Question about Sewing Machines
Elna carina electronic + duplex sewing machine cam problem
I have a elna carina electronic + duplex sewing machine. When I use the cams the machine will not reverse to complete the stitch. I love my machine - help!
bargainbox
  • 1388 Answers
SOURCE: Elna Carina Zig'Zag Stitch Issue
Over time, and especially when not used, there is a likelihood of dust and old oil forming a sort of glue, or clag....
Remove the needle for safety, then, when you have the setting on Zig zag, gently push the needle arm to the opposite side of the zig stitch.......release the needle arm, and if it springs back quickly, it is fine, if it moves slowly, or almost not at all, then the clag needs removing with application of few drops of methylated spirit to start, at the sort of piston affair that shifts needle arm L & R .....move the needle arm back & forth until it frees up, a drop of oil to finish.........if almost seized, may require leaving overnight after using a penetrating lubricant if it is really resistant....I have had them on the bench for 3 days with manual manipulation a few times each day before they finally come good.
Bargain Box
Posted on Feb 01, 2008
Tally Girl
  • 1133 Answers
SOURCE: The 6 built-in stitches (such
I have the same model, have you turned the first knob on left, the stitch selector, to the stitch you want? Then turn the middle knob, the stitch width to "4". Use the colour guide marks shown in the little picture on left of the knobs so you are dialing up the right settings. So for the zig zag, elastic blind hem, scallop, overcasting and multi-stretch stiches, 1-6 on the diagram you'll be setting the left knob to 1, 2, 3, 4, 5 and 6 respectively and the stitch width and length knobs to "green", you can vary the length and width to suit what you want.
Then for the cams, you need to set everything zero, turn stitch selector to 7, the cam setting. then turn the width to orange again (3-4) and the stitch lenth selector to the orange setting, right around the knob. This engages the "Elnagraph" the device under the flap on top of the machine to read the discs. Basically the green stitches the needle is swinging from side to side while the feed dogs move the fabric forward, making your zig zags, blind hems etc.
But when you engage the Elna graph, the machine matches stiches by moving the fabric "forward and backwards at certain times, while the needle does its thing from side to side. This is what makes elastic or stretchy type stitches because you are putting "stretch" into the seam by sewing forwards and backwards.
Please note: always turn your stitch width and length back to Zero BEFORE you make any changes to the left knob and select a new stitch as this saves on wear and tear to the moving parts in these wonderful machines.
I do hope this assists you and I haven't just told you stuff you already knew!
Posted on Mar 02, 2011
Tally Girl
  • 1133 Answers
SOURCE: Machine Elna Supermatic 722010
tally_girl_2.jpg I don't suppose it would be so simple as setting the wheel inside the elnagraph to "A" to engage the automatic stitches? I've done it myself once or twice LOL.
Posted on Mar 03, 2011
Tally Girl
  • 1133 Answers
SOURCE: my Elna Carina 65 doesn't feed fabric . I've
Is it possible that you've lowered the feed dogs and not raised them again? Is the stitch length dial set to 2.5 and not on a buttonhole blue setting or the Automatic "A" setting?
Posted on Mar 27, 2011
Tally Girl
  • 1133 Answers
SOURCE: Does anyone know of a cam to use in an Elna Carina
I am certain that we demonstrated this stitch with voile or hankerchief linen and using a wing needle and fine silk thread or rayon machine embroidery thread with the turkish hemstitch cam, cam number 140.
For the non heirloom sewers out there entredeaux looks like this.
Here is disc 140in the Elna discs sampler flyer
I am a member of the yahoo newsgroup called "Elna Heirlooms" and the following image was contributed by a member. I believe that members also list any Elna items they may wish to sell.
Or you could contact White sewing centre to order this cam if you don't already have it.
www.whitesewingcenter.com
If you find these images are just too small, feel free to email me on cwrogers@tpg.com.au and I'll send you the jpgs.
Posted on Jul 13, 2011
How to remove a can from an elna Carina . Its stuck and can't remove it. My grandma gave it to me . She hasn't used it in years
push down on the shiny metal centre spindle that holds the cam, this pops the cam up off the little "finger" that it locks onto. If you can't push down at all, try dribbling some good quality sewing machine oil (tri-flow if you can get it, its brilliant) down the centre of this spindle and give it an hour or so, then try again. The cam won't just pull off, you need to push the metal spindle down for it to release.
Jul 03, 2015 | Elna Sewing Machines
How to remove a can from a elna Carina electronic 65
you need to set the stitch width dial to zero, the stitch length dial to zero so that the cam following arm is disengaged and moved back off the cam. Now look at the cam, it is sitting on a silver shiny spindle, press down onto this with your fingers and this will unlock the little finger which locks onto the cam, releasing the cam upwards. Press firmly and it should release.
Elna carina snap on presser feet
Yes, any low shank should work. If it doesn't you can always regift it to someone.
Oct 27, 2017 | Sewing Machines
Does anyone know of a cam to use in an Elna Carina that makes a stitch very similar to french entredeux? What is the cam number?
Jul 13, 2011 | Elna 2005 Mechanical Sewing Machine
My elna has cams to upgrade the number of stitches it can do but I am unable to get them to work. I believe I have installed them correctly but cannot activate them.
Throughout the Swiss Elna range there were several of their top of line models that have the black cams for additional stitches and they all have an "Elnagraph" device in the top of the machine case where you insert the cams.
There are single cams where the needle just moves ffrom side to side while the fabric moves forward. And double cams where the needle moves from side to side while the feed dogs move the fabric forward and backwards to get a combination stitch. The trick is to get the Elnagraph to engage so the arm in it can "read" off the disc.
There are a couple of other knobs that you need to adjust to get the cam stitch though.
Star Series: (white machine with blue top) you need to put the stitch selector inside the elnagraph flap to "A" on the Star series and then stitch width to 4 and stitch length to the red A zone.
Air Electronic SU or Carina: you have 3 knobs from left to right - stitch selector (put it on 7) , stitch width (put it on 4, orange area) and stitch length (turn it around to the orange zone for the automatic stitches).
And on the early Supermatic the adjustments are a little different again.
And ALWAYS turn the stitch width and length dials back to zero, before you change the stitch selector, or pop out a cam.
I hope this helps you get your Elna stitching from the cam, there is a great Yahoo group called Elna Heirlooms too where there are lots of knowledgeable Elna owners and some files listing all the cam stitches.
Apr 10, 2011 | Elna Sewing Machines
I need an instruction manual for the Elna Carina Electronic sewing maching
There is a sewing guide available free here for the SU which is very similar to the Carina
http://www.arizonaexpressionz.com/elna_instruction_manuals/SU_air_electronic.pdf
but not an instruction Manual.
The SU, Carina, 500 and Jubilee all came with two books, instruction manual and sewing guide.
Oct 25, 2010 | Elna Sewing Machines
Elna Carine Electronic Sewing Machine
You should be able to buy a manual online but it may be a cd or image pdf file. Try www.sewingpartsonline.com or www.sewusa.com. If they don't have the Carina but have the Air Electronic SU, model 68 then this will be almost the same. Main difference is the Carina has the needle up/down button.
Here is threading up images to get you started.
Sep 21, 2008 | Elna 8007
Sewing Machines Logo
77 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
