E-Machines eMachines Refurbished EMA eMachines PC Desktop
Problem for E-Machines eMachines Refurbished EMA eMachines PC Desktop
Emachines 1900+ gets power to the monitor and computer but wont boot
By zionbound on Aug 03, 2006
i turn on the computer and monitor.the monitor powered up
the computer fans came on even the cpu fan but wouldnt boot
not even a flicker on the screen. the hard drive light comes on and stays on.
ive tried a new power suply,new ram,and a new hard drive.
anny help would be awsome thanks
Same Problem
Oct 18, 2008
-   I've got the same problem, though it's on an eMachines T6534 w/ onboard Nvidia GeForce 6100 chipset (aka graphics card).
I have tried: using a different monitor that I know for sure works, used a PCI display card from another working PC, pushed lightly on all MoBo chips to seat them properly (all that I could find, pretty sure I got them all), and switched the only RAM card to another available slot (there's 4 in total). During the seating process, the only PCI Modem card present was slightly out of it's socket when I had pushed down, so now it's in place.
Thinking the problem was solved, I reconnected everything and actually did manage to get the display to show for a few seconds. It appears to have hung where it shows the giant lowercase 'e'. On that same screen, were two options, one for F2 and the other for F10, can't remember what they were for though. I tried both keys, and nothing happens, the CAPS lock on the keyboard didn't show up, so I'm not sure if the keyboard doesn't work with that PC or if it just froze up. I know for sure the mouse and keyboard work.
So thinking the display would work by shutting down with the button held in and turning it back on, when it turns back on, nothing shows anymore! Since I have tried a different video source, it could be just be the MoBo.
Is it possible that the drivers were messed with? Before attempting anything video-related, I had taken out the HDD, put it into my external encloser and connected it via USB to scan both partitions for any viruses/spyware. Three were found on the main partition, while 1 was found on the 2nd (recovery partition). The 3 viruses, were actually Trojans. While this is a spur of the moment theory, it could be that while one or more of the Trojan's payload were Backdoors, allowing the attacker to mess with the display drivers. Though it seems unlikely, seeing as the amount of access an attacker can have with a Backdoor, not all attackers are the same, they each have different plans.
One more thing to add to this lengthy post, the names of the Trojans (scanned with ZoneAlarm Security Suite 7.0.483.000):
Trojan-Downloader.WMA.Wimod.n
Trojan-Downloader.Win32.Agent.aidz
Any help is appreciated, thank you :D
-   Megafloat
Best Solution
posted on Aug 04, 2006
Helpful)
scifiguy
Rank: Guide
Rating: 83%, 46 votes
There could be a number of causes. Do you hear any beeps when the computer starts up?
Try seating all the chips in the motherboard. That means, apply pressure to each individual chip on the motherboard with your finger or thumb. The goal is to make sure each chip is securely attached to the board.
Sometimes, heat or new h/w installs partially "pop" some of the chips out of the motherboard - causing the circuitry to be disconnected...
Comments:
Aug 04, 2006
- When a computer doesn't start up, there's a set of "Beep codes" which can provide an initial diagnosis. Although, the codes may differ based on the CPU manufacterer, here's a list of some of the common ones:
Beeps
Error Message
Description
1 long, 2 short Video adapter error Either video adapter is bad or is not seated properly. Also, check to ensure the monitor cable is connected properly.
Repeating (endless loop) Memory error Check for improperly seated or missing memory.
1 long, 3 short No video card or bad video RAM Reseat or replace the video card.
High frequency beeeps while running Overheated CPU Check the CPU fan for proper operation. Check the case for proper air flow.
Repeating High/Low CPU Either the CPU is not seated properly or the CPU is damaged. May also be due to excess heat. Check the CPU fan or BIOS settings for proper fan speed.
Aug 07, 2006
- So, did any of that work? If not, more details pls...
Was this helpful?
Yes
No
Solution #2
posted on Oct 31, 2008
Not Rated)
Jim4005
Rank: Apprentice
Rating: 0%, 0 votes
I have a HP Pavilion 505n. After I d/l an HP BIOS udate, I receve "CPU Fan failed. Hit F2 to coninute or systme will power off in 5 seconds." Fan is running. Any posible solutions
Was this helpful?
Yes
No
Solution #3
posted on Jun 18, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Hey i just had the same problem, i took the side panel off and just tapped on everything.. i dont know what was loose, but it worked. thank you
Solution #4
posted on Aug 26, 2006
Not Rated)
alexva
Rank: Apprentice
Rating: 0%, 0 votes
I am having exactly the same problem also (I have a Model C2685). The hard drive and CD ROM Drive light comes on and stays on.
Thanks for any advice..
Was this helpful?
Yes
No
Popular Solutions for E-Machines eMachines
Questions and Unsolved Problems for E-Machines eMachines
Do you recommend E-Machines eMachines Refurbished EMA eMachines PC Desktop?
Answer
Answer
FixYa Test Problem 11/26/2009 14:42
Answer
issue with acer aspire X3812, the dvd writter can read CD, burn cd but it does not work when i want... (More)
Answer
I cant get my speakers to work on my monitor can u help me?
Answer
Umax 2200 usb scanner & Vistascan 3.55u in Windows XP Scanner installs to the default XP... (More)
Answer
okay well, everything is plugged in and looks like its working, when i got to turn pc on everything... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For E-Machines eMachines...:
Top PC Desktop Experts
Rank: Guru Guru
Solutions: 744
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Desktop Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
