1996 Ford Ranger SuperCab Logo
Posted on Nov 14, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 96 ranger and the ignition chime never shuts off. The only way to make it stop is to pull fuse #25 which is gem system and speedometer. What could the problem be? I'm thinking replacing the ignition or should there be engine codes that come up and if so can it be done with an obdII comp or do I need a live dyno done?
Vernon Taylor
Level 3:
  • Ford Master 7,446 Answers
  • Posted on Nov 14, 2017
 Vernon Taylor
Ford Master
Level 3:
Answers
7446
Questions
0
Helped
1955004
Points
26207
I suggest you obtain a wiring diagram and understand the circuit before you begin to fault-find or check the exact operation or function in the vehicle handbook.
If a single chime is used for ignition, door and lights there could be a control box...
Jeffrey Turcotte
Level 3:
  • Ford Master 8,991 Answers
Jeffrey Turcotte
Ford Master
Level 3:
Answers
8991
Questions
7
Helped
4367864
Points
33683
There are no codes for this. The issue may be that the gem is getting a driver door open signal or the gem itself is bad. I got a used gem at a salvage yard for $20 recently, but make sure its not the door switch first. You can pull the connector off the switch and use an ohmmeter to see if the wire is grounded. If it is, trace it to the gem to find where it is getting cut into.
3 Related Answers
Anonymous
  • 161 Answers
  • Posted on Jun 15, 2009
SOURCE: Location of GEM Module on 1998 Ranger
i am almost sure it is in steering col area by firewall. but call any part store like auto zone and they can print it out and tell you if your ford dealer wont. but on the fords they usualy are all in the drivers steering area sometimes way up by fire wall
bill
  • 234 Answers
  • Posted on Aug 15, 2009
SOURCE: need to find out where the GEM module is located
behind the radio on the left side after you remove it
Anonymous
  • 65 Answers
  • Posted on May 05, 2011
SOURCE: I have residual current draw on 1996 Ford
When checking a draw you have to wait to check till all modules have powered down including Gem module. This can take up to 30 min. Specs are 50 ma draw. To check get you a test light take off the postitive cable, " you can also use a meter", now you have to put the light in series withe the battery and cable. Clamp one side of test light to battery cable the other side to battery post WITH CABLE OFF THE WHOLE TIME. Now if you open doors turn any switches you will have to restart your 30min. then you can check and see if unplugging module, if that fixed problem. what we do is open the doors before, then take a screw driver and close the door latch so that you can get in and out of the car without turning something on
Courtesy Chime Chime Chime will not shut off. What do I have to do to troubleshoot the GEM Module and whatever is connected to/through it?
If the chime includes the cab light staying on as well:
There is a door switch in both the driver and passenger side doors that needs attention. I too had this problem. Solution: squirt wd40 onto the switch located near the door latch on both driver and passenger side.
1helpful
3answers
Navigator Door Chime goes off when car off and I open the door. Radio system stays on & interior lights go off when door shuts.
All this comes from the GEM module,You will need to repair the driver door lamp switch located in the door lock assemble.
1helpful
What fuse do i pull to stop the warning dings for the headlights ,key in ignition, and seat belt sounds
there is what they call a chime module . located on the drives side in or near the fuse box by the lower kick pannel . this module could be about 2x2 color black/green/or tan . and look like it has a small speaker grill in it . remove this and it should stop the warning chimes
70helpful
5answers
Diagram of 1996 ford ranger fusebox which fuse is
RANGER FUSE PANEL Fuse Position Rating Circuit Protected 1 7.5 Amp Power Mirror 2 — Not Used 3 15 Amp Parking Lamps 4 10 Amp Left Headlamp 5 10 Amp On Board Diagnostic (OBD) II System 6 7.5 Amp Air Bag System/Blower Relay 7 7.5 Amp Illumination Switches 8 10 Amp Right Headlamp/Fog Lamp System 9 10 Amp ABS System 10 7.5 Amp Speed Control/GEM System/Brake Interlock 11 7.5 Amp Warning Lamps 12 10 Amp Front Washer System 13 15 Amp PCM System/Stoplamps/
4WD/ABS/Speed Control 14 10/20 Amp ABS System 15 7.5 Amp Air Bag System/Alternator 16 30 Amp Front Wiper 17 15 Amp Cigar Lighter 18 15 Amp A/C System 19 25 Amp Ignition Coil/PCM System 20 7.5 Amp Radio/GEM System/Anti-Theft 21 15 Amp Hazard Lamps 22 10 Amp Turn Signals 23 — Not Used 24 10 Amp Starter Relay/Anti-Theft 25 7.5 Amp Speedometer/GEM System 26 10 Amp 4R44E/4R55E Trans./Backup Lamps/DRL System 27 10 Amp Underhood LP/Map Lights/Glove Box Lamp/Dome Lamp/Visor Lamps/4x4 Sys. 28 7.5 Amp GEM System 29 10 Amp Audio System 30 — Not Used 31 — Not Used 32 — Not Used 33 15 Amp High Beam Lamps 34 — Not Used 6d47eae.gif
Battery has about 1/4 amp drain with everything off. Pulling fuse #25 (Speedometer and GEM system) brings the drain down to the normal 0.05 amp level. Problem is frequent but intermittant. Auto mechanics...
You're right - nothing to do with the alternator. Question is, why would those accessories be active with the ignition switch OFF? Perhaps some problem with fuses being active that shouldn't be when the ignition is off.
4helpful
Need to know what fuse goes where
I am not sure if this right and there should be diagram on the back of cover.
1 5A Power Mirror Switch
2 10A Daytime Running Lights (DRL),
Back-up Lamps, Transmission,
Passenger Air Bag Deactivation
Switch, Blower Motor Relay
3 7.5A Right Stop/Turn Trailer Tow
Connector
4 — Not Used
5 15A 4x4 Control Module
6 — Not Used
7 7.5A Left Stop/Turn Trailer Tow
Connector
8 — Not Used
9 7.5A Brake Pedal Position Switch
10 7.5A Speed Control Servo/Amplifier
Assembly, Generic Electronic
Module (GEM), Shift Lock
Actuator, Turn Signals
11 7.5A Instrument Cluster, 4x4, Main
Light Switch, Truck Central
Security Module (TCSM)
12 — Not Used
13 20A Brake Pedal Position Switch
14 10A or Not Used 10A: If equipped with Anti-Lock
Brake System (ABS) Control
Module
15 — Not Used
16 30A Windshield Wiper Motor, Wiper
Hi-Lo Relay, Wiper Run/Park
Relay
17 20A Cigar Lighter, Data Link
Connector (DLC)
18 — Not Used
19 25A PCM Power Diode, Ignition, PATS
20 7.5A Generic Electronic Module
(GEM), Radio
21 15A Flasher (Hazard)
22 20A Auxiliary Power Socket
23 — Not Used
24 7.5A Clutch Pedal Position (CPP)
switch, Starter Interrupt Relay
25 — Not Used
26 10A Battery Saver Relay, Auxillary
Relay Box, Restraint Central
Module (RCM), Generic Electroic
Module (GEM), Instrument
Cluster
27 — Not Used
28 7.5A Generic Electronic Module
(GEM), Radio
29 20A Radio
30 — Not Used
31 — Not Used
32 — Not Used
33 15A Headlamps, Daytime Running
Lamps (DRL) Module, Instrument
Cluster
34 — Not Used
35 15A or Not Used 15A: Horn Relay if Not Equipped
with Truck Central Security
Module
36 — Not Used
3answers
Is there a fuse to pull to stop the seatbelt chime?
Pulling the fuse is not an option.Check your owners manual for instructions on how to shut it off..
All windows will not work on my 2005 ford taurus
2002 taurus. don't have 2005. Sorry.
Could be your GEM module. Call your dealer and ask if your 2005 has GEM module. It's expensive so be sure it is problem first.
Dealer can test with NGS tool.
CAUTION: Once the new module is installed, it is necessary to download the module configuration information from the diagnostic tool equipment into the new module. For additional information, refer to Section 418-01 .
Principles of Operation
The generic electronic module (GEM) constantly monitors its subsystems for concerns. If a concern is found in one of the subsystems, the GEM will record the concern in the form of a diagnostic trouble code (DTC).
The ignition switch position is very important to the GEM functionality. Erratic or unexpected GEM functions can often be traced to problems with these ignition GEM inputs.
The GEM controls a variety of systems:
  • windshield wipers
  • courtesy lamps
  • warning chimes
  • keyless entry
  • interior and exterior lamps
  • power windows
  • parking brake actuator warning chime
Inspection and Verification
  1. Verify the customer concern by operating the system.
  1. Visually inspect for obvious signs of mechanical and electrical damage.
Visual Inspection Chart Electrical
  • Central junction box (CJB) fuse 216 (15A)
  • Damaged wiring harness
  • Loose or corroded connector(s)
  • Circuitry
  • Generic electronic module (GEM)
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
