I own a 5150 combo and i want to use a thd hot plate power attenuator,but i want to know how to connect it to the amp
  • 1,512 Answers
Hi vhmike
You simply plug your speaker lead out of the 5150 into the Hotplate, and then the Hotplate output into your speaker box. What it does(though you probably already know :)) is "soak" up power so you can run your 5150 hard and get that great tube overdrive happening in the output stages without blasting the surrounding area into orbit with your volume. Hope that helps answers your question. If not, just get back to me here with your questions. Cheers \m/
regards
robotek
Posted on Oct 23, 2008
  • Graeme Ross
    Graeme Ross Oct 28, 2008
    oh, I just noticed you have a combo... sorry man, seen so many 5150 heads with the awesome American Birch ply quadbox, I just automatically think of them when I hear 5150. You will need to use a quadbox with the rig or fit an additional "speaker in" socket to the combo to facilitate using the HotPlate. This is not a big job, and could be done for less than $50. If you need more details on how to do it, just ask :)
    regards
    robotek
Can anyone suggest me a small package for metal combo amp?
I would like to suggest you EVH 5150 III which is best combo package for metal music.EVH 5150 III set you up for success or you just have to claim it.EVH 5150III got many parts and many instrument.For deatils about this package try here. http://www.musicskanner.com/best-combo-amp-metal-small-package-big-sound/
Oct 31, 2016 | Music
How many ohms is this amp
your amplifier has the following specs:
Output Power at 12V:
1 x 200W @ 4 ohms (0.05% THD, 20Hz - 20kHz)
1 x 400W @ 2 ohms (0.5% THD, 1kHz)
Output Power at 14.4V:
1 x 300W @ 4 ohms (0.05% THD, 20Hz - 20kHz)
  • 1 x 600W @ 2 ohms (0.5% THD, 1kHz)
May 10, 2010 | Kenwood KAC-X401M Car Audio Amplifier
I need to know what the wattage the alpine mrv-f407 puts out when its bridged or only running 2 channels?
RMS Continuous Power (at 12.0V)
Per channel into 4 ohms...............40W, 0.08% THD
Per channel into 2 ohms ..............50W, 0.3% THD
Bridged into 4 ohms.....................100W, 0.3% THD
RMS Continuous Power (at 14.4V)
Per channel into 4 ohms...............60W, 0.08% THD
Per channel into 2 ohms...............80W, 0.3% THD
Bridged into 4 ohms.....................160W, 0.3% THD
Max. Power (at 14.4V)
Per channel into 4 Ohms..............120W
Bridged into 4 Ohms....................320W
This should help.
Apr 30, 2010 | Alpine MRV-F407 Car Audio Amplifier
How many watts is this amp
Specifications Power Output: 100 Watts RMS x 2 channels at 4 Ohms ≤ 1% THD+N Signal-to-Noise Ratio: 80 dBA (reference: 1 W output) Additional Power Output: 200 Watts RMS x 2 channels at 2 Ohms ≤ 1% THD+N
400 Watts RMS x 1 channel bridged at 4 Ohms ≤ 1% THD+N THD+N (Distortion): <0.25% (reference: 1 W output) Frequency Response: 20 Hz to 20 kHz (-3dB) Maximum Input Signal: 5V Maximum Sensitivity: 100mV Dimensions: 14.37 x 9.72 x 2.5 (365mm x 247mm x 63.5mm)
Jan 03, 2010 | MTX 4002 Car Audio Amplifier
How many watts is it
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/kac528.pdf
Page 7 of the manual gives you all the different configurations of this amp, and it's MAX power. FYI; Kenwood rates their amps at MAX power, not clean. Hope this helps.
Sep 30, 2009 | Kenwood KAC-628 Car Audio Amplifier
I don't know how many watts is this amp
ECLIPSE makes a 32440
If this is the amplifier you are looking for specs on...
4 x 85W @ 4 ohms (13.8V - 0.1% THD)
4 x 120W @ 2 ohms (13.8V - 0.1% THD)
2 x 240W @ 4 ohms bridge (13.8V)
Thanks for using FixYa -a FixYa rating is appreciated for taking the time to answer your Question.
Mar 28, 2009 | MTX Thunder 1501D Car Audio Amplifier
What is the watts of this amplifier
The XM-1002HX is a two-channel amplifier with power ratings of 100 watts x 2 or 280 watts x 1 into 4 ohms and 140 watts x 2 into 2 ohms. ...
Mar 21, 2009 | Sony XM-1002HX Car Audio Amplifier
Sony amp model 1652z
1000W max power
<b>
165W x 2, 20Hz - 20kHz, @ 0.04% THD + N, at 4 Ohms
200W x 2, 20 - 20kHz, @ 0.15% THD + N, at 2 Ohms
400W x 1, 20Hz - 20kHz, @ 0.1% THD + N, at 4 Ohms
</b>
OTL (Output Transformerless) circuit
Pulse power supply
Line & High Level Inputs
.3-6V Level Adjustment Control (RCA Pin Jacks) 1.2-12V (High Level Input)
80 Hz, -18dB/octave Low Pass Filter Switch
Jan 15, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp a2801q
Audiobahn A2801Q
Product Description:
Class A/B MOSFET Circuitry
200 watts x 2 @ 4 ohms stereo
280 watts x 2 @ 2 ohms stereo
560 watts x 1 @ 4 ohms mono
Volt Meter With Blue Illumination
PWM MOSFET Power Supply
Double Sided Glass Epoxy Circuit Board
THD: 0.02%
S/N Ratio: >100dB
Frequency Response: 10Hz - 40KHz (+/- 1dB)
Variable 18dB Hi-pass Crossover: 90Hz - 750Hz
Variable 18dB Low-pass Crossover: 30Hz To 120Hz
Bass boost @ 45Hz: 0/18dB
Subsonic Filter: 20Hz to 50Hz
RCA Throughput Connections
3-way Protection Circuitry: Thermal, Short Circuit and Overload
Cooling Fan
Cobalt Blue Illumination
High gloss Chrome Plated Finish
Nickel Plated Block Terminals
Dimensions: 2"(H) x 12.75"(W) x 15.5(D)
1-year warranty
Jan 02, 2008 | AudioBahn A2801Q Car Audio Amplifier
Power Cap or Deep Cycle Battery?
a .5 farad cap should work fine for 12v applications, a .75 will work fine for 14.4v applications. If you plan on upgrading the stereo system in the future, you should probably just pick up a 1 farad now and save trouble later.
when mounting the cap, mount it as close to the sub as possible. i recommended a deep cycle battery in an earlier solution due to the power handling requirements for the amp and speaker combo, any time you are working on a competition or semi-competition setup, you will want to isolate your audio system as much as possible from your vehicle's main electronics. i normally use a deep cycle battery if it's going to be a comp/street combo as you can sit at the lake and jam all night without killing your main battery. for comp only use, i stick to optima batteries, they seem to work well and can dump loads of amperage pretty quick.
if you go the dual battery route, you will want to buy a battery isolator to make sure the two batteries are independent of each other.
hope this helps,
trin
Nov 19, 2007 | Kenwood KAC-X401M Car Audio Amplifier
77 people viewed this question
 Grubhead
Grubhead
