 | Hotpoint Aquarius WD63 Front Load...
Bra underwire stuck
Switch off machine and unplug it from the wall socket. Remove back plate and identify the heating element. It should be located at the bottom of the outer drum. Remove element and you will have limited access to the space between the drums. Rotate the drum slowly by hand untill the bra wire gets to the bottom of the drum. Remove obstruction with hook or long tweeser.
Oct 31, 2007 | Bosch WFMC6401UC
How can we remove underwire caught outside the drum?
I havent opened your particular model, but mine (74520) cen be easily opened from the back (6 screws to remove the plate). You can then see a big rubber hose attached to the bottom of the drum housing. By removing this (open the big clamp on the hose) you should be able to detach it and reach into the housing and get the object out.
Aug 07, 2006 | AEG Lavamat 72640 Front Load Washer
AEG Lavamat W1050 Front Load Washer Logo
398 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
