Question about Kitchen Ranges
On a LG range, model#LSB5611SS, the bottom inside oven has the finish going bad.I,m not sure what the remedy would be. Rene
  • Rene Matz Feb 11, 2012
    Oven liner is not available as replacement part, Sears is doing a buy out.
2 Suggested Answers
SOURCE: tin foil baked onto bottom of gas range oven
rape it
Posted on Oct 09, 2008
Display shows PF-time of day flashing on Frigidaire range.None of the buttons respond. Rene
Try unplugging it to reset the main control board witch most of the time its your clock.then push enter.if don't don't work then your clock (main control is bad .or if it has a touch pad it could be bad.call repair clinic .com at 1-866-822-0890 or 1-800-269-2609 and order parts there.they can tell u how much
Nov 08, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
OVEN WILL COME ON
could be several things with not alot of description here we will give it a try... first off is the control working and does it appear it is trying to start the system just no heat coming from oven... if so i would say if indeed this is a gas oven that you have a bad ignitor on the unit. try the broil does it work if so then we just eliminated the controller most likely and the gas regulator i would say the bake ignitor is bad... you will have to take racks out of oven and on bottom you can remove the flat plate on inside bottom of oven and under that is a heat shield that can be removed to access the ignitor. it has to get hot enough to send voltage back to the regulator to open up...
go to www.sears.com and then hit the parts direct link up top enter your model number to unit and find your part and order good luck to you....
Feb 10, 2011 | GE Profile Spectra JGBP90 Gas Kitchen...
Whatis F3 mean when sld cleaning oven
F-3 tells you that the electronic control has detected the fault condition.
Press CLEAR/OFF to clear the display and stop any beeping. Then go to the house breaker box and try turning the house breaker to the oven off for 5 minutes. Electric ovens have two switches in the house breaker box. This will reset the system and clear any electronic glitches that are in the system.
If this does not remedy the situation then this means you have a bad oven sensor.
Unfortunately this is not a home handy person fix.
Mar 14, 2010 | LG LRE30755 Electric Kitchen Range
Range works, but oven does not heat up and I smell the gas . What should I do?
  • remove the oven cavity bottom, remove burner shield and clean the burner inside the oven.
  • make sure all holes in the oven bottom are not covered with anything (i.e. foil)
  • adjust ignitor position (move it slightly closer to burner)
Nov 17, 2009 | Whirlpool GW395 Gas Kitchen Range
LG Range LSB5611SS LHS element stays on
I have the same model and there is a recall on that model and others as well. The control panel will be changed for free. There is a site where you can check it out http://www.healthycanadians.gc.ca/recall-alert-rappel-avis/hc-sc/2012/15538r-eng.php then contact LG
Sep 01, 2009 | LG LRE30451ST Electric Kitchen Range
Where do I light my gas oven?
Hello Slacker3158 how old is this oven? I only ask as GE hasn't built a standing Pilot range in over 18 yrs. The issue may be a bad oven ignitor. Put the oven on broil, if it works then the bake ignitor is bad. It is found under the bottom of the oven. There is 2 to 4 screws inside the oven that allows the bottom to be removed.
Feb 03, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Majic chef gas range not sure of model #
You need to replace the oven igniter. It's what you see glowing. They grow weak with age. TURN POWER OFF before servicing this. The numbers can often be found behind drawer at lower front, on oven frame, on left or right near bottom.
Bring model # with you. It should be a standard magic chef igniter. Think it's 12400035.
Remove oven floor to access igniter. It's held on by 2 screws in side of burner. Put some dishwashing detergent on them before trying to remove them. Otherwise they might strip out. The new igniter may plug right in or you may have to cut wires and attach with enclosed wire nuts. The 2 wires to it can be attached either way.
Nov 06, 2007 | Magic Chef 31000 Gas Kitchen Range
F3 code on kenmore elec range
I believe the F3 error code is an oven temperature sensor fault. The sensor is a small probe that sticks out of the back of the oven wall. They do go bad and can be easily replaced. If I had your EXACT model number (found along the inside of the oven door or lower drawer) I could be more sure.
Sep 03, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kitchen Ranges Logo
80 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
