Question about RCA Audio Players & Recorders
RCA. RS2767iFE. no headphones, no speaker outputs, no turner sound, no CD's play. Unit powers Up but no functions.
5 Suggested Answers
SOURCE: No audio output.
The power supply electrolytics (C512, C513 & C514) and are a bit underrated. Recommend replacing them with 50 volt capacitors and placing an extra 2 in the vacant places next to C512 and C513. Replace C514 with a 2200uF 35V capacitor. Finally remove that resistor bridging F505 and place a 3amp 5x20mm fuse with holder clips for safety. That should stabilize the whole system.
Posted on Jan 01, 2006
  • 51 Answers
SOURCE: lost speaker output at rear of unit
Hi Guys
Johnac is right the same amplifier that produces sound on the head phones drives the speaker outputs. If you plug in the headphones you will have no sound form the speakers.
If there was a problem with either a fuse or a sound output device you would have the set not switching on as Sony has buildt a very comprehensive protection system into the GX880.
My suggestion is to also check your spekaer wiring. Or the speakers them selves might be faulty.
Also make sure you have set the soundfield setting to Dolby Pro-logic too enable all the speakers to have sound on playback. Thereby chacking too see if it is not only your front speakers that is faulty.
Best of luck
Posted on Mar 20, 2008
jr fix it
  • 5 Answers
SOURCE: System seems to operate fine but no sound
there is something that is called a relay in side of the set when u open it u will see it were u put the speaker wires behind that two black boxes those are the relay look between them n see if any thing had burn if so u need to change that part of reach me at 742-2520 if u want
Posted on Jul 14, 2009
SOURCE: I get no sound from the RCA unit in any playing
Bought new unit NOT from RCA manufacture. Listen learned DO NOT buy RCA.
Posted on Nov 18, 2009
A friend recently gave me a Pioneer deh-p5750mp car stereo cd player and I'm having trouble installing it. I have successfully managed to connect the positive, earth and constant power wires and...
One thing to remember about most radios, the RCA pre amp circuit will still work even if the mosfet power amp inside the radio does not. The best way to know if the amp inside the radio works is to use one matching color pair coming off the radio to wire up a random speaker right to the radio. You can use just about any old random 4 ohm speaker that is laying around to check it. The best solution if the amp inside the radio is blown is to replace the radio or amp the pre amp outputs with a small 4 channel amp. Oh, by the way. What vehicle are you connecting this into? And does the vehicle say Bose, Infinity, or ect sound or Premium sound? These usually denote a factory amplifyer already onboard and requires special connections to get the signal to these amps to then be delivered to the speakers.
Sep 12, 2011 | Car Audio & Video
Hello, I have a Sony STR-D85 surround sound system. I need to connect my phone to the system so that my phone's music plays through my surround sound speakers. The front of the console has a headphone...
Headphone jack is an output not input jack. Your going to need a cord to go from your headphone jack(output) of your phone to audio input on your receiver. The cord has a mini stereo plug to the phone and RCA plugs of left and right to your receiver auxiliary input. Good luck..
Jul 15, 2011 | Sony STR-DE485 Receiver
I have a LG 19LE3300 television and i whant to be able to connect an Infra red headphone while being able to listen by the speakers at the same time. actually when i connect the hearphone it disconnect...
First you need to make a test to adjust your headphones wireless system..
.pls follow the step below:
  • "Connect the headphone base" TO " headphones output of TV" with 3.5mm stereo headphone jack cable (than Tv should mute ) Infra red headphone pilot lamp should flicker in parallel to voice coming from TV
  • Infra red headphone should have a rotary adjustment on it.. "Volume" adjustment
  • while TV talking , when you sit in front of the Infra red headphone (it works point-to-point ) you will hear the voice of TV, than adjust volume properly...Thats it..now lets go to second step..
  • Your headphone's Base should either "3.5mm stereo headphone jack" or "RCA Stereo jacks" or "bot"h..After completion of this test ,I recommend you to switch / use "RCA Audio output plugs-white/Red cable " on the back of TV instead of TV's headphone output ,since it mutes the whole sound..RCA output plugs of TV work independently from the TV's master volume control..of course you need RCA cable to connect this..
Hope this helps!..if more help requires pls let me know.
Take care and please
Remember to rate/vote and give me 4 Thumbs Up for me to continue f
or Helping out the Community :)
Jun 30, 2011 | Televison & Video
Where do i plug my speakers in on my cdj 600's? got it working through the headphones everything else is useless??
You connect POWERED speakers to the left and right outputs... You MUST use POWERED speakers or an external amplifier. This unit has a small headphone amp, but that CANNOT power passive speakers.
Apr 22, 2011 | Gemini Sound Products Gemini CDJ 600...
VXZ 646 what connections do I require between unit and TV To play DVDs
all you need is to run the RCA outs from the back of the unit to the signal screen, the screen however will need a power source seperate to the head unit. if your screen is only a slave screen and does not have any speakers (or you wish not to use them), nor has any IR for headphones, then you need only to use a single Video RCA, if however it has got IR on the screen and you do wish to use headphones then you will need to use a triple RCA set, (normally RED, YELLOW, WHITE) with red and white being for your stereo sound output, and yellow being for your video.
I hope this has helped you and please dont forget to rate my solution.
cheers
Jan 13, 2011 | Clarion Car Audio & Video
How to listen to my ipod thru my home audio system
You need a headphone to RCA adapter cord, and then you just plug it into the headphone jack on the iPod (iPhone) and plug the two RCA plugs (red & white) into any sound inputs on the receiver and you're all set.
Check this link: http://www.google.com/products/catalog?q=headphone+rca&rls=com.microsoft:*&oe=UTF-8&um=1&ie=UTF-8&cid=12037070188082563730&ei=MC1ZS_qCA4SINJ7U3YsP&sa=X&oi=product_catalog_result&ct=image&resnum=1&ved=0CBQQ8gIwAA#
Jan 22, 2010 | Yamaha HTR-5860 Receiver
Audio from tv is not restored by turning off power on headphones
It sounds as if you are plugging the base into a standard headphone jack located on the Television set.
RCA Headphone jacks (incl mini) automatically stop the sound output to the main speakers on almost every set I have seen.. or home stereo.. etc etc
In other words you can take a standard RCA jack.. with nothing connected to it.. plug it in while the music or sound is coming out the main speaker.. and it will cut off the output to those speakers..
If you set has audio outputs on the back.. preferably Fixed Audio Out .. you will need to connect your base unit to those.. turn your set volume to 0 and adjust the headset volume using the control on the right ear-cup.
If you have variable audio out.. you will need to go into your TV sets setup menu.. turn off the speaker.. and turn up the set until you achieve a signal and decent volume through the headset.
If you are missing these connections.. your current “work around” is your only solution.
Best of luck
Dec 31, 2008 | Sennheiser RS 120 Consumer Headphones
Power on green light is on but no sound when speakers are hooked up
Light is on so suggests power, earth and remote turn on cable all ok. Now you just need to test the RCA signal and the AMP output. I take it you have used low level RCA as the input from the head unit? (two cables usually red n white although can somtimes be other colours) best way is with substitute amp n speakers etc although can be done with osciliscope or headphones. Once it is established the RCA signal is fine then you can check the speakers from the amp. disconnect them at the amp and put each of the two wires briefly to a battery, any battery will do e.g. 9v PP9 or 1.5v AA etc you should hear a pop from each speaker as you do it. that proves the speakers and wiring to them.
If there was no signal from the RCA the cables may be bad - requires testing from head unit to amp
failing that the RCA output may be reduced or turned off via a menu in the head unit
Or the RCA output from the unit may be knackered.
Sorry its a bit long hope it helps
Luda
Jul 04, 2008 | Jl Audio Car Audio & Video
Speaker Trouble
Michael,
Not being an expert, but having years of experience with electronics, I would think there may be a bad wire connection for the CD unit or a bad unit. If the CD unit is on your PC, you can check the internal connections. There should be a heavier gauge power supply cable and a lighter gauge signal connector. It could be loose at the CD unit or the motherboard. Use an anti-static wrist strap and make sure the power is off. Your cable might be bad and they are easily purchased and replaced. If it is on your "stereo", then check the RCA jacks. You can reverse the left and right RCA jacks to see if the problem is still in the same channel. You could also connect the CD to another line input on your receiver and see if the problem persists.
Mike
Mar 24, 2008 | Audio Players & Recorders
111 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
