Question about Exercise & Fitness
Error 5 true treadmill 825
Error 5
3 Suggested Answers
  • 103 Answers
SOURCE: I was given a Weslo cadence 825 treadmill. I need
go to iconservice.com they have free manuals and also you may purchase replacement parts there as well. Be sure to get your model number before going to the site to make it easier (lower frame of the machine)
Good luck, Tim
Posted on Nov 25, 2009
maxtreadmill
  • 832 Answers
SOURCE: My True 825 treadmill will
I'm sorry to say that the upper electronics is shot, the eprom is where the program software is located. In matter of speaking - it for the most parts lost its mind !! Call True Tech Support @ 1-800-883-8783 and see what it will cost to replace the upper electronics.
Good Luck!!
MAX
Posted on Sep 25, 2010
TRUE Fitness 825 suddenly stops and after some seconds shown errors E5( sensor error)what would be the cause of suddenly stop ?
Can be the speed sensor or the motor driver is faulty.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Feb 29, 2016 | TRUE Fitness Technology Exercise & Fitness
Why does my treadmill stop after a few seconds then error code E1 displays. What do i do?
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
True Treadmill Errors and Service Messages
  • The True 600, 700, 725 and 750 series treadmills are equipped with built-in diagnostics and maintenance reminders that display either an error message or service message as they occur.
  • The error messages that may be displayed by the built-in diagnostics are as follows:
    • E1:INCLINE
      • This means that the incline is moving when it has not been commanded to.
    • E1:MINIMUM
      • This is a minimum incline calibrating error that can be cleared by calibrating the incline.
    • E1:RANGE
      • This means the difference between the treadmills zero position and maximum incline is not sufficient.
    • E1:STALL
      • This means that the incline is not moving when it has been commanded to.
    • E2:OVERSPEED
      • This occurs when acceleration greater than 2.1 mph occurs as this is greater acceleration than anticipated.
    • E2:CAL
      • This means feedback cannot reduce or increase speed to target and error can be cleared by calibrating treadmill.
    • E3:EEPROM
      • This error happens when a data error is detected on the EEprom. The control panel needs replaced if this error occurs.
    • E5:SENSOR
      • This error occurs when there is no speed or RPM feedback detected from speed sensor.
  • The service messages that may be displayed by the built-in maintenance reminders are as follows:
    • S1:LUBE
      • This service message displays when it is time for inspection of the deck lubrication system.
    • S2:CLEAN
      • This service message displays every 500 miles and is your prompt to clean the treadmill.
    • S3:MOTOR
      • This service message displays every 2500 hours and is your prompt to check the motor brushes.
  • This information should help you understand the cause of the error message or code and how to take action to repair your True treadmill
Errors for True Treadmills E5 Sensor E2 Cal S1 Lube and more
Oct 12, 2015 | Exercise & Fitness
My cadence 825 had been unused for a while but now when I insert the plastic key the treadmill starts immediatly without my having control over it. where can I get some maintenance for this machine. Kevin...
RUN the software calibration for diagnose, troubleshooting , fix it.
adjust the speed sensor, clean it and tight the wires connector
LUBE the deck belt+rollers bearing too
SEE THE diagram.
God bless you
Jul 19, 2012 | Cadence Weslo 825 Treadmill Walking Belt
Safety key is inserted into weslo treadmill cadence 825 but belt wont move, it worked for about 5 minutes before it just stopped, felt like belt was slipping, rollers at either end not moving.
hi if you can take off the front pannel where the motor is. its look like the belt on the motor a either slipped off or you need a replacement,
Nov 15, 2010 | Cadence Exercise & Fitness
Where can I download a manual for a Weslo Cadence 825 treadmill
FitnessRepairParts may be able to sell you a manual if you can't find it anywhere, depending on which version of the 825 you have (there are quite a few.. check for other model numbers on your machine
http://www.fitnessrepairparts.com/part_search/EquipmentSearch/weslo%20cadence%20825
You can also try IconService.com and click on "Manuals" - sometimes they have manuals you can download or purchase.
Oct 05, 2010 | Cadence Weslo 825 Treadmill Walking Belt
My True 825 treadmill will not run and the display shows E3 EEEPROM. What do I do?
Good Luck!!
MAX
Sep 24, 2010 | Exercise & Fitness
Lubricating a treadmill
The only lube required is between the walking belt and the deck. You can get the lube from iconfitness.com. Lift the walking belt and squirt some on the deck from each side, underneath the belt in the area where you usually walk. Walk on it for a few minutes to spread the lube around.
Mar 04, 2010 | Cadence Weslo 825 Treadmill Walking Belt
Good luck, Tim
Nov 24, 2009 | Cadence Exercise & Fitness
We have a Cadence 825 treadmill and the display has quit working. How do we fix it?
either the console is bad (which is no longer available) or the control pwb is bad (available for $114 on iconservice.com) Check for power to the controller. Red light should be on. (you must remove the hood cover 4 screws 2 on the sides and 2 in the rear) If light is on the controller then more than likely you have a bad cosole as I said it is apparently no longer available.
Nov 09, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Candence 825, motor not driving belt, smells of burning
Hi Jill, have you found a solution yet as I seem to be getting a sililar error. Do you get a E02 message and a beep. Thanks Nicky
May 18, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Exercise & Fitness Logo
71 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
