Question about SanDisk Sansa m200 SDMX3-512 MP3 Player
Sandisk sansa m200
My sansa worked good and my power button stuck down so i couldnt turn it on i opened it and took out the power button anyway i can turn t on without the power button?
    Scholar:
  • 161 Answers
May be you can still send it back if under warranty. Never good idea to take things out like power buttons.
www.sandisk.com
1-866-726-3475
Posted on Aug 26, 2009
How do i play back a recording i've made? I have the Sansa m200 series MP3 Player
To play back a voice recording, you will need to do the following steps after turning on the player. Press Power/Menu briefly to get the software menu. Press the Repeat/A-B/Down button to highlight the line Play Music and press Select to enter the play back sub-menu. Press the Down button again to go to the line Recordings and press Select again. Use the Down button to highlight a particular voice recording and press Select to start playing the recording.
The manual for the Sansa M200 MP3 player is available as a PDF from the manufacturer here: http://kb.sandisk.com/app/answers/detail/a_id/241 . The details for playing back a Voice Recording are on page 23-24 (24-25 of the PDF). You will need Adobe Reader or a similar program to read the manual.
I hope this helps.
Mar 25, 2014 | SanDisk Sansa m240 MP3 Player
How do i free 8mb in Sandisk Sansa M250 i formated but the same result happens plz help me!!!!
SanDisk tech support recommends formatting the m200 series in both MSC and MTP modes to completely clear out all work areas,"fragments" and residual data. The m200 has a very basic Operating System that doesn't have a defrag option. According to tech support, the m200 needs formmating occasionally to keep it working smoothly. I learned that formatting will also clear up intermittent hang-ups. I format mine each time I reload it.
Format in MSC Mode
With the m200 not connected to the PC, power it on, press the menu key. Select "Settings", then USB, then MSC.
Connect the m200 to the PC via the USB cable
Right click on the "Start" button.
Left click on "Explore"
Find the m200. It will show as a hard drive, for example: "SANSA M250"
Right click on the m200 device and select "Format"
After formatting is complete, click on the "Safely Remove Hardware" icon on the System Tray and stop the device
Disconnect the m200 from the PC.
Format in MTP Mode
With the m200 not connected to the PC, power it on, press the menu key. Select "Settings", then USB, then Auto Detect.
Connect the m200 to the PC via the USB cable.
Find the m200. This time it will not show as a hard drive but as a music device, for example: "SanDisk Sansa m250"Note there is no drive letter in MTP mode.
After formatting is complete, disconnect the m200 from the PC. There is no icon to stop the device.
Your m200 device is now formatted and ready to reload.
By the way, MSC mode is mostly for use with other than Windows XP computers. If you are using WinXP and Windows Media Player 10, you might consider using MTP mode and WMP to manage the m200's.
Source: http://forums.sandisk.com
If i was helpful, kindly do Rate!
Regards.
Jul 28, 2009 | SanDisk Sansa m240 MP3 Player
Sansa m230
http://www.sandisk.com/sandisk-support/warranty-and-user-guides/user-guides.aspx#englishamericas
turn on your sansa player. (don't plug into to computer yet)
Click Menu
Scroll through using down area till you get to SETTINGS.
Click down till you see USB.
Choose auto detect for Windows Media Player 10.
Choose MSC if you have Windows Media Player 9 or earlier.
Good luck.
This is what is needed on the C-100.
Go to sandisk.com and get your manual.!
Sep 19, 2008 | SanDisk Sansa m200 SDMX3-512 MP3 Player
My scandisk sansa clip mp3 player is fozen at the refresh database screen
I actually called the 800 sandisk number and the guy was helpful (after some annoying personal questions).
Unplug from your computer
Turn off the device.
Push the button down to be in the "Hold" position
Press down on the "center" button (inside the circle)
While still pressing on the center, plug in the device.
Now you should be able to see the device under "My Computer"
Right click on it and FORMAT --YOU WILL LOSE ANYTHING THAT WAS ON IT! But you will be able to use it again. I was assuming all my stuff was gone, it was just copies from my computer anyway.
This worked for me and now I just have put my music back on it.
Hope this helps everyone else! And don't hook it up to a MAC!! Even just to charge it!
Feb 16, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa m250 MP#
Try doing a hard reset on a Sansa m250:
  1. Turn off the Sansa. Just pull the battery out for a second and then reinstalling the battery without pushing any further buttons.
  2. Plug the Sansa into a computer4.gif, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC4.gif Specific storage" file.
  4. Right click the "MUSIC Specific storage" file, and press "Format."
This should hard reset the Sansa m250. This solution has worked for me.
I do not know if this will work on other Sansa m200 type .mp3 players.
Dec 30, 2007 | SanDisk Sansa m250 MP3 Player
Sansa - sandisk m250 troubleshooting
  1. Turn off the Sansa. Just pull the battery out for a second and then reinstall the battery without pushing any further buttons.
  2. Plug the Sansa into a computer, and open "My Documents" in the computer.
  3. Open the Sansa file as if it were a drive, then go to the "MUSIC Specific storage" file.
Dec 20, 2007 | SanDisk Sansa m250 MP3 Player
M250 sandisk
Dec 13, 2007 | SanDisk Sansa m250 MP3 Player
Won't come on
it could be the classic lockup that these players are famous for but usually they botup to the sandisk screen and then its a brick, anyway try a total hardware reset by:
1 taking out the battery.
2 holding the powerbutton down for 40 seconds
3 waiting 5 minutes before putting in a fresh battery and starting over.
Oct 11, 2007 | SanDisk Sansa m250 MP3 Player
Reset button
1. There's no reset button. 2. Try removing the battery and keep pressing the power button for 1 minute. This is supposed to turn off the power. The other simple shut down is rather described to be a standby mode. Hope that helps. Amakorkos
Jun 10, 2007 | SanDisk Sansa m200 SDMX3-512 MP3 Player
SanDisk Sansa m200 SDMX3-512 MP3 Player Logo
117 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
