Home | Brother | IntelliFAX 4100 Plain Paper Laser Fax | Black lines printing dow...
Brother IntelliFAX 4100 Plain Paper Laser Fax
Problem for Brother IntelliFAX 4100 Plain Paper Laser Fax
Black lines printing down the right side of the page
By Bobmarlon on Aug 03, 2006
Everytime we send a fax the recieving end gets a black line down the right side of the page. I tried cleaning the scanner but it didnt help. Does anyone know a way to solve this problem.
I coudlnt figure out how I was soposed to install drivers or any of that to it because its not hooked up to a computer.
any help would be much apreciated
Same Problem
Apr 08, 2009
-   me too. I have a brother MFC7420-   Guest
Feb 06, 2009
-   I have the same problem but the only time it is printing the 1/2 inch black line down the right margin is when we send something to it and use it as a printer....so can't be the scanner glass......any suggestions-   cornpalace
Dec 22, 2008
-   I have the same problem. How can I clean it? I replaced the drum and toner and its still there. I tried cleaning the little strip of glass but its still there. Any ideas?-   rhenry31
Feb 19, 2008
-   same machine, same problem.-   imtaur
Jan 04, 2008
-   Dark line down the middle of copies.-   Guest
Best Solution
posted on Sep 06, 2007
Very Helpful)
SALIH OBAID
Rank: Guide
Rating: 85%, 4 votes
dirty mirrors problem open yor machine from th bak side ( metal sheet)and carfully clean the mirrors . do not open the two scrows holding the board behind the lense. clean only the merrors and the glass under the document feeding unit if not fixed send me mail
Was this helpful?
Yes
No
Solution #2
posted on Oct 10, 2007
Very Helpful)
fixix
Rank: Guide
Rating: 88%, 7 votes
This may seem like a stupid answer but have you checked that the document is centered when sending, if the document is off to one side you will get the black line on the other side.
or check that the glass is clean and the white strip above the glass is clean as this is the machines white reference to set shading. if you have white out on the glass some spirits on a clean cloth will work.
Was this helpful?
Yes
No
Solution #3
posted on Aug 06, 2006
Helpful)
leroyal
Rank: Wiz  Brother Expert
Rating: 80%, 1101 votes
One of the leds in the scanner led array is burned out.
Was this helpful?
Yes
No
Solution #4
posted on Feb 13, 2007
Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Check to see if thiere is toner spill inside the machine, often that will print black to the sender or there is dried white out on the scanner glass. Take a can of air and blow out the inside of the machine. Lastly, it could be on the drum, have you changed the drum lately.
Solution #5
posted on Oct 04, 2007
Helpful)
bigdaddy67
Rank: Master
Rating: 89%, 62 votes
There may be something on your scanner lense. Make a copy of blank sheet of paper and determine if there is line on copies also. If there is line take a soft cloth and rubbing alcohol and clean the area where you are getting a line. Make a copy again and determine if the line clears at all. If the line gets better keep cleaning the scanner. If the line does not improve then put the machine in the Maintenance MODE.
Unplug the power cord. Put your finger on the menu key first and then plug the unit back up until the machine says Maintenance. The unit will beep and all of the lights will flash. Let the menu key go and press 82 and the unit will say machine error. There will be a number, if it says 00 there is no error. Press stop and then press 55, the machine will " say scanner area set" this will reset your scanner.If the machine says scanner error, there is a problem with your scanner and it will need to be serviced. To exit out of maintenance press stop and then 99, Try making copies again and verify any improvement.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #6
Somewhat Helpful)
Captweez
Rank: Apprentice
Rating: 77%, 31 votes
Although I am not familar with your exact machine, this problem is almost always caused by a dirty machine. Often times someone will use White Out corrective flued on a document and then fax it. The white out can flake off and get stuck to the imaging lens strip. You should be able to easily open your machine and clean it.
Was this helpful?
Yes
No
Solution #7
posted on Mar 02, 2007
Somewhat Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Guys,this is easy. Look at your mirror where is line came from does the line on the mirror or you have line on your face. Remember, clean is best resolution.
Solution #8
posted on Jan 12, 2009
Very Helpful)
nansiedou
Rank: Master
Rating: 90%, 23 votes
We had the same problem on outgoing faxes or copies, but not on "Help" pages printed from the device, or on incoming faxes. That made us suspect first the scanning glass had dirt or white-out on it - but even after we cleaned the bits of dirt from it, we still had black lines. So next we suspected the scanner lamp. To test it, we started a copy and in the middle of its pulling a page through the ADF, we popped open the ADF a bit to see there was a section of the scanner lamp burned out when it lit up. It matched our black line perfectly.
At the suggestion of a FixYa member, we purchased a Brother CIS Unit, part #LE7949001 from Vance Baldwin Electronics and followed the advice of another FixYa member on replacing the CIS unit. We have a full light on the scanner lamp now, with no black stripes or lines on the outgoing faxes or copies. Thank you FixYa for this forum, and thank you to those who share their knowledge with the rest of us.
Was this helpful?
Yes
No
Solution #9
posted on Apr 19, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Open the cover door, remove drum--seperate toner cartridge from drum and wipe out roler on bottom of toner cartride with a cloth and do the same on the roller on the drum.
Popular Solutions for Brother IntelliFAX 4100 Plain
Questions and Unsolved Problems for Brother IntelliFAX 4100 Plain
Do you recommend Brother IntelliFAX 4100 Plain Paper Laser Fax?
Answer
Answer
Intellifax 4100 - changed toner but keeps reading Please Wait and toner light remains on. Cannot get... (More)
Answer
Same Problem ..Brother fax 4100 the fax will dial the number but gets a busy signal immediatly after... (More)
Answer
My clock on my Brother Intellifax 4100 runs fast have to adjust everyday
Answer
receiving fax offline fax is coming through but not printing. says offline
7 Other Users Have The Same Problem - Continued
Comment by mdrn, posted on Dec 10, 2007
every fax i send has 2 black lines down the right side of page
Comment by Guest, posted on Nov 16, 2007
Black line from top to bottom on left side of page after it is faxed, or if
I take a copy. How do I clean this? Is it coming from a dirty roller?
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Brother IntelliFAX 4100 Plain...:
Top Fax Machine Experts
Rank: Guru Guru
Solutions: 1496
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Fax Machine Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
