Question about ViewSonic VX1932WM LCD Monitor
Viewsonic vx1932wm flashing blue light - ViewSonic VX1932WM LCD Monitor
3 Suggested Answers
budmrtn
  • 11361 Answers
SOURCE: 3 shaded vertical bars on monitor about 3 inches
That the sign of failed T-CON board on the LCD panel, new panel will be needed. It will get worst with more lines appear.
http://s807.photobucket.com/home/budm/allalbums
Posted on Apr 25, 2010
budmrtn
  • 11361 Answers
SOURCE: How Do You Fix This Kind Of Monitor For ViewSonic
Check the caps in the power supply.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
By the way, your link does not work.
Posted on Jun 01, 2010
How do I remove the back of my ViewSonic VX1932WM-LED monitor
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Oct 03, 2014 | ViewSonic VX1932WM LCD Monitor
V223W acer monitor dont display
Disconnect everything from the monitor including power. wait a minute. Connect only the power. If it still does not power up the monitor power supply is dead.
Not much to do but replace the monitor.
Apr 02, 2014 | ViewSonic VX1932wm Monitor
VX1932WM-LED NO SOUND .......WHY?
Make sure the speakers are connected in the right portal, and connected with the computer.
Aug 22, 2012 | ViewSonic Computers & Internet
Vx1932wm-led background lighting goes out
That is a very common symptom of a failure in the power supply board. This model uses the same power supply board that the VA1930 model uses. Here is a link to repair information that shows what capacitors to replace on the power board to repair it.
http://www.ccl-la.com/catalog/product_info.php?cPath=21_34&products_id=168
I hope this helps,
BuddyMc
Jul 20, 2012 | ViewSonic VX1932wm Monitor
Viewsonic VX1932wm goes black after a few seconds of being on. I need to turn it off and back on to get a few more seconds, then it goes black again.
It probably has dying power supply due to bad DC filter caps, see pictures of fails VIEWSONIC due to bad caps at my Photobucket.com.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV, Monitors, Caps : http://s807.photobucket.com/home/budm/allalbums
Capacitor kits: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Nov 05, 2010 | ViewSonic Computers & Internet
Power light flashes on start up, screen doesn't light up
Try it other PC first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed VIEWSONIC monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Oct 14, 2010 | ViewSonic VX1932WM LCD Monitor
No sound from monitor
that problem is very common on a viewsonic tv replace the power supplyboard.
Jun 04, 2010 | ViewSonic VX1932WM LCD Monitor
How Do You Fix This Kind Of Monitor For ViewSonic VX1932wm LCD http://s928.photobucket.com/albums/ad126/vtamvo/?action=view&current=100531-161032.jpg
May 31, 2010 | ViewSonic VX1932WM LCD Monitor
Apr 24, 2010 | ViewSonic VX1932wm Monitor
ViewSonic VX1932WM LCD Monitor Logo
54 people viewed this question
Top ViewSonic Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
