Question about Whirlpool MH7140XF Microwave Oven
REPLACE handle on whirlepool microwave model MHE14XMQ-O
3 Suggested Answers
MicrowaveSvc
  • 9085 Answers
SOURCE: Blown fuse on Roper over
We have critical safety & disassembly info (including a how-to video) at our site, linked here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
Please reply back here if you still need help.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Jul 19, 2008
marked
  • 6487 Answers
Go to this link for the complete detail about your microwave and also for the diagram and how to replace the fuse..
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/0/52015b2c875fae4d85256a8c0062547e/$FILE/4322167.pdf
Hope that helps..........
Posted on Jul 28, 2008
Whirlpool mhe14xmq 0 everything works except FOR HEATING
Hi, Consumer. We're sorry to hear about the difficulty with your washer. Below are links to our Use & Care guides, Parts Diagrams, Troubleshooting information and the Service are of our website. We hope this helps! http://bit.ly/112Lu7q
Jun 04, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
Handle broken
I need to replace handle which fell off. Whenre do I find handle> Do not have model #
Nov 17, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
I need to replace just the door handle on a Maytag Microwave (Model No. MMV4205BAS). All I've seen online for parts is a complete new door for anywhere from $220 to $300. Surely there is a cheaper...
The handles run about $25-35 here.
Here are the part numbers & descriptions:
W10279351 Black handle
W10279353 White handle
W10279355 Bisque handle
Sep 07, 2010 | Maytag MMV4205 Microwave Oven
Loud fan when microwave model MHE14XMQ is in use
The fan is controlled by control board behind keypad. Replace fan motor first, if that does not help replace control board.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Jan 21, 2009 | Roper MHE14XKB Microwave Oven
How do I remove the wall whirlpool combination of their microwave and oven?
Whirlpool customer service is here and you can enter your model number on that page to download your owner's manual, installation instructions, etc.
The installation instructions will show you how it went up and that will help when you remove it.
Nov 25, 2008 | Microwave Ovens
F6 error... microwave not working
is the microwave itself working? because same thing happened to us apparently the guy who changed the bulb didnt unplugg the thing first and well it burned a part of the circut board cost us about 90 dollars to fix it.....
Oct 05, 2008 | Roper MHE14XKB Microwave Oven
Roper Microwave (mhe14xmq dec. 2003) trips breaker...
you might have to reset your your power settings on the micro.
Sep 21, 2008 | Roper MHE14XKB Microwave Oven
Microwave blows fuse
The most common suspects are the high voltage transformer and the magnetron. It's also possible you have a flaky door switch or loose door switch mount. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Jun 07, 2007 | Roper MHE14XKB Microwave Oven
Whirlpool MH7140XF Microwave Oven Logo
37 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
