Question about Maytag Washing Machines
How to remove an agitator from a model A8200 maytag washer
Model # A8200
the dr
  • 447 Answers
SOURCE: Maytag washer fabric softener dispenser is yucky
There is a 1/4" machine screw in a recessed hole close to the bottom of the agitator. Remove screw. Lift agitator off agitate shaft.
Posted on Nov 28, 2007
jsrock516
  • 5911 Answers
SOURCE: How do you remove the agitator on a Maytag Dependable Care Washer?
If this is a Maytag Performa or Atlantis model all you have to do is remove the center cap on the agitator by pulling on it and locate the agitator bolt underneath. Loosen the bolt, and the agitator should pull straight up.
If this is a Maytag Dependable Care series there will be 1/4 inch screw along the side of the agitator towards the bottom. Remove this screw and the agitator will pull straight up.
I hope this helps you.
PS If the problem is due to the build up of fabric softener, soak in some hot water to loosen it up. Fabric softener is essentially a form of liquid wax and it is common for it to accumulate and clog the dispenser in this manner. Periodic cleaning is recommended.
Posted on Aug 09, 2008
  • 219 Answers
SOURCE: Grinding noise during agitation on washing machine
check water pump
Posted on Apr 17, 2009
SOURCE: MAYTAG top loader makes high pitched squeal when agitating/spinni
This is a classic symptom of pulley/motor shafts/bearings in need of lubrication. It's not the agitator. You'll need to take the back off (with power unplugged) to access.
Posted on May 12, 2009
  • 3741 Answers
SOURCE: my washer wont agitate ?
If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Posted on Aug 20, 2009
I have a Maytag Washer Model LAT9206BAE, I have cleaned the washer but my clothes are still getting a lint like substance on them. Is there a screen or something on the discharge that may be blocked.
There is no filter. You may have something that is hung up under the agitator. To remove the agitator, remove the fabric softener cup, then the bolt that holds the agitator on and lift the agitator out.
Nov 22, 2012 | Maytag Washing Machines
HOW DO i REMOVE THE AGITATOR FROM maYTAG WASHER MODEL # MAV6457AWW
Gently remove the fabric softener cup off of the top of the agitator
Using a ratchet, an extension and socket; then remove the retaining bolt under the fabric softener cup.
The agitator will lift off after the bolt is removed.
Installation is:
Drop the agitator in place. Install bolt.... tighten bolt with ratchet, extension and socket. Install the fabric softener cup.
Fabric softener cup is item 14 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170378&diagram_id=28464917#d28464917
The bolt you need to remove is item 4 of the above link.
Thanks for choosing FixYa,
Kelly
Feb 05, 2011 | Maytag MAV6457 Top Load Washer
I think my daugther's retainer is stuck under the agitator. How can I get it off to check?
If this is a Maytag Atlantis model washer, just follow these steps to remove the agitator:
1. Remove the center post cap and softener dispenser by pulling it off.
2. Locate the agitator bolt under the center post cap and loosen.
3. With the agitator bolt removed, lift up on the agitator by grabbing the bottom flange.
If the model number is incorrect, please post back with your correct information. I hope this helps you.
Nov 11, 2009 | Maytag Atlantis MAV7551 Top Load Washer
REMOVAL OF TOP AGITATOR ON MAYTAG WASHER
i believe all you have to do is put you fingers underneath it grab the sides and pull up,that will remove the whole agitator,if you want to change the dogs,pop off the top fabric softener dispenser and take out the 7/16 bolt and remove middle section,change your parts and put it back the same way you took it apart
Nov 03, 2009 | Maytag PAV2300 Top Load Washer
Aug 09, 2008 | Maytag Dependable Clean Top Load Washer,...
I have a foul smell comming from my washer I want to try to take off the agitator and clean it How? :)
It depends on what model Maytag washer you have. If you have an Atlantis or Performa model Maytag you remove the agitator by, first, pulling the agitator cap and softener dispenser off. Locate the bolt on the center post and and loosen. The agitator will pull straight up to remove. If this is a Dependable Care model Maytag, there's a 1/4 inch screw located on the SIDE of the agitator about 3 quarters of the way down. Locate this screw and loosen. The agitator will pull straight up to remove. I hope this helps you.
Aug 01, 2008 | Maytag Washing Machines
Nov 28, 2007 | Washing Machines
Washing Machines Logo
55 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
