Picture problems LG LCD 37LY95
Hi! I have a LG LCD 37LY95 which three problems: 1. A couple of horizontal bars on the screen. Stay still not moving. 2. Changing channel takes pretty long time compare to other LCDs that I have tried. 3. The TEXT TV picture does not dissapear after having shut it down. It stay on like a shadow in the normal view. It takes same minutes before it dissapear. Any idea? Is it possible to update the firmware on the TV? Sheers,
  • 3 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Posted on Jan 17, 2008
tantong
  • 138 Answers
SOURCE: monitor shutdown also
Hi this is the way how to examine what's wrong with your LCD monitors. Power on both CPU and monitor. After they shut down on their own, you check that you can see the image on the screen by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. Like me, I can see window image using flashlight and check lamps inside. Some of them were broken. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so.
Posted on Feb 20, 2008
SOURCE: lcd tv screen shadow
they call that line pixels and the only way to fix is a new lcd panel. if you have under 8 pixels your warrinty won!t cover with some companys
Posted on Sep 23, 2008
SOURCE: shimmer and bands
i experienced a tainted vertical black lines on the boths sides of my lcd screen. There was no scratch or whatsoever that could be the reason why thsi balck colored vertical lines to spread. Hope you can help me solve this problem. Thank you..
Posted on Oct 28, 2008
SOURCE: frozen picture on LG LCD 37"
Try One of your working TVS and connect it to your cable outlet of the TV that is having problems. If that TV Does not work then there may be a degraded fitting or the Leg coming of the splitter to that outlet could have a Low Signal Problem
Next Take the First TV that was not working properly and put it on the cable outlet of one of the TVs that is working properly and if the TV set works on that Channel then you know it is not your TV that it must be the cable
Posted on Feb 28, 2009
LG 47LM4600 has blank and dark grey bars and no picture. It happened one day out of nowhere and there is no picture with it and can't access any menus. It is just black and really dark grey bars running...
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Jan 11, 2018 | LG Televison & Video
Can i repair my LG LED/LCD TV?
hi this could be a bad ribbon, or bad panel thanks
shaun
Feb 12, 2017 | LG Televison & Video
Samsung ln52a650a1fxza LCD has horizontal band of dark lines across screen
check connections on top of screen this is becoming a stockfault on samsung tvs
Dec 01, 2012 | Televison & Video
I have a 42 lg lcd tv when i switch it on the right side of the screen is darker than the left also there is a vertical bar about 1" at the edge
Be careful using this TV. There is a fault somewhere. No TV should ever do that, cold or not. Replace or repair it
Nov 24, 2017 | LG 42LC2D 42 in. LCD HDTV
Horizontal lines shadowed / blured picture after 20-30 minutes
There are some semiconductors or capacitors that are leaky. Might need thorough check up inside the TV.
Jul 07, 2012 | LG 55LH40 55 in. LCD HDTV
LG 55LD520 picture problem
the problem with these sets (all brands) is it could be any board in the set or even the panel used for the display---
Jun 06, 2012 | LG 55LD520 55 in. HD Ready LCD TV
The right side of my screen at about 3 inches from the side has a vertical bar that is lighter in shade than the rest of the picture. It started as horizontal flickering lines contained in the vertical...
Hello
There must be some loose contact with the t'Con board of your tV. Just look for it. Just unplug and replugh all the strip wires goes to T'Con board. This must solve the problem to your Tv. OK.
Oct 13, 2011 | LG 42LC2D 42 in. LCD HDTV
LG LCD TV - Buzzing Sound and Faint Horizontal Lines
From your description, the sound you are hearing is the inverter(s) that drive the back light for the LCD screen/module.
The inverters mounted on the back side (one lower right and one left side) of the LCD screen/module. They are under the sheet metal cover/shields.
The inverters are going out and or the LCD screen/module is going bad too.
That LG TV has only a 1 year on parts and labor from the date of purchase, but you could call LG and ask for their help for such a new TV. They might do it under a warranty, for little or no cost to you.
I hope this information has helped you.
Good Luck.
May 23, 2010 | LG 47LG70 42 in. LCD TV
Shimmer and bands
Jul 12, 2008 | LG Flatron L1710M 17" LCD Monitor
Computers & Internet Logo
62 people viewed this question
David Payne
David Payne
