Question about Electric Demolition Jackhammer
I have a EWHHPS95B83Z1 Electric bosch demolition jack hammer,,,I could not find bits the right size so bought some to have cut down the problem I am having is the length to cut it in reference to the retainer sping should that shoulder fit against the outlet of the hammer or is it just suppose to be short of the retainer spring???The length is right up to the spring but I believe it is suppose to mate with the outside edge of the hammer is this correct????
  • Clinton T Lovelace Feb 08, 2012
    Also it has 4 wires coming out and a commecial plug that I want to convert to a three wire plug in I was told they did not make a 3 phase hammer so want to know what to do with the fourth wire....????
3 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: My Black and Decker demolition jack hammer broke
Go to Dewaltservicenet.com and in the header under service locator follow the prompts and type in your zip code to find the nearest service center near you.
Posted on Oct 01, 2009
  • 1388 Answers
SOURCE: I have the Neiko electric
I have seen many different brand names on this tool depending or retail outlet / where purchased, including Sears, however none of the sellers offer replacement parts or are much help when a problem arises. This tool is a Chinese copy of the Hitachi h65 and parts list for Hitachi hammer can be seen at www.toolpartsdirect.com and many other web sites found by google search ( hitachi h65, or hitachi h65 manual ). Instead of taking apart the lower end of the hammer (if hammer still functions ), just remove the oil fill compartment cover and the oil felt retainer ( or only the felt) and introduce light oil directly into hammer to flush out old oil / debris. After you are satisfied with lubrication of the hammer, clean felt with diesel fuel and re-install. The felt is a wick and transfers the oil to crank. Place the wick in proper place for crank to catch oil (or replace wick with hitachi part). If oil does not transfer, use lighter weight non detergent oil. If you still want to take hammer apart, (remember that no parts are available) you will need to take the rod off the crank by removing the side cover to easily pull the lower end. Good luck with your repair.
Posted on Apr 21, 2011
I have a 3600w arksen jackhammer. It does not have an oil site gauge on it that I can see. what do I do about adding oil to this unit?
all these types of jack hammers hammers use 40 w oil
its electric
cant find a user manual for it online
if no visible site glass or oil filler
whats the chances you have to undo part of the jack hammer
at the Allen key bolts
reviews say these arksen units leak oil often
Jul 20, 2016 | Cars & Trucks
I bought a new jack hammer. After using it for a few hours grease started to come out where the bit is. Is this normal
No thats not normal real JACK HAMMERS on AIR ??? but its not Milwaukee not Bosch not Dewalt but a China brand? if you are have a real jack hammer then its not the right collum because its placed under Hammer drills? and you have also not possible speaking about maybe a little weight rotary hammer ? because ONLY real demolition and jackhammers are very specially made for the long lasting jobs !!! but the weight and power is very important by use the right tool for the right job the most rotary hammers ( exept brands like Hilti and Duss) are not made for long lasting jobs and are made for only working for a short time. its also makes the great price difference between a hammerdrill a rotary hammer a real demolition or a real jackhammer is much higher price. The tools on air Atlas Copco or Ingersoll for the hard and heavy jobs
If you have bought your tool by a hardware store and it is a real jack hammer go immediately back its possible that you are wrong informed by the seller or the budget was the fact. about the price for the tool maybe you have a real jackhammer but have choose a to little model size machine to do the job or its a budget brand online bought China machine. Its a simple question but a hard answer, difficult questions do not exist but difficult answers sometimes.
Regard and luck by warranty and a very small change maybe it is just only a factory flaw.
Apr 09, 2016 | Drills
The service light is on and the power is not steady
1 of the 4 electric sliding contacts of the electric field was broken .
Sep 17, 2013 | Bosch 11317evs ¾" Elec Vs Hex Demolition...
Hammer not Jacking
Mine stopped and I took it apart and found a badly worn piston gasket. I can't however find a new gasket. Anyone know where to get parts for the sky687 hammer drill then let me know. Copipeworks@gmail.com
Sep 18, 2012 | Heavy Duty 1240w Electric Demolition Jack...
Bosch 11316EVS demolition Hammer soft start not working. Starts at full speed and does not impact until slowed down.
Variable speed control module has failed, however you can still use the tool. Hammering action will improve with a good cleaning of internal parts and apply new grease. Hammering action is caused by air/vacuum cushion between drive piston and driven piston which inturn hits a third piston that actually impacts the bit. If third piston is worn, chipped and lodged with debris, there will be light hammering action. After use, store the hammer with the nose pointing down so that the driven piston will slide to end of cylinder and ready for next use.
Sep 27, 2011 | Bosch 11316evs Elec Vs Sdsmax Demolition...
Hello... I've rented a Bosch 11318 Hammer drill and it did not come with a manual......could you please tell me how to insert the bit. thank you.
You should only need to push the bit in. If that does not work grasp the chuck and pull back towards the handle than insert the bit and release the chuck. You remove the bit by doing the same pulling the chuck back and taking the bit out
May 09, 2011 | Bosch 11318evs 11 Amp Sds Max Demolition...
It won't rotate. It only hammers.
The 11316 Demolition Hammer is made to hammer only, it does not rotate the bit. It is for demolition with pointed bits or flat and scraping chisels. If you want to drill holes in cement you need a rotary hammer drill.
Dec 23, 2010 | Speed Bosch 11316evs Variable Sdsmax...
Electric Demolition Jackhammer Logo
121 people viewed this question
Top Electric Hammering Experts
John Trevino
Pieter Vleeshouwers
Pieter Vleeshouwers
Dan Webster
Dan Webster
Are you an Electric Hammering Expert? Answer questions, earn points and help others
