Question about Sewing Machines
I need an instruction manual for a Beldray Sewing machine model BEL0092
  • Sewing Machines Master
  • 7,365 Answers
Check with sewvacdoctor.com
Posted on Feb 09, 2012
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
SOURCE: Kenmore sewing machine manual for model # 148 12080. (older)
i have a older kenmore sewing machine model #148.19370
Posted on Sep 17, 2008
SOURCE: kenmore sewing machine model 385 16764
There's a website called managemyhome.com which is sponsored by Sears. It's free to join. Go to the Home Manager column and choose Owner's Manuals from the drop down menu.
You can type in the brand name (Kenmore) and model number of your machine. Not all of them are in there but, I did find the one for the 1950280 question. It's a pdf file.
For the 38516764 question, please double check your model number. I received either no response or a Kenmore Elite dishwasher manual in response to my query.
Posted on Feb 04, 2009
SOURCE: Manual for Kenmore sewing machine, model 385.12812690
So far I've only been able to find this page. It's $8.00 to download. Considerably cheaper than a new machine!
http://www.sewconsult.com/kenmore_instruction_manual_385_oce_type1.htm
Hope it helps.
Posted on Apr 02, 2009
  • 1116 Answers
SOURCE: instructions manual for the handy stitch sewing machine
http://www.sewwhat.net/millie/Manuals/CEX300k.pdf
Posted on Feb 21, 2010
Need to find manual instructions on using the machine
Instruction Manuals ' Singer Sewing
www.singerco.com/support/instruction-manuals
Our replacement instruction manuals are provided in a downloadable PDF file ... To download a manual, you will need to know your machine's model number.
Instruction Manuals - ' Singer Sewing
www.singerco.com/accessories/instruction-manuals
singer global ' singer store ' where to buy ' blog ' product registration · logo_singer ....Narrow Your Results: Find accessories for your specific sewing machine: ...
Machine Model Numbers ' Singer Sewing
www.singerco.com/support/machine-model-numbers
Jan 05, 2016 | Singer Sewing Machines
Beldray 12 stitch sewing machine manual
call or email these sites
sewvacdoctor.com
a1sewingmachines.com
Mar 04, 2014 | Sewing Machines
Can not find where to buy a new Beldray bobbin case
try these websites and email them or call them and ask them
about the part you need
Nov 26, 2012 | Sewing Machines
Beldray sewing machine won't make a stitch
try changing the needle--make sure the needle is the right one for
the fabric being sewed, and also inserted the right way in the needle
holder and all the way up into the needle holder
try rethreading the machine top and bobbin--make sure every
thread guide is used
make sure the bobbin is turned the right way in the bobbin case
if none of these suggestion help then the machine needs to be
checked to see if there is a problem with the timing.
Nov 01, 2012 | Sewing Machines
Hey did you managed with the lower bobbin at a beldray sewing machine...??i dont know how to pplace it becuz the needle wont take the lower thread...
Unfortunately, although the top solution is good for all other machines, you cannot get into the base of a Beldray, it is sealed shut. I really need the same help, It is not spooling around the bobbin, and you cannot remove the casing or the bobbin holder .
Jun 08, 2012 | Sewing Machines
I need a manual for Beldray 12 sewing machine cant see model number on it just 12
email these sites about a manual
sewvacdoctor.com
sewusa.com
May 26, 2012 | Sewing Machines
Need Manual for Beldray 0092 12 stitch sewing machine
try these sites you'll probably have to email about a manual
sewvacdoctor.com
Apr 22, 2012 | Sewing Machines
No manual for a beldray 12 stitch sewing machine
hello how does the beldray sewing machine works? please email on alysha678@gmail.com if you know please
Feb 10, 2012 | Sewing Machines
Manual for beldray sewing machine
Welcome to FixYa.
Please post back with the complete model number of your Beldray Sewing Machine so that we can assist you further.
Jas247
Sep 25, 2011 | Sewing Machines
I lost Beldray 12 Stitch Sewing Machine, Model ES0068. he machine is not threading atT all but its running
Martyn Lloyd I have tried the tension knob from one end to the other nad it hasnt made one bit of difference. It would agree with whom ever said it wasnt a very user friendly sewing machine and I have been sewing a few a few years.
So I wouldnt recommend it to anyone.
Aug 03, 2011 | Sewing Machines
Sewing Machines Logo
416 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
